fishman
Veteran Member
Welcome back Fishman. I still remember your visit to Jinman痴 place to check out his lake.
Yes, I enjoyed that a lot. Sadly I didn't find out about Jim's cancer fight until it was long over.
Wish I were closer to some of you wood burners.
speaking of burning wood, need to let this pile settle down a little and have a nice bonfire. That pit is full up.
After a lot of fidding, hauling the big jack from one end of the shipping container to the other on the pallet forks, dragging it through the gravel, and swapping shims into and out of the stacks at each corner, I got within 1/16" of level. I was hoping that would make the doors work better, but it didn't help a bit. I can't even get the set on the front of the box to close all the way, and wonder if all that jacking has warped the door frame. Time for more measurements, this time of the door frame diagonals.
As mentioned previously, the laser self levels by manipulating a spinning mirror or prism on top of the unit. The beam can be set to remain stationary, scan in an arc, or to spin full circle, as shown in the video below.
This is today's data sheet; yesterday's was twice as long as the measurements after each adjustment were confounded by the container resting on the gravel base. Once it was up on the piers, the measurements could be used to guide the shim additions and subtractions, and it came down to finding pieces of wood or metal of the correct thickness.
By sheer luck I found missing game cam just inside the woods,that game cam doesn't work anymore from teeth marks.
Took garbage out front for pickup. Looked off to the right and seen this view. Still a lot of leaves to drop.
This just in:
Weather advisory in effect for:
North Bay - Powassan - Mattawa
West Nipissing - French River
Winter Weather Travel Advisory in effect for today and tonight.
Cold westerly flow over the relatively warm waters of Lake Superior is expected to produce isolated snow squalls this afternoon and through tonight. The snow squall bands are expected to shift southward tonight moving out of the region.
Total snowfall accumulations of locally 5 to 10 cm (2-4") are expected by Thursday morning. Areas affected include Highway 69 south of Sudbury, Highway 64 and Highway 17.
Locally heavy snow is possible along with reduced visibilities at times. Falling temperatures tonight may also cause roads to become icy or slippery. Prepare for hazardous driving conditions at times.
I think winter is here.
