Good morning!!!!
/ Good morning!!!! #24,261
Good morning all. 75F going to 95F sunny and breezy(?). Searching for more houses, and will help weed eat today. Yesterday spent 5 hours on Lake Texoma. Not much boat traffic, all the restaurants were closed. Hit a little wind squall on way back to boat launch waves 2 1/2-3 feet, lot of spray when running.
/ Good morning!!!! #24,262
70 and foggy. Headed to 88 and humid.
Guess I will finish mowing then try to do trimming later in week.
/ Good morning!!!! #24,265
2014-09-03, 1226
I see David (MossFlowerWoods) hasn't posted in several days...guess it's due to his financial problems. Well, I do wish him the very best and I hope he overcomes those problems!
/ Good morning!!!! #24,266
68F and .73 inches rain last 24 hours. Blue sky peeking through.
Got new fence and gate plumb and stable on one side of the house in between rain yesterday. Maybe can get the other side today.
Be safe
Have a great day
David Sent from my iPad Air using TractorByNet
/ Good morning!!!! #24,270
Good Afternoon. 1240, mostly cloudy, 88F {98 heat index} with 69% humidity. Forecast high of 89F with 50% chance of a thunderstorm this afternoon, and a low of 72F tonight. It is much cooler today. We hit 102F yesterday. And of course I was in town, where the concrete, asphalt and all those cars just make it that much hotter. Just after midnight we had a pretty good thunderstorm. Or so I hear, I slept through it. We got just under 2 1/2" of rain out of it. I've been doing laundry all morning. Now that it has warmed up, I guess I will switch the Woods RM400 RFM over to the B7500 and do a little mowing. The grass is so high in the backyard if Mocha lays down, I can't see her. But the front yard and over at Mamma's will still be at the front of the Que. Mamma is threatening to get on the her mower if I don't get it done. If her front tire wasn't flat, I would take that threat more seriously.
Hope everyone has a good day.
Larro
/ Good morning!!!! #24,272
72 degrees now with Rain moving in,it looks like it will be with us for a few Days.The tractor is running smooth after Plugs where replaced.The Brake is working good on the new master cylinder.I will have to replace the other Master cylinder down the road but good for now.
/ Good morning!!!! #24,273
Well, an interesting day for sure. Pilots on the grill portion of the kitchen range were out. That is common for the rear burner but not the front, so after breakfast I decided to check the LP tank. Gauge shows below zero. :( just topped off in Feb so no way it should be empty. Guessing we have a leak. Checked and found two rusted areas on the piping. Plumber coming tomorrow to do a pressure test and temp setup using gas bottles. Fortunately I have a 40 and two 20s standing by. Apparently, this pipe has a problem in our climate, this is 2nd leak in 7 years. This is the green coated steel pipe. Am considering taking this opportunity to switch out tanks and suppliers, will find out more Fri morning.
/ Good morning!!!! #24,274
2014-09-04, 0340
52 right now...weather underground says fog, but not around here. High to in the mid 80's...
/ Good morning!!!! #24,275
back in PA to clean up after the movers. Horrible drive up here, 9.5 hours thanks to a bus being pulled by a wrecker catching fire in the Balto tunnel, shutting it down totally. Spent over an hour sitting in the sun,and then inching through the tunnel. A bit claustrophobic
funny, I was thinking the same thing about asking about David/MF and here three others are too.
I think David needs all the support we can give him. I hope I didn't insult him by suggesting he sell his Harley...
we are all just trying to help. And I waved again David going past your exit.
am in a lot of pain from the accumulated everything, plus that drive. Neck is just killing me below where they fused the three vertebrae. Just like the surgeon said it would...impossible to wear a soft collar on a hot day; even my back belt keeps the heat in. I have plenty of pain meds but am doing my best to stay away from them. But I think this morning I may have to find a little white pill of something.
I'm headed to Florida where Larro is opening up his Fountain of Youth Hotel. Going to check in for a while...of course, a few of you might be there too...:D
it's one thing to get old. It's another thing to get old and hurt. I need to work on the latter, though considering I've been going 12 hours a day for six weeks, perhaps no wonder I hurt.
ok, enough moaning and groaning, doc appt this morning then Uship trucker comes for the second and last load of tractors, UTV, golf cart, etc. The golf cart's battery bank has died from lack of use, so that should be fun getting on the trailer. Need to pull the disconnect lever somewhere, and maybe I'll pull it up with the Kubota RTV400. And I sure hope my little tractor starts after sitting in there so long, piled with boxes, the indignity of it all...
/ Good morning!!!! #24,276
55 degrees and heading into the mid 80’s and going to be a clear day.
/ Good morning!!!! #24,277
69 this morning high of 85 later today with a chance of storms in the afternoon. There are some hints of a major cool down coming by next weekend not the upcoming but the next one. In some areas will feel like winter. Maybe highs here only in the 50s
Drew age gives us more wisdom but more aches and pains as well. We tend to get frustrated when things do not go right ie traffic jambs and pains that used to be a nuscienance are magnified. One needs to slow down and not try to cram to much into one day. Please take care of yourself.
MossFlower needs support and prayer and lots of it to get thru these dark times in his life. I'm sure everyone here wishes him the best and will listen to him anytime he needs them to. God bless you David
/ Good morning!!!! #24,278
Partly cloudy and 64F here @ 05:00 ... heading up to a high of 87F today.
Wife just got up and was squeakin' about the place being a meat locker. Turns out the AC got left on all night and it was 64 inside the house too ... feels fine to me ... :D
Looks like I've rolled over to a daytime schedule for the moment ...
Got the shielding gas picked up yesterday, along with the resistors to (hopefully) repair the plasma cutter ... .5 Ohm rated for 50 watts (the originals were only 10 watts) with 1% tolerance. They look nice ... big gold anodized heatsinks on 'em ... lol ...
Dave ... the guy at the electronics recommended Easy Braid, with a "Here ... you'll need this ..." :thumbsup:
Also got the names of a couple of local firms - including one within a couple miles of the house - that do board-level component replacement if I elect to go that route.
Finished sorting out all the wiring on the west wall. Got the holes drilled and the vise & stand bolted down to the floor up in the shed. Got the case for the Sawzall cleaned up, including cleaning the rust off of the blades (which were then oiled and bagged), ... also spent some time putting tools and other stuff away. Might try to get all the fasteners and small parts on the back bench put away today. Would be nice to have that cleared off.
Have a friend and fellow TBN member coming over later today to put another set of eyes on this 100A panel I installed, just to make sure there's nothing obviously wrong in what I did. One thing that has me perplexed is that there was no equipment ground bar included with it ... just a snotload of holes in the neutral bar.
The lawn still hasn't been mowed ... might be good to get that done by 14:00 or so, before it gets really warm out there.
Hope everyone has a good and productive day.
/ Good morning!!!! #24,279
Probably more than three ... ;)
Given your intent (to help) I rather doubt it. Sometimes conditions in life change, and ya just gotta do what ya gotta do.
Exactly.
I hear ya ... I've got something out of alignment in the middle of my back ... if I stand for any length of time (5 minutes) it feels like I'm being stabbed with a big metal poker. Need to go see the chiro and have him put the kung-fu whup on it. I'm way overdue ...
Perhaps not ... ;)
You're probably far better off remaining active (even if overly so) than being sedentary tho' ...
/ Good morning!!!! #24,280
Drinking first cup of coffee. 59° with clear skies this morning. Heading to 86° with lots of sun and humidity. Lawn did not get cut yesterday. Wife and I found other projects that needed to done first. I need to get it done today or will have to get rotary cutter out. Weather reports show that it's going to cool off after Friday. That should slow lawn growth down.
MossFlower, hope you are being able to get your problems straightened out soon.
Drew, glad things are finally coming to a close and you can settle down in your new place.
2016 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2016 UTILITY VS2RA...
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
2007 Sterling L7500 Series 18FT Flatbed Truck (A59230)
2007 Sterling...
2025 Swict 66in Bucket Skid Steer Attachment (A59228)
2025 Swict 66in...
2020 BOBCAT E55 EXCAVATOR (A59823)
2020 BOBCAT E55...
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Mechanics Truck (A59230)
2016 Ford F-550...
