Good morning!!!!
   / Good morning!!!! #107,041
Today is no work day if it snows here Ram 4500 does not do well here in the snow although what we get is only going to be an inch or less now
Thomas I hate downsizing or talk there of
   / Good morning!!!! #107,043
Another cold morning, forecast is snow on Sunday, average temps until then (40s for high, teens and 20s for low).
   / Good morning!!!! #107,044
Good Morning!!!! 50F @ 7:15AM. Partly cloudy. High 69F. Winds light and variable.
Love the way the plank layup stands out on the end tables, Ted. And the finish brings out the tiger stripe, too.:thumbsup:
You can do pretty much anything with a larger tractor you can with a smaller one, but not the other way around, Thomas. But you can't argue with female "logic", either. Good luck with that one, buddy!:laughing:
Had another go at starting the big trencher after the battery charged overnight, but it only turned over a couple times before we both gave up. Refueled the tractor, then brought the truck around to jump the trencher, and it lit off on the first revolution. Jumping up to the driver's seat, I verified that the only brake is an emergency brake, and it doesn't do much in the way of slowing anything down. And then I noticed that even it idle, the darn thing creeps veeeeery slowly to the rear. Hmmmm, this is going to be interesting. The transmission seems to be hydrostatic, as the rocker throttle doesn't change the RPMs at all. Those are controlled by a hand throttle on the dash: Unscrew it and it will eventually raise the RPMs, and the push button on the end of it doesn't do anything I could find. I could only get the gear shift to move into one of the three locations; every other one just ground with an alarming noise. So off we went, very slowly and carefully, trying to keep the thing on as level a grade as possible. The seat is about six feet up in the air, and that really accentuates sideways motion, making the tip feel far worse than it is. :eek:
First task was to use the front blade to level out the pad for the generator, and with enough experimentation and small cuts, I did get it better. Not perfect by a long shot, and I did use the box blade to get the notches out, but good enough that an inch or two of road base gravel will make up the difference. Then I got it turned 90° and pointed down hill, sheesh, don't kick the shift lever out of gear getting on or off the seat, it's right between your knees! And remember if it does let go, you can power the front blade down and hope it catches something, or drop the big wheel in back and see if that does anything. :confused2: Ah, the joys of homeowner "maintained" equipment! Anyway, took many tries to get the saw lined up with the upper parts of the trenches, but with many hops up and down to run back there to see where it was, all the while leaving enough room for the thing to creep backwards until I could get back to the controls, I got the two trenches cut. Found some more concrete buried in the ground, but aside from a little more lurching and the sound of gravel in the shoot, you'd never know the teeth were cutting it. Hoping I was done, I got it moved back to the end of the extension cord and the battery charger, and got it hooked up again after it shut down.
Then I used the tractor to move the spoils on the surface away from the trenches, first using a hoe to drag them back from the edges. That's when I learned my hoe needs a longer handle, as Mr. Back didn't at all like bending over that far. I also found out that I couldn't get the tractor close enough to use the FEL in some places, so those got hand shoveled. Now I understand why construction workers like to lean on shovels: In my case, it's to let the back relax and not complain quite so loudly. Fortunately, sitting with my feet in the trench and shoveling into the bucket doesn't hurt as much, and I got both trenches cleared out without too much more discomfort. But I also learned that one of them has a three or four foot section that isn't deep enough, caused by the front wheels of the trencher going off the edge of the flat pad down the hill and me not compensating enough by dropping the saw far enough. Not sure if I can get it cleaned up with the mattock or not, and depending on where the trenches ended up, I might need to cut one more short trench anyway. So before today's town run, I'll get the measuring tape and string back out and see where things stand.
Finished up the day clearing out the last forty feet or so of trench out to the solar panel rack. About five feet of that was full of spoil, put there when the trencher drove over it to get off of it. The rest only had a foot or so of loose dirt in it, but for some reason the blocked section had lots of rocks, and they were compacted, and I was glad when that was over with. I really didn't expect to be this far along with the trench clearing, and even if I have to do some touch up work tomorrow, it looks like I'll be plumbing gas line and laying electrical conduit over the weekend. And with no rain in the ten day forecast, I should get a start on the solar panel rack posts, too.
Visiting a new eye doctor this afternoon, and hoping he can figure out something to help me see better. Not looking forward to the dilation, and sitting around in the parking lot with those funny filter lenses stuck in back of my glasses, waiting on the stuff to wear off, though.
Hang in there, gang, Friday's comin'!
   / Good morning!!!! #107,045
Now that thar is sum first class Redneck Ingeneerin', Drew!:thumbsup::laughing:
inspired by my neighbor who had his buddy sit in the FEL on his tractor and push a small hand seeder in front of him. For real.
   / Good morning!!!! #107,047
Good Morning! It's 46° and drizzling rain of and on .. damp and chilly with a 15 mph wind out of the north. I'm doubtful it will get out of the 40's today.
Looks like it will be a great day .. to complete the reassembly of the hydraulic press in the shop.
I bought a set of skid shoes for my LandPride RB3796 rear blade so I'll likely back the tractor into the shop and get them installed. I ordered the missing parts yesterday, to install my hydraulic angle cylinder ... hoping to get parts next week.
RNG .. hope they get your vision issues resolved.
LS .. your tables look great! Nice work.
Drew ... videos of your Red Neck snow blowin' will be .. mandatory!
I got the "Farm Chat" email invite and signed up. Looks like it may have some interesting subject matter.
Hoping everyone has a great "Friday Eve" today.
Prayers to all.
   / Good morning!!!! #107,048
64°F and .46 inches rain.
Hoping for cooperative wx today.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #107,049
Good morning to all! Low of 26 currently, only forecast for a high of 36. Surprisingly, there is a heavy fog outside and a very fine drizzle, but nothing seems to be freezing. I confirmed my outside temp and compared it to the wunderground reading, that one was lower by a degree... strange there is no snow or sleet at the freezing temps.....
Drew, sorry to hear about you winter weather... sure seemed like spring was there already! Do not push the snow blower too hard, you definitely do not want to aggravate your neck pain.
Bruce, mmmmm, coffee cake... a favorite accompaniment to.... well, good coffee :licking:
WNG, you would be all set with your fresh roasted beans if you had some of Mostly s coffee cake....
Today s agenda is taking wifey down to the city for her nail job . Gotta keep her claws in top shape..... they come in handy for that occasional itchy spot I cannot reach:dance1:
Then I get to go to HD or Lowe s to pick up the hinges and metal sheet for the end table doors. I might get a chance to start making the rough cuts for them today. I got a few coats of finish on the tables yesterday, today I will get the final coat on and get them buffed. Here are a few pics of them.
Everyone have a great day!
Very very nice, Ted
   / Good morning!!!! #107,051
I received an email this morning, accepted for voluntary career transition (retirement), last day is March 20, 2020. Lots to do before then, lots to do after.
   / Good morning!!!! #107,053
Whipper’s back seat.
   / Good morning!!!! #107,054
I'vee been following the posts, but have been really busy being a domestic worker, chief cook, bottle washer, and chauffeur for SWMBO. A lot of the posters here are familiar with my current challenges, but sooner or later Wifey will get her strength and range of motion back. For a lot of reasons her broken wrist/arm is mending slower than anticipated. The ice situation here has complicated matters as well. I致e bought more de-icing chemical this Winter than ever before. Hopefully after this 2 day "cold snap" the temperatures will warm over the weekend and allow for more seat time managing the ice. Weather-wise I believe there will (hopefully) be a pattern change midweek next week and there might be a snow bearing coastal storm rather than the mixed precipitation events I've been getting most of this Season.
Hawkeye- Congratulations and good luck.
Don- I like your/Whipper's seat covers. After 10 man-woman hours of detailing my Tundra is still far too trashed for me to consider seat covers. :embarrassed:
I am enjoying all the pictures of wildlife and projects in various stages of development. Thanks for sharing.
My + thoughts, wishes, and prayers for everyone mending, those undergoing and/or having plans for rather unpleasant medical procedures, those under the weather, as well as those ambulatory healthy few.
   / Good morning!!!! #107,055
Congrats
   / Good morning!!!! #107,056
Congrats! Figured out yet what you'll do with all that newfound time?
   / Good morning!!!! #107,058
jbrumbergI'vee been following the posts, but have been really busy being a domestic worker, chief cook, bottle washer, and chauffeur for SWMBO. A lot of the posters here are familiar with my current challenges, but sooner or later Wifey will get her strength and range of motion back. For a lot of reasons her broken wrist/arm is mending slower than anticipated. The ice situation here has complicated matters as well. I致e bought more de-icing chemical this Winter than ever before. Hopefully after this 2 day "cold snap" the temperatures will warm over the weekend and allow for more seat time managing the ice. Weather-wise I believe there will (hopefully) be a pattern change midweek next week and there might be a snow bearing coastal storm rather than the mixed precipitation events I've been getting most of this Season.
Indeed the icy has been issue enough so had throw heavy coating grit driveway and walk usually mid March or so before doing so,heard but yet another icy mix for next week. :rolleyes:
   / Good morning!!!! #107,059
Buppies.
Fingers etc. cross for positive out come tomorrow for you. :thumbsup:
   / Good morning!!!! #107,060
Just got word that my FIL (who was in car accident 8 days ago and is still in ICU) has pneumonia, his oxygen level was 83 and they were suctioning crud out his throat.. he is doing better otherwise. SIL is doing great, started PT.. Thanks for the prayers and positive thoughts.
2015 Ford F-250 Pickup Truck (A59230)
2015 Ford F-250...
2016 Chevrolet Traverse SUV (A59231)
2016 Chevrolet...
2018 INTERNATIONAL LT625 TANDEM 6X4 SLEEPER (A59904)
2018 INTERNATIONAL...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2020 FREIGHTLINER...
403 (A52706)
403 (A52706)
2020 DRAGON ESP...
