Good morning!!!!
   / Good morning!!!! #173,501
As far as drones, I have a DJI Phantom 3 that I have had for many years. It works well, I use an iPad for a video monitor, it attaches to the remote controller.
I was playing with a DJI Mini 3 the other day and it is amazing how far it’s come since mine, the display is integrated into the controller and the airframe is tiny. It’s below the weight that trigger all sorts of regulations, which is a huge consideration.
I might consider upgrading to mini 3 just for the controller. I have to hook my phone to mine.
Just looked, pretty pricy with the display. The pro is over $1k but it senses obstacles.
But you can get an air drop system to carry under 100g.
   / Good morning!!!! #173,502
when I first drove in Popgadget's driveway, I thought
wow, this could be a landing strip here
did not know how true that would be
but just for r/c planes. It's perfect, down to his windsock
looks like I need his help. My favorite girl has a drip.
likely hydraulic oil, unlikely motor oil.
Have now put a white oil diaper underneath and will look carefully in a few days.
Looked underneath, hard for me to do with neck that won't bend..., so I tried taking some pics instead.
That worked better.
so only way to fix this is to get it up on some kind of lift. Sure miss my FEL.
hoping it's a loose line fitting. Hoping it's not a main seal or something serious.
I doubt a five year old Vanguard twin with 200 hours on it is leaking. Maybe.
but the oil stain looked more hydraulic than motor oil.
my favorite girl, have to help her with her drip.
definitely could use a degreasing and a bath
but first some detective work
   / Good morning!!!! #173,503
I got a puddle under the BX front end. I’m not sure if it’s got hydro oil in it, some people put a heavier weight in. It appears the heat in the barn causes it to leak more.
   / Good morning!!!! #173,504
Seems the recent weather is taking a toll on our equipment. That must be it.
I hate it when I find puddles and drips. I hate it more when things just stop working in the middle of a job.
This is not the time of year to be working on equipment, the equipment should be working.
Suns up and out, and I feel the humidity kicking in. Turned on A/C in the Milk House and will remove remaining tools. They are in three different buildings right now. LOL. Sure could use that multi-meter. LOL.
   / Good morning!!!! #173,505
Good Morning!!!! 73F @ 4:00AM. Sunny. Hot. High near 100F. Winds SSW at 5 to 10 mph.
And the heat goes on...
I agree completely with that. When you consider that flow is the mass of the water and pressure is the velocity, it’s like comparing swinging a sledge hammer slowly to a tack hammer really fast. The weight is more useful than the speed for most tasks. After about 1500 psi, look for as much flow as the power system will allow. For a 115v motor, that’s about 2 gpm at best.
It's the same argument old timers make when comparing 45 ACP to 9mm Parabellum, or 7.62 NATO to 5.56. In the videos I linked earlier, the car detailer explains that the pressure rating can be "customized" by choosing orifices of different sizes, and that the sweet spot for automotive cleaning is about 1000 PSI @ 2GPM. For the little Ryobi units selling in the $100-$180 range, that is accomplished with a 2.5 or 3.0 orifice. If you need higher pressures for tough jobs like cleaning off sidewalks or loose paint, you can get a smaller orifice and bump the pressure up by maybe 30%, so that's what Ryobi does to reach 2000 PSI. Amazon sells different tips if you wanna play around with that. Not sure the offer is still good, but a couple weeks ago, Ryobi was offering that pressure washer for about a hundred bux at Home Depot. I bought one, and I really like the way it works. A lot easier to manage due to the wheels, handle, light weight, and small size, too.
Some progress yesterday. Escrow did open, so I was able to setup a wire transfer for the deposit. Also received a Natural Hazards Report, which struck me as a canned version that was not specific for any particular address. It didn't contain any hazards I wasn't aware of, other than three trucking companies that apparently are run out of the driver's house. Or are they bringing hazardous waste home with them? Or is it a case of stupid computer programming?
Also learned that the loan on the house isn't a traditional second mortgage, but is instead a UUC-1, which is a lean against the solar power equipment. In the fine print I found a clause about a lower interest rate for the first 18 months to allow filing for a 30% federal tax credit on the system, and then a higher interest rate if the tax credit isn't applied to the system. From the balance due on the loan it's apparent the tax credit wasn't applied, and the seller failed to disclose that condition. So we're not out of the woods on this deal yet.
A building inspector showed up for the final on the wind damage repairs. That was going fine until he asked to come in the house and verify that smoke detectors were in place. I asked what that had to do with the scope of work, and he explained that has been a requirement in the county for quite a while. I acquiesced under protest; more government overreach. The rest of the inspection went fine.
Got about a half hour of spraying done before the side-by-side overheated, then spent the rest of the morning installing drip tubing back on the house. Got two of the five circuits done, and got a start on a third one. Hardest part was getting some of the fittings disconnected to shorten some of the runs. That half inch drip tube does not want to come out! Was finally able to overcome it with a pair of ViseGrips and a bucket load of elbow grease.
Spent the rest of the day inside unearthing the above info on the new house. Oh, and scheduling a home inspection for Friday. The recommended provider charges a whopping $450 for the service, and I figured if he can do four a day, he'd be knocking down almost a half million a year. Where can I get a job like that?
   / Good morning!!!! #173,506
As is often the case our Western KY drouth is being broken with flooding. Mayfield (Graves County) is warning about washed out roads being underwater and people are still trying to forge these places. Reports of 6-8 inches overnight and still raining but breaking before noon.
Just got a warning that the flood warning has been extended until,2pm.
   / Good morning!!!! #173,507
Drew I have the DJI mini II SE 2.4k video compared to the mini II which is 4k. I didn't see the need for 4k as the file sizes are huge and my videio's are mostly viewed on the web anyways. Super simple to fly. My .02
   / Good morning!!!! #173,508
Good morning, 78 going to 86 today no rain around here
Slept in longer this morning. Buppies hope you got some rest
The new string trimmer should arrive today. Stacked a couple of loads of firewood yesterday.
Wife is up but having pain in her shoulders, arms and hands. Time for her weekly Methotrexate meds today that should help ease the pains somewhat.
Will see what I may get into today
   / Good morning!!!! #173,510
Morning all, Cloudy/smoky
Calling for 3-5 inches of rain, again !
If you don't here from me tomorrow, send a boat.
Some e-bikes would be pretty hard to tell, even up close these days.
Drew - there is a batteries plus in Langhorne, not the cheapest, but at least they carry name brands. I found my ramps and can take a look at machine, if the rain ever stops.
Scotty - good luck today!
Buppies - Try to get out and look around, sometimes a break from the daily routine adds a little light.
M7040 those are stage two lantern flies, next stage they grow wings and hop longer distances.
Be well ,
2011 Wacker Neuson RD12A, 36" Double Drum Roller (A52384)
2011 Wacker Neuson...
HARDEE RD72M LOT NUMBER 158 (A53084)
HARDEE RD72M LOT...
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
2022 Kobelco SK85CS-7 Excavator (A51573)
2022 Kobelco...
Airco Tig Welder (A51691)
Airco Tig Welder...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
