Good morning!!!!
   / Good morning!!!! #164,921
With this wind, I better look outside and make sure my camper is wheel side down.
   / Good morning!!!! #164,922
Cat in basement will jump on dryer, from there jump on cabinet top, then get on ceiling of basement bathroom. It’s 8ft, basement is 9 ft.
Today it figured out to walk from there across ductwork and get to shelves on other side of the wall, and then get down on side he ain’t supposed to be.
So I piled boxes on top of the cabinet so he would have no space to land. Within 5 minutes, as I sat and watched, he was up there.
Now I screwed a ceiling under those 2x4s out over the cabinet. Will see how long this takes.
   / Good morning!!!! #164,923
little glitch, seems rv dealer two hours away forgot to put power cable back in rv.
I looked in every compartment three times. Someone just forgot.
Camper's World is half an hour away, headed there early tomorrow. Dealer will set it aside for me, going to get some work
done there anyway. another spare...
meanwhile ran a super heavy extension cord to inside of rv, running a 1200 watt space heater on a thermostat.
Tomorrow when I get back, if it's cold I'll just run the propane furnace for ten minutes.
I asked for a quote to replace the existing 13.5k a/c with a 15k heat pump, so I can forgot worrying about heat.
I actually have done just fine with two electric heaters in the past. Real question is whether the rv will stay cool in S. Florida.
pretty tuckered out, but a good day.
   / Good morning!!!! #164,924
Went out at 11:45 to plow 6" of fluffy white snow and got back in at 16:30, this place and my usual 5 plus one extra I am doing while he is on holidays.
60% chance of flurries tonight and tomorrow.
You tube rabbit hole here I come for the rest of today.
   / Good morning!!!! #164,926
just read that NJ governor says, just like California, no new ICE cars sold after 2035.
Sounds good to pass this legislation, but where's the absolutely required and missing funding for an adequate
charging system nationwide? And is all the electricity made by burning moonbeams?...
then they mentioned this:
introduction of zero-carbon-emission heating and cooling systems to residential and commercial buildings.
what does that mean other than they clearly don't like fireplaces and wood stoves? Or propane. Or fuel oil. Or, or, or
not everyone can afford geothermal heating...
I hope they do some kind of impact study on the cost of these changes. Not just the perceived benefits.
NJ's mid state air is noxious, drive near the Newark Airport or the Jersey Turnpike. So clearly they, like California, have to do something.
On clear nights I go out and collect five gallons of moonbeams. Guess I'll be ok for fuel.
Don, I played the album Traveler pulling out of the dealership, an old favorite a friend gave me on my first rv. Hard to beat Willy.
   / Good morning!!!! #164,927
I found this interesting. If I go on the road, will take a closer look.
Starlink is now a huge deal on yachts, will put the existing VSAT carriers out of business.
Starlink now says they are global, even the North Pole.
there are so many satellites up there now, surprised they aren't running into each other.
Maybe they reserve a position with some governing space body?
   / Good morning!!!! #164,928
Good (Saturday) morning. Overnight Low of 16.5C and it's presently 23C, overcast and fairly calm... a vast 'improvement' over yesterdays top of 38C with strong arvo winds.
Just 'tootling' along.
   / Good morning!!!! #164,929
On driving on the autobahn rented a BMW sedan and was doing 200 kph when a car used the horn for me to pull over to pass and went by pretty fast. It is generally safe driving but when accidents happen not much is left.
Doing 120 MPH was common when we went to Vegas for shopping. It was 100 miles from Bullhead City, AZ to Vegas and part of it was getting up from Davis Dam to Searchlight a winding hill climb and then straight as far as you could see until hitting Henderson. 100 miles took one hour in a big block sedan rental car. Forget about mileage you could literally se the gas gauge needle move down as we drove.
   / Good morning!!!! #164,930
I have a Starlink RV system, used it at home until they let me buy the home system. Now they have another version you can use in motion, my RV one is like the home system, just costs more. I have it on pause.
   / Good morning!!!! #164,931
Doing 120 MPH was common when we went to Vegas for shopping. It was 100 miles from Bullhead City, AZ to Vegas and part of it was getting up from Davis Dam to Searchlight a winding hill climb and then straight as far as you could see until hitting Henderson. 100 miles took one hour in a big block sedan rental car. Forget about mileage you could literally see the gas gauge needle move down as we drove.
But gas was cheap, back then.
It is 313 miles from Toronto, ON to Montreal, PQ. I could do it in 3.5 hours flat, but I had to 'get with the program and stay with the program', and hopefully not get busted for speeding. The whole trip was 60 mph road, but the speed limit signs up here are merely a suggestion.
   / Good morning!!!! #164,932
My weather station still not reporting in. I tried to reset it’s network but didn’t work yet. Had to leave,
Went to game night at church. While they played, I got 2 Ethernet cables pulled thru the floor conduit, then up to podium. Have the hdmi working to the old projector and thru the new switch. Next step is to install the new 4K projector.
   / Good morning!!!! #164,933
Good evening all. 25ºF for the start, mostly clear sky, breezy. Wind slowed done during day, partly cloudy sky, and high temp was 50ºF. Clean ashes and revive the fire in insert to start day. Puttered some in morning, take wife to Hair appointment, grocery shop, pick her back up and have lunch then come home to ride. There is a project going on to replace 50yo water pipe, Have lost water for couple of hours, then half day. No loss today but lane blocked for 1/4 mile for most of day, not sure how many days that will last. No nap today, ride starting with below freezing temps tomorrow :( 🥶 :eek:
Bill hope you had fun plowing today. Hope rabbit hole was fun
Ron sorry about the ice. Glad meeting with financial guy went well. Neat pose in pic.
Drew will be fun driving in the wind. Hope you got home ok.
Spike hope you get to fertilize the fields soon.
Phil nice snow pile. Glad to hear wife getting voice back. Nice bowel. Hope garage door install went well.
Dennis sorry about no updates from WX station.
Mike sorry about the rain. Hope you got rid of the construction waste.
Thomas thanks for info. Record is largemouth bass.
Thomas sorry about rain. Hope putter was fun and good date night.
Frits sorry about power, did you phone power company?
Billy yes was largemouth. There is a catch and release on all largemouth, 12 inch min on crappie, and sand(white) bass, no limits on channel cat. Mating season does have it's risks :)
Dave you are sure warm.
Lou sorry about the weather being warm and weird.
Paul hope trip to Costco went well. And music night was fun asn delicious.
Buppies glad cold shot will be short. prayers sent.
Ken hope no damage from wind.
Frits glad you got power only out 4 hrs.
Ted sorry it is so cold. Good luck with the door track.
David hope you made progress om laundry room and no hurt surgry. Hope curry was good and the luck for guy was good at H&F.
RS sorry you got caught with sander, maybe when you use it on handles might get more of a pass. Hope bathroom is coming along now that valve not leaking. Hope sanding table coming along.
Dennis sorry about lost power at church.
Kyle sorry about commuter cars all have issues. Hope family vision test done soon.
Drew are you sure it has fuel filter that gets changed? Glad you got home ok.
Dennis good luck slowing cat down.
Drew sorry about the no power cable.
Bill glad plowing went well.
Drew good thoughts on NJ legislation. Hope you can work Starlink out for mobile internet.
Randy(wag) glad heat did not last long.
Frits I remember the big block appetite for gas, used one for towing boat.
Dennis sorry no progress with WX station, glad progress on HDMI cables, hope projector install goes well.
prayer for all , especially Jay/Peg, Kyle /Daughter, /mom's breathing, /learning new job, /friends upcoming new baby, /son's migraines, Bird /aging issues, Ron /heart, Billy /mom hypertension & congestive heart failure, David(moss) /remodel, /divorce, Buppies /new skin cancer spot and treatment, /elbow healing, /wife knee healing, Thomas /gout, Phil /reflux, /wife's voice, Frits /veteran son with mental issues, /granddaughter with Evans Syndrome, Ken /dad possible dementia, Steppenwolfe /son-auto immune disorder, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, /wife feeling bad, Lou /eye issues, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's and David's new eye surgery recovery, Chris /neighbor's granddaughter and Covid issues, Scaredy/shoulder dislocation, /marriage not doing well, / friend stop drinking, Paul/ wife's healing from back surgery, Dennis /retirement, /neighbor issues, /land development, / brother "alligallyitus" and back in hospital, Drew /foot heel issues, /friend's wife cancer diagnosis and recovery, mike /wife's healing from surgery, Scotty /back pain, Frits /daughter recovery from surgery, Helogabals /second opinion, /wife's friend situation, Mark /wife colon surgery, Fatjay /father broken hip, Ukraine war, and Country.
   / Good morning!!!! #164,935
good morning all
not very warm here today, 28 going up to only 44 in sun, should be clear sunny day though.
am off early to campers world to get rv power cable, then home to sanitize inside of rv so I can start putting things away.
didn't sleep well last night, nose is a little sniffly this morning.
.51 inches of rain yesterday, temps were high enough nothing froze.
Hope you all have a good weekend.
   / Good morning!!!! #164,936
Good morning. Yikes, 28 degrees here. Guess I forgot to watch the weather. Had left my hose reel connected, so flushed it a couple times this morning to prevent it from freezing up. Quick (I hope, wife will be along) trip to Ace Hardware this morning, maybe Altman Plants. Altman is huge and has public sales at wholesale prices, cannot be beat.
Wishing everyone a safe, happy, enjoyable day. Don't work too hard. :)
   / Good morning!!!! #164,937
26 going to 51. Windy forecast next few days after today...should help dry things out.
LS, yes it's a restaurant...in an old building that was built over a spring...it is still flowing into a stone lined pool in what looks like a cave right in the main dining room. Good food.
Kilroy, hope your cold is better.
Replaced two bluebird houses, and cleaned out 4 others. They all seem to be in good spots that the bluebirds like. The Evening Grosbeaks are still here...have stayed since January 9th...never had them hang more than a week in winter. They are sunflower vacuums.
   / Good morning!!!! #164,938
Drinking hot coffee. 17° with clear skies this morning. Heading to 44° with partly cloudy skies. Sun came out about noon yesterday and melted ice on driveway and walkways where sun shines. Areas in shade did not melt. Put ice melt done. Poor Sassy wanted to go out and take care of her business. Turns out grass blades with ice on them turned into little spikes. I went out in snow boots and trampled down a area so she could get to where she wanted to go. All north window on house still have a sheet of ice on them. Should melt today. Was looking for some papers yesterday. Ended up emptying out the whole 2 drawer file cabinet. relabeling all the file holders and putting papers back in. Did not find what I wanted in there. Went to another cabinet. Papers where on top of the pile in first drawer. Ended up cleaning out that cabinet also. 2 Large bags of paper to burn today. Should be nice out after it gets above freezing.
Staying out of freezing rain.
Don, I always liked Willie music.
Drew, put on you Bucket List a List to visit Fredericksburg, TX. With a side trip to Luckenback. Wife and I spent a whole winter in the area in 2007.
Everyone stay well and safe.
Good Morning All.
   / Good morning!!!! #164,939
Or you could ArmorAll the top of the cabinet and dryer and maybe get something on America’s funniest Videos…
   / Good morning!!!! #164,940
28 outside this AM. Upper 40's expected. Like wngsprd, hoping the winds will help dry things out.
Feeding horses last night, stepped right and a gush of mud went from my toes to my thigh. Talk about projectile squishy. Had to change my pants. LOL. My koi-less pond now has a child pond next to it. The water is just not going where it should. I expect Summer when it gets here, any day now, to be draught conditions.
Today, will finish up framing and vinyl on that one side of the Milk House. If I get bold, maybe hang the door.
Hope all have a great weekend. To those in need, get healthy. Be safe all.
2000 TEREX T560 CRANE TRUCK (A59905)
2000 TEREX T560...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
Jack Daniels Miniature Decorative Truck (A59231)
Jack Daniels...
2015 CATERPILLAR 725C WATER TRUCK (A60429)
2015 CATERPILLAR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A59905)
2019 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
