Got brush!
/ Got brush! #1
roblwest
yanmar y226
Walk behind string trimmer vs. walk behind brush mower? I've come to tractorbynet to find out. I have an older Yanmar but my ground is to rocky and rought to use a mower with the tractor.
Glad this resource is here.
/ Got brush! #4
Hey roblwest! Welcome to TractorByNet! :D I have moved your thread to the Lawn Care & Landscaping Forum. You will have better luck finding what you need there. :thumbsup:
/ Got brush! #5
Hello and welcome to the best outdoor and tractor info on the web:thumbsup:
have you checked into the DR trimmers?
I'm sure any of the dealers we have here on TBN could tell you about these,;)
/ Got brush! #7
DR has some great self propel models...I believe you can purchase different types of cutting blades.
/ Got brush! #8
If your ground is too rocky for a tractor brush hog, then I'm not sure that a walk behind brush cutter with a metal blade is what you can use, either.
A gas powered trimmer with a metal brush blade is okay for limited areas, but not good for rock and not good for large areas.
I have used a walk behind trimmer with the flexible lines, and the brush worked those lines over pretty quickly. The one I used was not self propelled, either. A good shoulder trimmer is easier to use and at least you have the option of a metal cutting head if you need it.
Sometimes you can spray brush and at least see what you've got to deal with before you start cutting into it blindly.
A photo of your site might help.
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
3 ROLL TOOL CARTS (A67714)
3 ROLL TOOL CARTS...
Mercury Outboard Boat Motor (A66738)
Mercury Outboard...
2006 Ford F-350 4x4 Ext. Cab Reading Service Truck (A66736)
2006 Ford F-350...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
2018 CHEVROLET SILVERADO REGULAR CAB PICKUP TRUCK (A66091)
2018 CHEVROLET...
