Good morning!!!!
/ Good morning!!!! #104,461
Just read that whenever you write the date this year (especially on legal documents) always write out the entire year "2020". If you just write 20 it is too easy to change the date by adding two numbers to the end.
Randy hope you have a good report with that new vegan valve.:thumbsup:
/ Good morning!!!! #104,462
My wife starts her 3rd semester of Spanish today in the language club.
That should come in very handy in your neck of the woods Don.
I'm not much beyond the Si, Bueno and gracias level, and sure wish I was.
Friend came over and picked up quite a few left over veggie seeds I was going to give away, to plant on her farm.
I gently unloaded on her about my damaged truck in that food pantry parking lot debacle, since she is on the board of the food pantry, and
she was shocked by the fact that no one ever got back to me after my admittedly aggravated email to the head of the place.
She promised this would go back to the board and get better signage. And as a devout Christian lady with all her kids in Christian schools, she was
really annoyed that anyone would use that language on that property.
I admit being dumbfounded by what the guy did. Beginning to think this may be a senility issue, and not mine...
I need a new headlight as the old one's glass alignment point broke off. One of those projector lamps/bulb, might ask about them finding one from salvage.
Bear took out the first one...now here I go again. 1100 bucks, truck only has 25k miles, need to get it fixed and likely will downsize to a smaller truck
/ Good morning!!!! #104,464
Good point.
/ Good morning!!!! #104,465
You guys were talking about Craftsman tools and returning them to Sears..... I found out that the Lowe’s stores that carry the Craftsman tools will replace them just as Sears would. All of the Sears in this state have closed, so Lowe’s is the only alternative. I have a few screw drivers to get replaced, I will get them together and maybe take them back this weekend. I will post my results with Lowe’s.
/ Good morning!!!! #104,466
Good morning. It's 49ー here with very heavy fog ... probably less than 1/4 mile visibility. The sun should show up and burn this off by mid morning but ... I need to head out for the Richmond house by no later than 6 a.m. this will be an "interesting" drive. Our forecast is for 69ー this afternoon and a sunny weekend with highs in the mid 70's.
My early morning trip is partially to offload about half a p/u load of recycling in Richmond before the recycle truck comes by early this morning. They don't do much recycling ... out here in the frontier. I also need some hardware for a couple of shop projects that I can't source locally.
RNG ... glad you're home safe and sound.
David ... I had same thoughts about Sears a few months ago and gathered up several ratchets to get replaced. Hope you get your water heater sorted.
BEF ... hope you get over your cough.
Randy ... we've had really good results using Wet & Forget on the north facing siding on our house. The effect seems to last. I apply it using my foam gun and pressure washer. I can do second story from the ground.
Amazon.com: MATCC Foam Wash Gun 3 PSI High Pressure Washer Jet Snow Foam Lance Foam Cannon Foam Blaster with 3/8" Connector: Automotive
Everyone have an excellent start to your weekend.
Prayers to all.
I use that on gravestones, never thought to try it on the house and buildings,I use 8/1 water to bleach with a low pressure sprayer, about 25 lbs at high setting. It easily reaches the peaks of all the buildings. It usually lasts about 1.5 years. I lost track of how long it痴 been while I was sick. I might try the Wet and Forget this time.
/ Good morning!!!! #104,467
An overcast 33ºF for today’s low; a 37ºF presently; and I am hoping for an overcast afternoon with temperature in the low 40ºF’s. It was a good day for the diesel fuel run with dry conditions expected today and possible manageable snow this weekend and again early nest week. For all the TV ProMet hype about the warming trend and melting ice/snow it has not happened around here yet; ice is still hanging on trees. There was a lot of ice/snow storm tree damage around here in the hilltowns.
Rich- Good luck with the “countdown.”
David- I am sorry to read about Sophie’s slow healing and postponement for the next surgery, but she is healing and hope hope she stays on light duty around the place. And good luck with the water heater.
RNG- I am happy to read that you made it home safe & sound. We both really liked Downton Abbey.
Randy- I am happy to read about your ongoing progress and hope that it continues.
“… "DO NOT SUBSTITUTE" this task could be tribal test of courage”- Thomas I think this is instinctual. There are probably prehistoric cave drawing “game and produce” lists inscribed by some alpha female in some cave saying the same thing :eek::rolleyes:
Drew- I am sorry to read about your truck and good luck getting a new one.
I hope that everyone is having a decent day today.
My + thoughts, wishes, and prayers.
/ Good morning!!!! #104,468
64°F and .14 inches rain.
A quick run into town for $5 Friday at Safeway and back home.
Prayers for all
Be safe
Have a great day
/ Good morning!!!! #104,469
This was 1 spraying with wet and forget. I bought it at Costco probably 8 yrs ago and finally tried it last fall. I couldn’t reach the top of the window from the ground with a pump sprayer, but it all used to look like the top. I need to reapply. Overall worked well.
/ Good morning!!!! #104,470
Nope, propane here as well. From my research, consensus seems to be that unless a straight forward fix on a not too old unit usually more cost effective in long run to just replace unit. Always a hard decision given the cost. I know locally adding in the os of he service call pushes the numbers quickly. Guess I知 fortunate in that I can/will do the replacement myself, so basically cost of material and my ç´*ree time.
Our repair guy came back out yesterday and ran all the tests for fuel and water flow, power,etc. again. He was stumped and said the only other thing to try was to clean the burner area and fan assy. He found a small amount of what looked like cat tail seeds with the fine fluffy stuff but it appeared pretty clean over all. He put it back together and so far, it works fine. One thing he mentioned was that these units are designed to heat cold water and we have a solar heater upstream and he said that could cause problems. Time will tell.
/ Good morning!!!! #104,471
Do you have a pressure washer? Consider a foam gun, to reach high areas and get better coverage. Plus you can use the foam gun for many other tasks.
This is the one I bought and it has good adjustability of both pattern and water to product ratio.
MATCC Foam Wash Gun 3000 PSI High Pressure Washer Jet Snow Foam Lance Foam Cannon Foam Blaster with 3/8" Connector Amazon.com: MATCC Foam Wash Gun 3 PSI High Pressure Washer Jet Snow Foam Lance Foam Cannon Foam Blaster with 3/8" Connector: Automotive
/ Good morning!!!! #104,472
I usually use a PW to wash it off. Tried wet and forget so I didn’t have to pull out the PW.
/ Good morning!!!! #104,473
The 8/1 bleach mix will get it like new, usually in one good application and no rinsing or high pressure is required. Much easier on the siding, shutters, etc... than blasting them with high pressure. I’ve been using this method for 15 years.
/ Good morning!!!! #104,474
I'll bet she's having a good time, too. In the 10th grade in high school in Marlow, OK, I took a year of Spanish; couldn't get any of my friends to join me, so it was just me and 6 girls. But you had to take Spanish 2 years for 2 credits, and we moved to Marietta, OK that summer and the school there did not offer Spanish, so I never got that second year. I've always regretted not finishing learning Spanish.
/ Good morning!!!! #104,475
I made a run into town today, so swung by Lowe’s and exchanged a bunch of beat up, abused, and broken Craftsman screwdrivers. Some were bent using as a pry bar, one had the handle halfway chewed off by the dog, others had the tips broken. Lowe’s replaced all eleven of them, no questions asked. Total of $55 worth. Lowe’s has my :thumbsup:
/ Good morning!!!! #104,476
Woohoo. 3 hours of seat time hauling over 40 FELs full of mulch around the new raised beds. Now that they have the wood chip pathways around and between them them they are really looking good.
I was just about to stop for the day when a helper showed up and then we just had to finish it - especially since I now had someone to rake the mulch and did not have to get off the tractor.:D
/ Good morning!!!! #104,477
Don ... do you create your own wood chips from your FireWise and trail clearing?
/ Good morning!!!! #104,478
Yes we do, everything is mulched/chipped nothing is burned, but we use that mulch at those location either spread out under the trees on fireWise or on the trails on trail clearing.
These wood chips come from other sources like the landscape companies that trim trees in the neighborhood.
/ Good morning!!!! #104,479
Good evening all. 43F for the start, overcast moderate wind. Wind backed off in the afternoon, sky finally cleared off, and high temp was 57F. Slow start, envelope stuffing fish club forms in the POA billing to start day. 10 of us got 1500 envelopes stuffed in about 25 minutes:) . Then off to town to get grocerys and wife's hair permed. Did get a nap in, wanted to work on a friends bike but timing did not work.
All the people with countdowns hope you make it with no issues.
David hope Sophies eye continues to heal. Wife has that issues with restaurants, she finds something she really likes and poof in less than a year it changes, restaurant closes changes cooks etc. drives her mad.
RNG, nice you made it home glad it was a good trip, hope you get windshield fixed soon.
Randy, good to hear better than before operation, how long before you are fully recovered?
Rick, thanks for the wet and forget tip have some siding to try that on.
Ron, I put my appointments in phone calendar, used a PDA for years that synced with desktop. I suffer from CRS (can't remember stufff...)
Ted, glad you are mostly recovered from bug.
Don good advice, thanks
Ted thanks for Loews update, no Sears here either.
Don are going to work like Drew and make us look worse?
prayers for all.
/ Good morning!!!! #104,480
Good one Eric, made her laugh. Me too.
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
UNUSED SUCTION CUP WINDOW GRABBER HANDLE (A60430)
UNUSED SUCTION CUP...
2018 JLG 742 TELESCOPIC FORKLIFT (A60429)
2018 JLG 742...
2021 Billy Goat F902H Walk-Behind Debris Blower (A59228)
2021 Billy Goat...
2008 KOMATSU PC138USLC-8 EXCAVATOR (A60429)
2008 KOMATSU...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
