Good morning!!!!
   / Good morning!!!! #142,281
Something else I noticed yesterday.
The premium for Medicare Part B went up almost 15%.
Anybody else notice that?
Yep, wife did...
Since I'm still working, and we both have company insurance, I don't use Medicare B. Wife elected to do so
   / Good morning!!!! #142,283
Yep, I got my notice of the new rates yesterday. I wondered if everyone else was hit the same way.
   / Good morning!!!! #142,285
My healthcare plan went down about 30 bucks a month. I had to triple check. It must be that once in a lifetime special.
And in six months, I get to kick another kid to the curb, and it is just me and the SO. So there is hundreds of dollars more a month in the kitty.
Life is grand!
   / Good morning!!!! #142,286
Not sure what today will bring, might tinker in the shop for a while, I have to go sign some checks at the airport, might be an excuse to take the little plane out for a neighborhood tour.
Not sure if I've told this or not, but a buddy's dad had 3 fabric planes. Buddy and I both worked in the heat back in the 80's. He'd call and say meet at the grass strip runway hangar after 5pm. Whoever got there first would start pre-flighting. We'd usually take the Cub, or sometimes the Super Cub, just to go on a 3K foot altitude quick jaunt....with the entry door window in the up position, so we could cool off. Man o man, did that feel good. 80mph air conditioning could cool you down quickly. I miss that. Boy, were we spoiled.
Good afternoon. We escaped frost by a smidgen last night, thought I would warm up by cutting brambles with my ancient, yet still very useful, billhook.
The porridge powered hand tools of years gone by still appeal to me on a cold winter's day. Ironic really as yesterday I was sucking petrol (gas) out of the brush cutter, water pump and generator. They don't use that much fuel and at times can be unused for months, so decided to pay a bit more and run them in future on Alkylate. The dregs of old fuel will be used up in my Husky chainsaw, then once that has gone it too can look forward to drinking Aspen 2 stroke next year.
Wng, our Christmas tree options are also limited this year. I half heartedly suggested one to my wife that had no branches on one side. She surprised me by saying it is perfect, fits flat against the bookcases and leave plenty of room to walk past. :)
I can just see the Vikings trudging across the hills with some of those. I like the good idea for a 1 sided tree usage.
Warm today. 86F running A/C. Cold front coming. Need to bring bales up to front area to load. (with tractor)
Prayers for Topps and Bupps. You guys get well....and for the rest of our team.
Rich, thanks for sharing. I have my wife listening while I read your drama aloud to her.
TxDon and Caren, sorry about Gray2. There is a male cat hanging out around here if you want me to trap him for you, let me know. He's already full size.
Miller Roughneck 1e saga. So it was given to me, with the fan shroud off of the Kohler K301. It has no spark, so I need to get the flywheel off....UHGH. Both holes for attaching a puller were stripped out. 1 of them had a helicoil, but too loose to grip a bolt. I watched Taryl's video of getting flywheels off. He had about 5 engines where he used a pry bar, and hit the crank with a hammer. So I put the nut back on the threaded crank end, and tried it with my 5lb copper hammer. Nope. I put 2 opposed prybars, using a ratchet strap wrench to apply pressure while I banged it. Nope. Got my propane torch out and applied a bit of heat. Not just Nope, but I broke off the 5/8" male threads on the end of the crankshaft. Material is very grainy, like maybe cast steel, possibly cast iron. Sure didn't take much abuse. I found a video online where the same exact thing happened to a small engine mechanic, and he just drilled out the end and used a 1/2" diameter bolt to retain the flywheel. It has a taper with a keyway....I was pretty dejected/mad and at this point, it was Kyle vs the Flywheel. At first, I didn't figure my 3 fingered flywheel puller would fit so I didn't even get it out, because this flywheel is about 10"+ in diameter....but I got it out and it just barely got a grip over the teeth of the flywheel's perimeter (electric start). Maybe just holding on each finger with about .100" (2.5mm). I had to drill a new centerdrill hole in the end, and managed to get it way off of centerline...did I mention there is a frame member bar in my way, making it hard to get a good strike with the hammer, or keeping the drill straight? I got the puller on, tightened the pry bar ratchet to banjo string tight, applied more heat, tighted the $|-|it out of the puller, and with the puller's threaded shaft sticking out about an inch past the frame, I gave it a big bang, and the whole mess came crashing down. Puller, pry bars, ratchet strap, flywheel, all on the floor. Finally. I worked in a small engine shop my teen years, and I've never had one that stuck. I pulled the head off, and plenty of carbon at the top of the cylinder as expected. No gouges in cylinder wall, but it is like a #2 finish glass smooth. Remember it has a lot of blowby. I'm going to get out my dial bore gage and see what it measures. If it isn't too bad, I might just order a set of rings and run a ball hone in it. It will be a pain to remove from welder, as there is another flywheel/fan on the back of the motor attaching it to the welder end....
   / Good morning!!!! #142,287
   / Good morning!!!! #142,288
Thanks but no thanks. The best place for cats is on the farm where they can roam and hunt. We moved with the pets that adopted us on the farm but when they are gone we will not be replacing them.
   / Good morning!!!! #142,289
Need to give Rich a Cha Ching for the Ultrasonic Cleaner. I got the 10L one. Mostly because I have a cheap streak at times. It was $129 one day last week. It will do what I want. Did a pair of Channel Locs that were left out in the grass for awhile. It did not take all the rust off. But they do work now.
Oh, I wonder if one would free up an adjustable wrench.
   / Good morning!!!! #142,290
Here's the serial number so I can stay on Rich's good side.
   / Good morning!!!! #142,291
Unplanned crank modification....now to check why no spark, and a host of measurements.
Reason why previous couldn't get flywheel off.
   / Good morning!!!! #142,292
33 high of 51 high wind watch tonight
Backed over mail box last night then on the way home a car and I hit no one hurt. Still feel poorly
Surgery moved up to December 17
   / Good morning!!!! #142,293
I hope you feel better Buppies. I’m kinda in you’re boat, waiting on possibly more surgery, threw up my lunch this afternoon. Legs are weak, I think it may be the Bactrim causing some of it. Gonna lay off until I can reach a doctor.
My surgery leg is feeling much better.
Hope you all have a good evening.
   / Good morning!!!! #142,295
Got my free tote. In decent shape.
Unfortunately that trip to significantly longer than anticipated. Sophie warned me
Paul (driver) is quite the talker. Additionally, the tote person grows mushrooms and took great pride in giving us a tour and awesome info on her operation. Very interesting. She also gave each of us 2 containers of mushrooms, shiitake and sakuratake
No time left for greenhouse
I’m making roasted potatoes in air fryer. Been marinating all day
   / Good morning!!!! #142,296
I'm really sorry you guys are feeling crummy. More prayers.
   / Good morning!!!! #142,297
About how much snow do you get each?
Usually around 6-10". 4" is a pita. I gotta keep my place clean for emergency services, so I pretty much have to plow every day.
Tonight we will be getting snow after midnight then changing to freezing rain, then to rain with high winds. :mad:
The only thing I hate about winter up here is the dam freezing rain. But it is better than Toronto.
   / Good morning!!!! #142,298
L4N - seems like you are getting enough snow for everyone on the list.
We should get about two or three good dumps this winter. With all the moisture in the air the first big one will probably be heavy and wet. Good for snowball fights. :D
   / Good morning!!!! #142,299
Case of Constant Doyle Perry Mason Bette Davis wonderful actress destroys Burger as well as Perry
   / Good morning!!!! #142,300
Snow what’s that 70 degrees tomorrow
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
2015 CATERPILLAR 953D CRAWLER LOADER (A60429)
2015 CATERPILLAR...
2019 CHEVROLET SILVERADO LD CREW CAB TRUCK (A59823)
2019 CHEVROLET...
206320 (A57192)
206320 (A57192)
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
