Good morning!!!!
/ Good morning!!!! #133,201
Nothing like a stiff neck and sore shoulders to make a fella appreciate a good soak in a hot tub...
So true. Seems the older I get the stiffer and sorer from overhead work.
/ Good morning!!!! #133,203
Got an odd one here...
When I start my 4052, I give it a few seconds at low idle (1000 RPM), than increase the RPM to 1500...done that with every tractor I've owned.
Now, when I start the tractor, I get a display "Increase Engine Speed to 1500" (something like that). However, idling at 1500 RPM disables the Hitch-Assist. Even when I reduce the throttle to minimum, the speed stays at 1500 RPM. This tractor has a regen program, but the soot content is only at 31%, well under the regen requirement.
No sure about JD??? Messicks has video about Kubota small to medium size Regen,about 50 hours Regen and rpm's will increase,operator has to choices increase rpm's if working or set idle until Regen done.
/ Good morning!!!! #133,204
Hope the soreness pass quickly for you and Mrs. Kyle.
/ Good morning!!!! #133,206
67F cloudy looks like another down pour on the way,little after 12:30pm had gusty winds rain thunder storm.
Been good day for outside chores,trim blue spruce area and front field also mow the front field,while mowing front field eyes were upon me waiting for meal.
Not much plan for this evening...since it's National Barbecue Day Mrs. decided chicken and sweet corn on the cob from the grill for dinner,than recliner share bowl ice cream with kittens.
Enjoy your evening all.
/ Good morning!!!! #133,207
Ron, nice picture. We are past dandelion season except for a few strays.
Kyle, ouch. Hope nothing too serious. Get checked out. Shame on a good car.
Thomas, nice owl.
/ Good morning!!!! #133,208
Worship went well, a couple people asked if we were going to drop the mask requirement, but not today. I had song leading.
Ordered takeout Mexican from the new place, really like it.
Thunderstorm came by about an hour ago, but just a few sprinkles from it. I took a nap
Now it’s started raining, looks like enough for a good watering. We need it. At least it’s green here, but lost some garden plants already.
/ Good morning!!!! #133,211
Gas is available at probably 80% of the stations here with no lines. Unless there is a part2, this too has passed.
/ Good morning!!!! #133,213
I bought the wrench. Now I can change the pump in less than 30 min. The first one my old mechanic and me took a few hours. It was the bottom one and was impossible to see what you are doing.
I’ve got the Tempest wrench, but it wouldn’t fit, engine was too close to the firewall.
/ Good morning!!!! #133,214
Good Evening All.
Was a bit slow to get moving this morning, may have over done it a bit yesterday ... :rolleyes:
Was 68F and partly cloudy @ 12:30 ... currently 60F and partly cloudy @ 21:30, headed down to an overnight low of 51F.
Managed to hit a high of 70F for the day, was really quite beautiful.
Possibilities of rain through next Sunday appear to be low with highs in the upper 80's starting Thursday ... should be good for getting a lot of work done outside ... (y)
Spent most of the afternoon working on the sprayer. First issue was diagnosing a problem of no juice to the pump. That turned out to a faulty connection with the trolling motor receptacle which was easy enough to fix once I tracked it down. Once I had that handled and the pump was running I noticed that it wasn't making pressure so I stuck a new diaphragm kit in it that Fimco had sent me, that I had up in the shop. That got us up to around 65 - 70 psi ... (y)
Next issues were the spray gun/wand was leaking (cracked) and the retainer cord for the cap for the tank had broken off some time back ... which allowed the cap to leak out the top. Tried cobbling something together on the gun/wand from old parts but ultimately that didn't pan out. So around 17:30 I headed out to TSC, after having placed an online order for both items and a new Accu-Rite measuring cup.
When I got there the lady that waited on me pulled the order out and it was missing the tank cap, said they must be out of them. So I signed off and took what she offered ... and then walked back to where they have the sprayer parts, and lo and behold, there was the cap (two of them actually) they couldn't find when they pulled the order hanging on the pegboard. Took it up front and paid for it and headed out to the truck.
Once I got there, I looked a little closer at the spray gun/wand she had given me ... it was missing the nozzle tip. Not only that, it was also the wrong item. I had ordered a regular one and they had given me a telescoping one.
So I walked back inside and explained the situation and walked back and got the right one ... complete with tip even.
Best part of the trip was seeing that the Dunkin' next door was advertising iced butter pecan lattes on their electronic sign (right after the "Help Wanted, $10 - $12 Per Hour" ad)
I settled for just a butter pecan coffee, and skipped the latte.
Best part of the TSC experience was actually getting all the correct stuff - before I actually left the premises (and the items I really needed being on sale)
Managed to get a couple gallons of glyphosate mix sprayed after I got home, leaving about 22 gallons in the tank to start with tomorrow.
Woman and I split a meatball sub from the local place, and I finished off the last two pieces of the Dominos as well.
Just moved her car from in front of the garage and pulled the Cub inside. Light aim much better ... but still needs a little further tweaking. Really amazed at how much light they put out.
Hope everyone had a great day ... (y)
/ Good morning!!!! #133,215
I bought some outdoor tickets for a band playing Fleetwood Mac songs. Because of the threat of rain and the easing up of the CDC it was moved indoors in the town's Square Palace Theater. There were about 100 people in attendance - the band and singer were good. Mask were only required going in and out and there were none worn other times.
Kyle sorry to hear about your accident in Houston. When I was rear ended in the Kia the person behind was going 5MPH and caused $2,500 worth of damage. Their insurance paid for a rental car while mine was being repaired.
/ Good morning!!!! #133,216
Good evening all. Yesterday overcast, 61F light breeze. Windy, overcast with peeks of sunshine, high 81F. Tour de Norway, rode the 60 mile route, operator error caused a loss of 1.2 of the GPS track. 2700 feet of climb and headwinds starting at about 11AM. Got home in time to shower and take wife to dinner. Today 67F for the start, overcast and light rain in the area. almost 1 inch rain by 5, heavy rain at 8. high temp was 74F. Chapel to start day, made wife's breakfast, and conserved energy and napped till after dinner bike ride.
Covid update: Cooke 3217 confirmed cases, 7 active cases, Montague 1759 confirmed cases, 3 active cases, Grayson, 11308 confirmed cases, 15 active cases, local not updated.
Ron hope you got the grass done . glad you are spending time with aunt. nice cardinals
Bill not unusual that the fans used are a standard type that you can easily get.
Buppies good luck with bear, 50% hit rate on quoting sounds great. thank you for your prayers
Ray agreed Juan does a nice job with all his videos. Tax time never fun. hope you chores get done
Drew sorry about needing Helga the Torturer, hope the Makita works well enought.
Thomas hope that finished your wood work for a while.
Randy here is hoping you can get it all done.
Eric nice looking repair job.
Drew it is easier to blame other for the poor choice we make :(
Paul glad your day went so well. I would be waiting for the other shoe to drop :)
Don that is impressive your potatoes are about ready. Don locally no mask mandate, some store have then, not enforcing it.
RNG sorry about all the loose ends you have had to fix on the van. Don't people realize you aren't supposed to pull up stake that are not yours?
RS sorry your rain chances have left, my 10 has rain every day! hope you day went well. good luck kart engine
David hoping your insulation installation goes well
Bill sorry about the new power washer, have fun with new mower
Dennis nice day got can't open mesg. on pic. nice pics
More catching up tomorrow.
prayer for all, especially Jay/Peg, Kyle's daughter,Bird/aging issues, Billy/skin cancer, David(moss)/remodel/divorce, Buppies cancer surgery, Phil/reflux/wife's eyes,Steppenwolfe/son-auto immune disorder, Dennis/older brother/son, Grev/wife's eye, Randy/recovery, Bill/DIL home care, Ted/knee recovery, Doug and wife/health issues/nerve and pain/ wife's eyes, Ken/uncle, Drew/tendon healing, David(sadamo)/Sophie's eye surgery, and Country.
stay safe and healthy you all.
/ Good morning!!!! #133,218
Boy that hot tub sure felt good after working arms over head.
Ceiling insulation in container done except a strip about 11”, width of container. Might wait until I get walls done and just wait to see what I have for cutoff instead of a new sheet.
Used Heavy Duty Liquid Nails for adhesive. Seemed to work OK if I gave it about 45 minutes before removing the support/lift. I’ll leave the cleats in place and remove as I install the sheetrock. Once sheetrock is in place I don’t care if the insulation slips.
While I’m tempted to sheet the ceiling, I think I’ll continue the insulation install, then switch. I’m hoping the walls to be much easier than the ceiling.
Progress, with a hot tub reward.
/ Good morning!!!! #133,219
2021-05-17, 0308
40 right now, high in the low 70's today...
/ Good morning!!!! #133,220
52 high of 64 sowers after lunch after tomorrow heat starts to build 90s next week
prayers for mostly wife, L4N DIL, LS knee, Kyles family auto accident, Toppo, Drew’s shoulder, Stepp son, all others our Country
2015 Toro Z Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2015 Toro Z Master...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2006 Godwin GHP45KW-RC45kW Towable Generator (A59228)
2006 Godwin...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
Mini Margaritaville Truck (A55853)
Mini...
2001 John Deere M665 60in Zero Turn Commercial Mower (A59228)
2001 John Deere...
