Good morning!!!!
/ Good morning!!!! #116,801
I mowed this afternoon, when I was near finished I crossed a small swale on the front by the road at an angle and downhill. Well it high centered on me like a terrapin on a fence post. After thirty seconds of spinning the right front and left rear in a near panic, I remembered the differential lock. Pushed the pedal and backed right up the hill. I’ve had tractors with diff locks for 30-35 years, why I didn’t think of it right away is beyond me.
That happened to me once. I never had to use it before, and took me awhile to think of it.
/ Good morning!!!! #116,802
Got my beer :)
Also got the PTO Driveshaft squared away on the flail mower (you might recall a post about a week ago describing how it wouldn't extend). Ended up rigging a short tow strap to the tractor end...came right off, I greased it up and go to go!
Got gas for the zero-turn and pretty much filled the tank...I'll mow first thing tomorrow (Sunday) morning...maybe the field too.
Only disappointment was a test on our 10kW generator. It started OK...let it run for a few minutes the plugged a drop light in...that was OK, so it's putting out juice. But then it started running rough. This was the first test since last fall...my guess is I forgot to add Stabil and I have bad gas. It holds about 7 gallons...and is full. I added some Stabil and I hope it runs OK tomorrow...otherwise, I'll have to drain the tank and put fresh fuel in it. This is an off-brand genny made in China and sold by a company called Pulsar
/ Good morning!!!! #116,803
Got my beer :)
Roy
I've had the same issue with my generator due to lack of use etc. I use a little Seafoam additive and seems to clear up the
issue after running a little bit with a not critical load on it. Its a task to remember the Stabil when refiling cans.
Just sat down for a beer and a burger! :thumbsup:
Luther
/ Good morning!!!! #116,805
Roy
Luther
We have a big bulk diesel tank but don't want to store large amounts of gasoline .. so I get 2-3 five gallon containers filled about once a month. I started treating all my gasoline with Stabil 360 Marine several years ago. I add 1/2 oz to each 5 gallon container before going into town to fill them. It reduces the effects of ethanol contaminated gasoline and has totally eliminated all fuel related issues with our 2 cycle chain saws, pole saws, brush cutters, blowers, etc. I used to consume more gasoline but .. now our Kubota zero turn .. is diesel. I treat the gasoline, for our Corvette, with the Stabil 360 Marine also.
/ Good morning!!!! #116,806
69F and clear @ 22:00.
Got west planting bed and blueberry bushes watered, MMM deck cleaned off and degreased ... and then re-greased (except for the u-joints on the pto shaft which I need to remember to do tomorrow) old blades taken off, sharpened ones installed, live trap hosed off (but not reset)
Got Menards order placed a little before 13:00 and got an email a little after 14:00 that the order was ready for pick up. Also ordered a Milwaukee jig saw and some blades from Acme Tools which should be here by next Friday.
About that time neighbor showed up, said he hadn't seen me for a while and was wondering if something had happened ... which was funny, 'cause I wondering the same about him ... :laughing: Thought maybe he had headed back down to Texas to visit family again. So we sat around and shot the breeze and worked on solving the world's problems for about an hour or so.
After that I greased the FEL, checked and aired up the tires on the Kubota, and worked on sanding the auger rack some more until The Woman got home. Once she got here I headed off for Harbor Freight and TSC. HF was already closed by the time I got there, so I swung by Autozone on the way over to TSC and picked up a new front wheel bearing for her car. It's starting to growl pretty good ... need to research that, apparently involves some specialized tools to change ... :rolleyes:
Got sunflower seeds at TSC, along with a catnip toy for "the kids", and grabbed 4 Carhardt pocket-tee's (which are currently on sale thru Sept 20th) ... plus got an extra, extra small red harness for The Squeak ... which should be loads of fun.
Noticed there were a couple of birds in the DRST as I was heading out to do the running around so I stopped on the way back in to check it out and it turned out it was a pair of pretty good-sized juvenile blue birds so I let them go.
Hope everyone had a great day ... :thumbsup:
/ Good morning!!!! #116,808
Good evening all. 76F for the start, clear, light breeze. Mostly clear sky, moderate wind with brisk gusts, and high temp was 96F feels like 100F. Bike ride this morning, 5 in group, 57 miles, nice tailwind back to home. Nap after lunch and that was it.
Covid update: Cooke unchanged, Montague 70 confirmed cases, 2 active cases, Grayson 1118 confirmed cases, 74 active cases
Kyle sounds like a nice get together.
RNG medium carbon steel won't fully harden, would require water or oil quench. If properly quenched (most likely water) to promote hardening, I would draw it to a brown color then then air cool
Dennis sorry about shoulder, should you have it looked at?
Drew glad you are getting to socialize some. Would be tough going through your ordeal with no one to talk to face to face mask :)
Randy 7 inches in less than a week is a whole lot of water!
Eric nice looking hay, hope all goes well baling it
Roy hope fuel run goes well
Billy hope your grass dries out
Rick thanks for the sharpener review
Ron your aunt is impressive. neat balloon pic
Don you have cooler mornings than we do. When hunting you chase to pull trigger or not. When fishing, the fish gets the choice
Oldpath Welcome :welcome:
Ted, that is dry! you sound excited to get back on wood projects
RNG Firetruck ready for action!
Jim sorry about your bad experience that sounds like a giant pain for nothing
Dennis you might check and see if seat switch bypass is working or seat switch gone bad
Randy how many times have you used the lock in the past few years?
Roy hope you get genny squared away ok
Luther welcome :welcome:
Rick +1 on marine stabil
prayers for all, especially Drew, Jay/Peg, Kyle's daughter, Mike David(Moss), and country
stay safe and healthy you all
/ Good morning!!!! #116,809
I'm ahead I have 70* at 10:45pm, everything went great til I forgot where I put my hammer after I hit my thumb, can you take a look in your backyard.................
/ Good morning!!!! #116,810
Eric,
Sophie was one of those kids that grew up wearing glasses, then as an adult it was contacts & glasses. Then about 20 years ago Lasik and she was freed. Lasik gave her something called monoview. Far distance in one eye, close in other. Made it interesting taking drivers vision test but otherwise good and they would work together, she could read, do her eyebrows etc and still see good at distance, all without glasses.
Retaining the monovision was part of discussion with the original ophthalmologist and even though the lenses wasn’t stable her vision was same as before that cataract surgery.
No discussion with 2nd ophthalmologist other than him saying he’d anchor the 1st lense if possible and if not replace. He replaced. We assumed everything was already in her record so didn’t question. When Sophie got the card with lense info we noticed it was a different measurement. He stated it was based on some measurement. So once she achieves healing I suspect there will be a discussion. We suspect he may not have honored her desire to retain the monovision and just assumed she’d be OK with glasses. Last appointment he said possibly reading glasses. At this point she isn’t reading, can’t read stuff on the TV and I seriously doubt could pass drivers vision test as she can’t read signs either.
Hood looking hay
/ Good morning!!!! #116,811
This is the wrong time a day for me to post on this thread so I'm not going to, everyone on EST needs to wait 45-ish minutes to start over...............
/ Good morning!!!! #116,812
MG,
Nice ride ... :thumbsup:
... RNG medium carbon steel won't fully harden, would require water or oil quench. If properly quenched (most likely water) to promote hardening, I would draw it to a brown color then then air cool
Wondering if perhaps you might have had some insights on that but wasn't sure ... ;)
As regards your previous question, nope ... haven't checked the voltage at the battery or at the solenoid. Neighbor asked about that today when he was here. I'll check it ... but I have a feeling that juice is not the problem (it's done this before ... and battery is fairly new ...)
/ Good morning!!!! #116,813
Ron, that’s a really blue sky.
Drew, we’ve been watching a bit of Amazon Prime of late. Some strange stuff. Did like the Madame Curie, Radioactive, we watched last night.
Don, so Gray is a meat eater? Hmmmm.
Do you check Afib with your watch? I check every morning. Not that I’m expecting anything. Hope the study gets enough data.
RNG I’d have to say that overall, things have improved for us Apple users. Many years ago I had issues with my primary credit union. They would tweak their system, breaking it on the Mac/Netscape but work on PC/Explorer. I’d notify them, they’d deny, I’d say fine, just close my accounts if you can’t fix it. Two days later it would be fixed. I think eventually they got a better programmer.
Good luck with the emissions struggle.
Been a long time since I sharpened a chainsaw. Used a rattail file.
Jim, that does NOT sound pleasant at all. I have challenges sitting still in the dental chair.
Dennis, sure hope you get some shoulder relief soon.
Your MIL tractors sound a bit frustrating. Hope you find easy solutions.
/ Good morning!!!! #116,814
Great deer photo, Thomas. Wife really liked it.
/ Good morning!!!! #116,815
Welcome to GM.
But for some of us, it’s just dinnertime
/ Good morning!!!! #116,816
Eric,
Hood looking hay
Prayers that her vision comes back enough to read and drive.
I just got in from fixing the plastic hood on my LT180. It had cracked on of the hinge points. The hinge points are down near the exhaust, and they get hot, plus time takes it's toll. Anyway, I marked and drilled to 1/2" holes through the frame, where the pivots are, then I drilled out the green plastic hood with 1/2" holes right through the old pivots. There was some plastic webbing reinforcement that needed to come out too. I got out my flat 1/2" paddle bit and drilled thru (real gently) about halfway from each side, so to keep it from cracking. I temporarily have a 1/2" diameter x 20" round bar of 17-4 stainless (Type 630 for you metric guys) pushed through everything. Because it's right by the muffler, if anyone is reading this, don't use a wooden dowel or anything combustible. I'm going to rig a piece of 1/2" stainless tubing, with some stops on each end, one of which I can remove and pull out the shaft, to take the hood completely off in order to more easily facilitate working on the motor/carb etc. All thread with double nuts on each end will also work well.
Got my 2 pecan trees watered well, and my daughter watered our blueberries (just like rs). Our blueberries have about half the leaves turning brown from the heat I guess. Some new leaves are growing.
I want to make a (don't laugh too hard) 10' long brush killing apparatus, that uses a 2" pvc tube with some drilled holes in it. You wrap it with towels or an old blanket, and use some safety wire to hold it tight to the pipe. Then you pump in your favorite weed killer at a slow rate. Some call it a tampon. :) I will hang it in front of the gator or the tractor's FEL and drive around, applying herbicide to the tall weeds. Mainly johnson grass.
Other than that, it was a 100F day, "feels like" 107F......so I stayed in most of the day.
Oh, my mom had her 91st BD back on the 5th. She's a 1929 model.
/ Good morning!!!! #116,817
My less than planned day went well. Got painting done, both coats just before a light shower.
Got some corn, zucchini, cucumbers, and tomatoes from garden.
Need to figure out when this will be ready
/ Good morning!!!! #116,818
Kyle,
That sounds like quite the wick applicator you contemplating there ... ;)
We're getting quite a bit of new growth on two of the (three) blueberry bushes, although one plant was getting its leaves chewed pretty good by Japanese beetles. That plant is currently the largest and appears to be doing very well. The other one that is doing pretty decent is also a mid-season ripening bush. The one that is not doing very well at all is an early ripening bush ... it appears to be just hanging on. They're all old plants (probably 40+ years) ... so if they can be brought back with the severe pruning we gave them it's all gravy at this point.
The Japanese beetles seem to have subsided now for some reason or another - the beetles seem to have mostly just disappeared ... which is kind of odd, given that we did not trap them this year and haven't ever treated with milky spore (need to do that)
Dunno on your brown leaves ... are these new plants or established ones ?
Glad you were able to get the hood fixed on your LT180 ... :thumbsup:
/ Good morning!!!! #116,819
Kyle,
Both were bought in containers. One was planted last year, one early this year. I have not noticed any bugs on them. I was hoping it was just a transplanting temporary thing.
/ Good morning!!!! #116,820
Very likely it could be ... :thumbsup:
As I understand it, the old roots die off when replanted and new roots have to form and grow for them to establish. I wouldn't expect them to be really well established for at least 3 years or so after being planted ... pinch the blossoms off during that time: you want the plants putting their energy into forming new roots (and stems/bush)
Also, on the one hand, they generally don't like "wet feet" ... but on the other hand, better that they shouldn't lack for moisture while they are trying to get established.
In northern climes, they are said to really flourish with "full sun" ... although our plants here actually did very well for many years planted right next to the east side of the house - maybe 3' from the foundation ... which itself is kinda odd, in that the foundation (solid, poured concrete) probably makes the soil more alkaline (rather than acidic which they prefer)
Another thing I've read is that because they are natively a northern plant, when they are planted in the south they may require some shade ... :confused3:
Blue Diamond 103709 (A53317)
Blue Diamond...
Electric Golf Cart (A56859)
Electric Golf Cart...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
12FT X 20FT STEEL CARPORT (A58214)
12FT X 20FT STEEL...
2014 Top Hat Trailer (A60352)
2014 Top Hat...
5th Wheel Hitch (A59230)
5th Wheel Hitch...
