Gooseneck or stick with bumper pull ?
   / Gooseneck or stick with bumper pull ? #31
I am with Chris on this one, but remember we both have 3500 trucks. Get the bumper pull and save you bed space for other things.
OP already has a bumper pull he is or was debating buying a gooseneck for more room . And you can still haul stuff in ya bed with a gooseneck .
Sent from my iPhone 5 using TractorByNet
   / Gooseneck or stick with bumper pull ? #32
I have one of them pins that is bent from pulling under 8000#'s .
And I even have a receiver hitch that I broke with a little light swing of a short handled 8# hammer . The shock load of a 14,000# load would easily do the same .
But it's where the load is placed on the truck that makes it dangerous with 14,000# plus loads .
It's saver to have the load over the axle than 4-5 feet behind it .
I have pulled well over 100,000 miles trailers 10,000# and above. Almost all BP except maybe 3,000 miles with my GN. I have never once bent, deformed, or destroy a pin, ball, or bar. I did cracked the weld on my 2004 Super Duty's hitch but that was purely my own fault towing nearly 3 times what it was rated for and 1800# of tongue weight.
That must have been a cheap pin and bar!
Chris
   / Gooseneck or stick with bumper pull ? #33
Hard for me to give advice since I have 15 trailers . But I like goosenecks better than bumper pulls .
if I never pull another BP again I'd be happy. I MUCH prefer GN to BP
   / Gooseneck or stick with bumper pull ? #34
Can't put a box blade, plow, ect in with a GN. Look I had a 25' GN with tandem 12,000# axles. It's gvwr was 25,000# and weighed 6,500# empty. I found I had less room with its fold up ramps and dove tail than I did with my 20' 14,000# BP with slide in ramps. Then the bed space added to that was just a bonus.
Don't get me wrong, my GN had its place. But for loads under 11,000# it did not. The 14 bumper pull weighed half what the GN did, was easier to load, easier to manage, and handled 99% of my needs better due to the usable space being better. I have never felt once uncomfortable pulling it with my two 1 tons or two 3/4 tons I have owned.
Chris
   / Gooseneck or stick with bumper pull ? #35
Guess it all comes down to comfort level. We pull 25,000# of the bumpers.
As for a 5/8" hitch pin. The sheer point is north of 50,000#.
Chris
What kind of hitch do you use for that much weight?
That seems kinda heavy for a pick up?
   / Gooseneck or stick with bumper pull ? #36
Chris
Well you have been lucky is all . The pin and bar was standard products anyone could buy .
And u just stated that its dangerous to pull bp trailers with them weights because your over loading the tongue weight . So over weighting the tongue weight makes it dangerous . Sorry you don't see your dangerous even though you stated ya was .
O and you need to get and pull more . Your way behind my pull'n miles . Lol
   / Gooseneck or stick with bumper pull ? #37
Chris
You could have easily stood your ramps up strait and had more room . Sorry you didn't know that you could do that . Or could easy use a slide in ramp with a dove . Then you could use the whole length of the trailer .
So the OP has a 18" bumper pull and is thinking 25 dove that he could easily use the whole length like I just stated . So I see 7' of useable room difference . He was looking for more room not weight carrying .
Your the one that has a weight problem . Lol
   / Gooseneck or stick with bumper pull ? #38
I call bs on breaking that hitch with one light swing from that hammer unless it was already fractured or damaged.
And I have done some serious pulling Jerking and yanking on seemingly immovable objects with my 8000# truck and a cheap 5000# rated tsc insert and never even slightly bent a pin. So unless you were using a homemade pin out of plain mild steel, I call bs on that one too since this seems to be turning into a pi$$ing match...
   / Gooseneck or stick with bumper pull ? #39
Nope I was a pretty light swing with the hammer pictured I was stunned it broke and it wasn't fractured or damaged i looked for that at the break . It was stuck in a hitch from rust so I thought I would tap it out and that's what happened . Heck I was going to use it glad it broke tapping it out and not hooked to a trailer .
As for as the pin it is a factory standard pin . I still have it somewhere .
And pissing match not really . Just means that there's dangerous people out there pulling dangerous heavy loads .
   / Gooseneck or stick with bumper pull ? #40
Think its worth the difference to go to the gooseneck ? Id gain more deck space, but loose some hauling capacity (12k vs my 14k)...
Call eTrailer.com and ask them what they recommend. Faster solution, without insults if you opt for a bp. It will also save posters in this thread the time they'd waste looking for pictures or videos of breaking a GN hitch with a tack hammer. :D
2011 Kubota M7040SUD 68HP Utility Loader Tractor (A49461)
2011 Kubota...
71054 (A49346)
71054 (A49346)
2018 John Deere S780 Combine (A50657)
2018 John Deere...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2006 INTERNATIONAL PAYSTAR 5500I KILL TRUCK (A50854)
2006 INTERNATIONAL...
