Good morning!!!!
/ Good morning!!!! #132,441
42F clear sky upper 60's for high t shirt weather. :)
Bedroom window was open last night for the fresh air in which very little air was allow in because both kitten sat on window sill,early felt paw lightly pulling on blanket than love push to the face nope it wasn't the Mrs.,one of kitten want under blanket than curl up next to me purr to day break than turkeys started gobbling...not much sleep for me this morning but it was worth it.
Ha!
Cats are something. Here is ours.
He may be a tiny bit spoiled. He only sleeps on my wife’s side of the bed.
MoKelly
/ Good morning!!!! #132,442
I was thinking roy's idea of adjustable drop hitch.
Get a can of nice shiny CC yellow spray paint, scrape off all that nice new
paint around the hitch, and weld this on:
That's a lot heavier duty then one would ever need with a lawn tractor!!
Good suggestion though, Drew!
Deere didn't offer any kind of hitch, but a little internet search, I found one on eBay...even painted Deere green!
The rear "bumper" of a Z9xx series ZTR has two holes already drilled....good thing, since the bumper is pretty heavy duty
/ Good morning!!!! #132,443
Good Morning!!!! 57F @ 4:15AM. Abundant sunshine. High around 85F. Winds NW at 15 to 25 mph. Winds could occasionally gust over 40 mph.
The Fire Weather Alert has been escalated to a Red Flag Warning starting at 10AM, lasting through Tuesday.
Red Wing Blackbirds are a sure sign of summer around here, Ron, but even with the hot temps, I haven't spotted any yet. Good to see you posting again.
Got an early start on the mowing yesterday and got the upper meadow done. Forgot all about the old motorcycle tires I'd left out there, which the tall grass hid perfectly. The flail mower knew just where to look, though, and gobbled one up like a rooster on a June bug. Love the way all you do shut down the PTO is mash down on the button, as the tire jammed the rotor and the belts started screaming. Used a big pipe wrench to reverse the rotor and unwind the tire, and decided it was as good a time as any to break for lunch. It was good timing for the FedEx guy to drop off the front differential.
Tried a new pattern this year that kept the tractor pointed more directly up the hill, but that still wasn't enough to get all of the ground under the trees done. It gets steeper toward the right side of the photo, and when it gets to the point that the wheels turn and the tractor doesn't go, it's time to quit. Still plenty left to do, so I'll be out there again early this morning, but will probably quit when the red flag goes up.
Hope everyone enjoys the rest of their weekend!
/ Good morning!!!! #132,444
Ron, GOOD TO SEE YOU!!!
/ Good morning!!!! #132,445
Great idea, Drew. I'd be tempted, if I was gonna weld on my new tractor, to weld one of these on. Then you could put a lot of different things on the back.
/ Good morning!!!! #132,446
Good morning, low was 36 and high will be 59°F. Wind NNW 4 mph. Mix of sun and cloud. 30% chance of rain showers or flurries. It is going to be a wet week.
The part time guy at the dump tried to give me a hard time over lifting the stove out of the trailer. Told him it was my trailer and I would accept all responsibility for the trailer. He lifted it out. I will wait until Tuesday and get the full time guy to lift the mower.
Jobs for today, put a level on the back hoe. I've got one of those screw on R-V levels that I am putting on the control station on the BH so when I put the stabilizers down I can see when she sits level.
Welcome back Ron! Nice shot of the Red Winged Black Bird.
On the ZTR I think I would weld on a 2" receiver and go for the drop hitch, that would add an extra foot to your drawbar length and make backing up the implement a bit easier. Longer distance from pivot point to axle makes for easier backing up.
Have a safe day all
/ Good morning!!!! #132,447
my understanding is that zero turn hydraulic motors are not designed to pull heavier loads
that a garden tractor would have no problems with. So no need to go heavy duty since you don't need
heavy duty from a pulling standpoint. This looks like a fun welding project where you could do the whole thing from scratch with
left over shop materials.
If I had it, I'd pull a cart with something else but today most of us have gotten rid of conventional garden tractors.
Why those old Craftsman GTs can be nice to own. Or a larger Wheel Horse, Bolens or Simplicity. And for sure a shaft drive Cub Cadet.
But for mowing lawn, there's seems no equal today for a commercial zero turn.
I gave my Gravely 8199G with 23hp Vanguard to a close friend locally. As much as I love that machine, and did a frame up restoration on it, without
power steering it's too hard on me. Once I got the JD X750 I realized how comfortable mowing could be. That sold with the farm.
So my orientation is to a 5 series mower where
hydraulic steering is first offered. Would be nice to find a used one, some of the older 3 series had power steering also.
Zero turns are dangerous on wet slopes, we all know that and the steerable front end and grippier tread tires of the larger Cub Cadet zero turns
with steering wheels apparently add a lot more grip. And RS's mower sure doesn't look like any MTD product...seems positioned between Prosumer and Commercial.
I need power/hydraulic steering so the cost goes up thousands of dollars for that, because you only get it on higher line models.
I have zero desire to go zero turn fast, would rather roll along comfortably and smell the roses.
Now that my shoulder is done, that hurdle to mower use is done.
Well, not at the moment, arm doesn't work yet at all but with a smile let's say I'm cautiously optimistic.
So I'm spending a little time on CraigsList looking at used equipment, mowers see what's out there. Less than I thought actually.
/ Good morning!!!! #132,448
Front mount mowers such as the Kabuta F series, NH and Deere have them also along with Toro and others.
/ Good morning!!!! #132,449
Yep, you're right Drew...
ZTR's are not designed for towing. But, as long as one uses a degree of common sense with what they tow, shouldn't be a problem. I have two towable implements I tow...the aerator that's been the topic of multiple posts, and a lawn roller that has to be filled with water for ballast. I've used both implements for 3-4 years now...only use 'em once a season
I've considered getting a towable spreader, but if I do, I'll most likely tow it with the Gator.
Speaking of the Gator...one thing I forgot to order yesterday was the 10 amp in-line fuse for the LED work lights....probably should have just stopped by Home Depot or Lowes in Lebanon (NH) since I pass by there every day
/ Good morning!!!! #132,450
Good afternoon, I thought I would have all day to play outside, however rain came sooner than expected. At least I got out for a couple of hours with the brush cutter and made an impression on some unwanted weeds and rushes.
Thomas, 9 wheelbarrows is a lot of kindling at one go, how is your arm today ?
Ron, great to see you back !
We had frost again last night, the met office says April was the coldest in many places of the UK for 50 years and this weekend could be a record breaker. Even so, the spring flowers and trees are doing well.
Unlike some places we don't have vast carpets of bluebells, all we have are small pockets that seem to favour the shade at the bottom of the replanted hedgerows. There are not many, but anything that confirms winter really is over is most welcome.
/ Good morning!!!! #132,451
Howdy Ron! Always liked red wing blackbirds, or baltimore orioles, or whatever they are.
Daughter's prom went well. Made it home safely before midnight.
Eric, nice bluebells.
Even though the small area I tilled was 10" deep mud, I went ahead and planted my tomato plants. I hope they don't drown like they did when Hurricane Harvey hit.
Starting to think about another used car for commuting.
Prayers for our team and country.
/ Good morning!!!! #132,452
74 and partly cloudy @ 12:00, heading up to a high of 80F. Should be a beautiful day ... but somewhat unfortunate that my appointment for second vaccine shot happens to be in the middle of the afternoon. Just happy to get it though.
I see there is one suet feeder around back that needs filled, so that's on the list for the day.
Downstairs fish did not get fed yesterday, so it is as well.
Calling for rain here next three days (Mon/Tue/Wed) ... so certainly seems like mowing should be on the list for today.
Need to clean the aerator and inspect it.
Was also hoping to get the back patio cleaned off and that piece of FRP brought inside.
May have another piece of FRP that can be put in the bottom of the dump cart to keep it from getting beat up.
Hope everyone has an enjoyable, productive, and safe Sunday ... (y)
/ Good morning!!!! #132,453
Why not just bend the drawbar straight or make a new one? Seems like an easier fix, and addresses the problem directly.
1. It's a new item, and still under warranty.
2. A straight drawbar may not leave the drawbar sitting completely level (although I suspect it would be close enough to handle the issue I'm having)
3. Probably doesn't handle the issue I will likely have with other implements (dethatcher, tow-behind spreader) that I'll be dragging behind it.
/ Good morning!!!! #132,454
I think I'd try flipping over the aerator's drawbar (if that's possible).
It's really not - IIRC (which itself is questionable ... :LOL:) there is a slot in the drawbar which the lever that raises and lowers the wheels goes through.
Unfortunately the slot is not in the center of the drawbar IIRC - therefore it's non-symmetrical - and the bolt holes for the drawbar would not line up with their holes, if one had the slot for the lever lined up properly.
Need to verify that though.
If that isn't feasible, I'd look around for a drop hitch to rig to the mower.
That's the direction I'm leaning.
Even if you can't find one, shouldn't be too difficult to fabricate something
Yup ... doesn't have to be real heavy-duty ... Cub's tow capacity is only rated for 250 lbs. IIRC.
/ Good morning!!!! #132,455
(y)
Yeah ... something along those lines ... but I'll make it bolt-on (want to avoid welding on it ... or scraping off any that shinny new paint ;))
/ Good morning!!!! #132,456
Poured first cup of coffee. 64° with mostly clear skies. Heading to 81° with mix of sun and clouds. Cleaned up a few little items around yard yesterday. Must have over done it. Have aches and pains this morning.
Hope you feel better and the pain goes away soon.
Garden pond cleaning this morning. Lot of maple helicopters have fallen into pond.
Haven't seen any of those falling here yet ... but I think we're real close. Today could be the day where they start coming down.
Then conserve energy and watch some NASCAR in afternoon.
Enjoy the NASCAR ... and thanks for the RWBB picture ...
Glad to have you back ... (y)
/ Good morning!!!! #132,457
66°F and .12 inches rain.
Looking like a good day to hang some electrical boxes.
Very enjoyable evening out with friends. Hard to believe it had been more than 2 years since last time. One of those interesting American couples. Mo is an Iranian immigrant who landed in Ca. Leslie of mixed Japanese heritage with family ties to Hilo that grew up in CA. Both are LA government retirees. They bought their Hilo couple a few years back but soon realized they wanted to be closer to their grown children back in LA. Kept the condo to vacation here.
Prayers for all
Be safe
Have a great day
/ Good morning!!!! #132,458
Poured first cup of coffee. 64° with mostly clear skies. Heading to 81° with mix of sun and clouds. Cleaned up a few little items around yard yesterday. Must have over done it. Have aches and pains this morning. Garden pond cleaning this morning. Lot of maple helicopters have fallen into pond. Then conserve energy and watch some NASCAR in afternoon.
Prayers and best wishes for everyone.
Good Morning All.
Yeaaaaaa, you’re back 🤙🤙🤙
/ Good morning!!!! #132,459
Well, rain wasn't in the forecast, but that's what happening right now...cool clammy weather!
But, I did get the lawn mowed! Some areas didn't need it, so I didn't mow those spots.
Had a couple beers and watching YouTube "Good Works Tractors" videos. He's primarily a used Deere dealer, but has videos that apply to any brand tractor.
Thinking about a nap...in fact, that's inevitable on a rainy Sunday afternoon!
/ Good morning!!!! #132,460
Afternoon all! 70 here with rain.
I was able to get the snow blower off of the riding mower at the apartment house and put on the mower.
I also did some digging in the back yard here and got 3 small stumps pulled out of the ground. Made a heck of a mess when I used the tractor to bring them to the property line. Still way to wet for tractor work! Big ruts that will have to be fixed now. Oh well.
Hope everyone stays safe and healthy!
2023 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A56858)
2023 GMC Sierra...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2017 Caterpillar 249D Compact Track Loader Skid Steer (A59228)
2017 Caterpillar...
2017 Ford Expedition SUV (A59231)
2017 Ford...
2016 INTERNATIONAL PROSTAR (A59904)
2016 INTERNATIONAL...
Boat (A59231)
Boat (A59231)
