Good morning!!!!
   / Good morning!!!! #199,361
Good Morning
31° and mostly cloudy, high of 49 forecast, and the clouds will persist, but not yield any rain.
Yesterday was reasonably productive, got the timer installed and setup for the hot water recirculation, seems to work well.
Made a HD run with the KubVan to pick up some T-111 to make new doors for a storage shed. Also some PT 2x4’s and Azek trim. Continued to clean up the shop, making progress on many fronts.
Airport Authority meeting was in eventful, we made the decision to raise the rents 3.4% to follow the CPI for our region. it’s always a hard decision, but grants and rent are our only sources of income, and we continually maintain and improve the airports, and those costs aren’t static.
Today, I’ll likely build the shed doors, install an outlet or two that the wife has decided she needed, and see what else pops up.
   / Good morning!!!! #199,362
I have Don's old electric splitter. It works OK. I am bad about not splitting wood while it is green because I usually only take down oaks that have died. The big rounds are tough to split. You can cut a notch with a chain saw to help. Not sure how yardmax 6.5 is getting the extra power, because these are mostly the same splitter. It would need a bigger diameter ram, or higher hydraulic pressure for the extra power. Still, I would choose it for just the small price difference.
Buppies, sad day for worker and his family. Condolences.
Off to the hospital.
   / Good morning!!!! #199,364
Morning all, 37 up to 50 and cloudy, dry.
Well, old car pickup did not happen yesterday, it only takes two companies going back and forth to mess up a schedule.
Will retry for tomorrow.
Taking wife to a place she wanted to try this weekend for her birthday.
Today we hopefully pick up her new car. Need to cut the check later.
Thomas - Brother has had EKG, stents, all kinds of medicine, he tries to exercise everyday, but he is always tired and they don't know why.
Sorry about the fall Buppies, hope you didn't get too hurt. Prayers to your employees family, so young.
I had a large area of bamboo when I bought the house. Why I got the brush cutter. Took many hours to get it cut down, then spray and cutting for the next two years. When I got the tractor, used the backhoe to rip out the last roots. Nasty stuff. Neighbor has a whole area of bamboo on the road, separated from me by the roadway.
Mostly, can't fix old splitter with new hose or pump as needed?
Good luck on driving test L4N!
Be well,
   / Good morning!!!! #199,365
Good evening all. 57ºF for the start, overcast, moderate breeze. Got windy, brisk gusts, Sky cleared off, and high temp was 73ºF. Made coffee to start day, Men's meeting, then bike ride, wind made it harder, Then lunch, then nap, then some wood splitting, my Earthquake splitter start pouring out hydraulic oil, so sure it is dead :(. Ryobi has an electric 5 ton for $300 and yardmax 6.5 ton for $310, thoughts? I split up to a cord of wood a year. Also need to replace Trolling motor batteries.
*snipped for space*
Mostly, sorry about your luck with the splitter. My uncle has one of the electric 5 tons and he enjoys it. I don't know if I'd like to split a cord of wood with it, but for that price I can see why it's attractive.
Did you have the trolling motor batteries on a trickle charger? That always seems to work for my father, I'm fairly confident he still has the original battery and it's been 5+ years now.
Best of luck!
   / Good morning!!!! #199,366
Morning all;
It is going to be a fairly relaxed day today. Got to call the tractor dealership and see when my new rear tires will be in.
And then putter with all the settings in my wife's new car, there are a lot of them to set and or reset.
2025 Equinox EV;
The entry and exit is much more comfortable then her little Jeep Compass was and the ride is even pretty decent considering the 21" 275/40r21 tires have 41 PSI in them. Nice power and driveability so far.
On the drive from the dealership to home it averaged 2.6 miles per Kwh. Which supposedly converts to 87.63 MPGe. In our case I'm at close to $0.20 per kwh
   / Good morning!!!! #199,367
Morning all;
2025 Equinox EV;
Looks nice inside. Thanks for sharing the pictures! I find that marketing materials can be hard to interpret some times.
That m/kWh number seems on the low side, given other EVs today. I would be interested in if/how it changes as you and your wife drive it more.
All the best,
Peter
   / Good morning!!!! #199,368
69°F and 1.86 inches rain. Looks like today will be another wet one.
An inside day I’m sure
Hosting H&F this afternoon. Coconut curry chicken on the menu.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #199,370
David, I keep thinking of the jungle you are trying to mow. Wonder if you might be better hiring a company to bush mow it for you, beat it back to a level
where your equipment is sized for it. Honestly looks like you are trying to do too much though I guess if you go super slowly it will digest all that brush.
locally I have two friends who have inherited properties where the prior owner planted bamboo. Now illegal due to invasive species, the bamboo grows so closely together even the deer can't fit through there. Sure does make a sight block though, even in winter.
Drew, I sorta agree. Neighbor rear of has numerous clumps of overgrown bamboo and other things. She is in process of clearing much of it. Excavator type machine with hydraulic mulching head. Told me it was $1500 for 8 hour day. Didn’t ask, but believe the guy is a family friend. He doesn’t work there every day.
As for mine, a the cumulative results of various factors. That area of tall guinea grass near the road is only area I’ve never completely mowed before. It was part of the area I rented to potato farmer. He left it much rougher than I realized and this last year or so the guinea grass has taken over. When it started I didn’t have operational rotary mower and my tractor being down almost a year surely didn’t help.
That area I got stuck last week used to get mowed until I let the farmer plant some sort of Mexican sunflower. Over the years since I managed to eliminate most of it, contributing to demise of my Rhino mower. This year, it took advantage. Likely never get it eliminated as it is down in an area I’ll never get, even with big equipment, as it reseeds.
I need more patience. It has been so rainy and wet that I am not giving enough time to dry out and then when things are going well i get carried away. I’ll win, but over time. 😁
   / Good morning!!!! #199,371
Got my stove putting out some warm heat. It is run on natural gas nowadays. Insurance wanted to raise rate to much to keep using it with wood. Plus we were traveling south for many years.
Sure feels good on a cold damp day.
   / Good morning!!!! #199,372
All the best,
Peter
Reading the article was interesting. The Caddy was the closest to what we have. Ours is the dual motored awd with the wide 21" tires.
Also non of our terrain is level it's all rolling hills and our driveway is an energy hog, coming up at 10 mph used more energy then cruising at 55mph.
Per that article many of the tested vehicles had much higher m/kwh then the GM's.
   / Good morning!!!! #199,373
Any chance of getting permission for a controlled burn?
   / Good morning!!!! #199,374
Ron curious where you went when you went south for Winter?
   / Good morning!!!! #199,375
47deg
Just a chilly overcast day.
I spent morning going thru a stack of paper, stuff that comes in and I didn't want to deal with at the time, so it goes on the pile. most of the pile ended up being either shreded, or thrown in recycle. Unfortunately we are still on a burn ban or i would have a fire going outside and getting rid of some of it that way.
Wanted to clean garage, but haven't gotten to it yet.
   / Good morning!!!! #199,377
Lou, I'm sure the high tire pressure is to max out mpg but I'd try softening that a bit.
EVs are much heavier, likely the reason but I think tires over 20 inches usually give you so little sidewall
they are vulnerable to potholes.
young man finishing up with my car. Meanwhile I loaded driveway scraper onto trailer and will take it to my stepbrother two miles away
tomorrow morning. Since I'm giving the Gravely away, nothing to pull scraper with and my stepbrother has a gravel driveway it works well with.
and now, finally, drum roll, enough room to put car in garage.
   / Good morning!!!! #199,378
Went to McAllen TX and Mesa, AZ. During our stays at these places we would travel to other places like CA. We took up to a month travel to and from the 2 main destinations.
   / Good morning!!!! #199,380
Drew, shuffled stuff in my garage and got golf cart where I can take it out the other door.
Was on a throw away spree and filled my trash can, which didn’t get picked up today. Guess they a day behind from Monday. Should be able to get car in also.
Got rid of 1 stack of papers in office. Shredded a bunch.
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
(1) UNUSED 31" X 8 MM EXCAVATOR TRACK W/ PIN (A60432)
(1) UNUSED 31" X 8...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2017 FREIGHTLINER...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
