Got a 2210
   / Got a 2210 #1
passgas55
Bronze Member
Well after kicking around the idea for about a year I finnally bought a 2210. I got it from LMTC and so far I am happy with my purchase. If the weather or the ground is dry Friday I will put some seat time on her. Now I need to make up a box to store all my tractor stuff since the tractor will be 75 miles from where I live. I am lucky in that I have a small barn availible for me to store the tractor. Now back to my tractor stuff box. I will have motor oil, antifreeze mix, 5 gallons diesel, tractor hydro fluid, grease gun, copy of operators manual, gear oil for rotary cutter, some large tools, pins and anything you think I should have. I better add a fire ext. Small hand tools I always carry in my truck. What am I missing? I need to get a ac powered air compressor. Note book.(I am adding things as I go)
On the subject of oil when it come time for an oil change I plan on using either a 30wt or 10/30 wt diesel oil. what weight oil you running in your Yanmar?
   / Got a 2210 #2
Rotella 15-40. When you CD arrives check the 2210INFO.pdf on it for fluid and filter information.
  • can of spray lithium grease, for spraying the linkages on the 3 pt lift and the eyes in the lift arms.
  • can of PB Blaster for anything metal that won't open or loosen.
  • hammer to persuade implements when hooking up.
   / Got a 2210 #3
Great choice going with the 2210. It is a great all purpose compact tractor. I would almost refer to it as the "flag ship" of the Yanmar line up. Happy tractoring.
   / Got a 2210 #4
Make sure your wrenches are metric. When I had my 2210 there were 3 main sizes I believe. I can't remember for sure so I won't say what I think they are, but if you have these 3 sizes, you can pretty much get ahold of any bolt on that tractor. I know one was 22mm the other two were smaller. Great tractor and wise choice in dealers.
   / Got a 2210 #5
13mm and 17mm
   / Got a 2210 #6
^ That's it!
   / Got a 2210 #7
Get yourself a Plews oil squirt can, (Sears), to squirt 90wt on those "hard to reach connections, and a whisk broom to brush off your radiator screen. I carry that and 2 12" crescent wrenches, along with some rotary cutter shear bolts in my tractor's tool box.
   / Got a 2210
Here is a pic. i notice that they have a sq. tubing attached to the rear bottom that can extend out. Is this made for pulling a trailer?
   / Got a 2210
this is pic of tractor.
   / Got a 2210 #10
Nice looking unit. You have two of Yanmars best features: Powershift and that 2cyl. YammerHammer :) Sounds like you are describing the drawbar or the place it should go.
Enjoy.
Bruce
