33F with light snow @ 14:30, might head up another degree or two. High today was 36F, probably at midnight.
Was snowing hard this morning when I got up to chase the cat out of the bedroom, ground was completely covered. Most of that has melted off at this point though.
Productive evening working on the wiring in the garage.
Got the 12" of wire that was hanging out where the two runs of conduit come together stuffed into the run along the wall and the two sections connected and tightened up. That was a challenge as I couldn't get the ladder as close to where they joined as I would have liked due to the workbench along the north wall.
After that I got a measurement for the down leg running to the box on the wall by the drill press and got that cut with the tubing cutter.
Then fitted a 90 elbow on the end of that and put it in place and climbed up on the short stepladder that was sitting on top of the workbench and got a measurement for the short section that connected the conduit run on the north wall to down leg and got that cut with the tubing cutter.
Once that was done I fed all the wire through that short section, the 90 elbow, and the down leg into the electrical box.
Then got the backing plate for the 2nd electrical box put up on the wall where it goes and got a measurement for the section of conduit between the boxes and got that cut with the tubing cutter and got the 110v wiring run through it to the 2nd box.
Was getting close to 01:00 at that point and my forearm was cramping up from gripping the conduit to cut it with the tubing cutter so I called it a day.
Still have one more box for 110v outlets to install, along with the 110/220v box for the power for the Unisaw. May work on that tomorrow when temps warm back up to the 50's (easier to heat the garage)
Woman was just asking if I was planning to work on installing the new utility tub in the laundry room today. Told Her that installing that was probably going to put the clothes washer out of service for several days since the plumbing in there needs some work done on it.
A prospect She didn't seem entirely pleased about ... so I may be off the hook on that ... at least for the time being ...
Not sure what I'll get into the rest of today, no shortage of possibilities though.
Indoor plants need watered.
I could stand a haircut.
Hope everyone is having a decent Sunday ...
