Got a 2210
/ Got a 2210 #1
passgas55
Well after kicking around the idea for about a year I finnally bought a 2210. I got it from LMTC and so far I am happy with my purchase. If the weather or the ground is dry Friday I will put some seat time on her. Now I need to make up a box to store all my tractor stuff since the tractor will be 75 miles from where I live. I am lucky in that I have a small barn availible for me to store the tractor. Now back to my tractor stuff box. I will have motor oil, antifreeze mix, 5 gallons diesel, tractor hydro fluid, grease gun, copy of operators manual, gear oil for rotary cutter, some large tools, pins and anything you think I should have. I better add a fire ext. Small hand tools I always carry in my truck. What am I missing? I need to get a ac powered air compressor. Note book.(I am adding things as I go)
On the subject of oil when it come time for an oil change I plan on using either a 30wt or 10/30 wt diesel oil. what weight oil you running in your Yanmar?
/ Got a 2210 #2
Rotella 15-40. When you CD arrives check the 2210INFO.pdf on it for fluid and filter information.
  • can of spray lithium grease, for spraying the linkages on the 3 pt lift and the eyes in the lift arms.
  • can of PB Blaster for anything metal that won't open or loosen.
  • hammer to persuade implements when hooking up.
/ Got a 2210 #3
Great choice going with the 2210. It is a great all purpose compact tractor. I would almost refer to it as the "flag ship" of the Yanmar line up. Happy tractoring.
/ Got a 2210 #4
Make sure your wrenches are metric. When I had my 2210 there were 3 main sizes I believe. I can't remember for sure so I won't say what I think they are, but if you have these 3 sizes, you can pretty much get ahold of any bolt on that tractor. I know one was 22mm the other two were smaller. Great tractor and wise choice in dealers.
/ Got a 2210 #5
13mm and 17mm
/ Got a 2210 #7
Get yourself a Plews oil squirt can, (Sears), to squirt 90wt on those "hard to reach connections, and a whisk broom to brush off your radiator screen. I carry that and 2 12" crescent wrenches, along with some rotary cutter shear bolts in my tractor's tool box.
/ Got a 2210
Here is a pic. i notice that they have a sq. tubing attached to the rear bottom that can extend out. Is this made for pulling a trailer?
/ Got a 2210
this is pic of tractor.
/ Got a 2210 #10
Nice looking unit. You have two of Yanmars best features: Powershift and that 2cyl. YammerHammer :) Sounds like you are describing the drawbar or the place it should go.
Enjoy.
Bruce
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
2010 John Deere 4720 58HP 4WD Utility Loader Tractor w/ Titan Aerator (A66734)
2010 John Deere...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A66736)
2016 Ford F-150...
2012 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2012 FORD F150...
