Good morning!!!!
   / Good morning!!!! #33,981
Thanks redneck I will give it a try. Just found out I need to replace a rotting transom, rip up the floors in the next few days see how the stringers are. Gel coat is least of my problems.
Sent from my iPad using TractorByNet
   / Good morning!!!! #33,982
I connected a piece of hose to my drain valve and ran it thru a hole to outside the shop. Whenever I go in to the shop I open it for a quick burst.
   / Good morning!!!! #33,983
lots of really good ideas. Vice just plopped in general area, agree completely to repositioning. This is all before...
I wanted the vice on that corner in case something had to go out the door. Going to put another support under that section plus under the drill press on the other side. Have lots of 4x4's left over from prior garden. Might as well make it sturdy.
never thought of water in the hose lines but yeah...fifty feet of line plus another ten say of various lead in lines and connecting lines. So sixty feet of hose offering a chance to condense, should one blow out the line before connecting a tool?
remember, never used air tools before but if there's moisture in there either trap it or blow it out.
Ok, I'll go blow out the air tank tomorrow, that should make a nice noise, and see how much water comes out since I first installed it. The tank valve is on the very bottom and ok to get at, though i'm not putting my face down there while opening that valve.
If I do build the new garage storage building next door, and needed a good air compressor, like an Ingersoll Rand type 30 or a US made Quincy to power equipment lifts, things I really want to work properly, and also higher air use tools, I would think about installing one of those air filter/drier kits in line. Kind of stuff is standard on rotary screw compressors, clearly the water should be religiously prevented from accumulating or damage will ensue. if the expensive compressors have this stuff standard, says something about the general need on smaller compressors. Even low hour ones.
Point well made and taken.
Drew I still blow out (drain) my compressors every time I use them, but I also hooked a in-line dryer to my big compressor because 90% of the things (furniture) I make I spray with lacquer. And any moisture can ruin a good finish.
   / Good morning!!!! #33,984
Don I have to agree with Drew, forgiveness not permission .
Had a little rain this morning then cloudy most of the day, didn't keep the crazy's in work was still busy. Predicted rain possibly thunder storms overnight.
Worked on the boat when I got home from work, the more I "dig into it" the deeper in my wallet the project goes.!
   / Good morning!!!! #33,985
more good ideas. Easy to pipe the exhaust drain outside, but what's coming out is under high pressure so this could make a real mess...well, I don't want it on my shoes anyway so better to get it outside. I have plenty of hose, but when opened I have 120psi bleeding off, not sure garden hose would like that. I have better hose left over from my larger boat days. Basically smaller diameter heater hose. Unless I pull the pop off valve I suppose. But the point is stuff is blasting out that hose so I need it aimed somewhere there is nothing to mess up. Eg, not my lawn mower parked there...
Ok ok
I promise to blow it out often. Like voting, blow it out early and blow it out often. It's a nice compressor and my air tools are mostly new now so would be pretty dumb to rust them out prematurely.
   / Good morning!!!! #33,986
Drew I just open and close the valve really quick Woosh all water gone.and use a hose clamp on the valve connection.
   / Good morning!!!! #33,987
Bust
Out
Another
Thousand
   / Good morning!!!! #33,988
Bust Out Another Thousand
Larro thanks for the encouragement!
Redneck the loader arms look good, nice job.
Drew nice looking work shop enjoy it.
   / Good morning!!!! #33,989
Snake boot selfie!
Went looking for the big snake this evening armed with my camera. No luck, the snake boots must have scared her off.
Chippewa Boots
Test - does anyone else see the problem with this test, like really only one boot!
https://www.youtube.com/watch?v=s1x7bLCvPBs
   / Good morning!!!! #33,990
Congrats on retirement! New garage, you are off and running. :D
Thanks just moved here permanently and don't have any storage in this small place so We Need a garage can only fit a 24x30 but we will make it work..:)
   / Good morning!!!! #33,991
I was finishing the last quarter of the field by the railway with the knapsack sprayer when I heard a distant voice calling. It was my wife calling me from the gate and although I couldn't hear the words clearly, that look told me she wasn't pleased with me. Somehow it had got to 7:30pm without me showing and she thought I must have had an accident with tractor or chainsaw as not only was I not home for tea without saying I'd be late, I wasn't answering my phone either. Pulled out the new phone and sure enough 4 missed calls, with call volume set to 0 :duh:
Julie had walked quite a way to find me and now I was now in deep dodo. It was a fair way for her to walk back too, however the Iseki was waiting not far away, so I suggested she drove it back. Now I have been trying to get her to drive this new machine for a while, but she has never shown interest before. This time she climbed in the cab without any protests and even managed a little smile at the surprise of sitting on the sumptuous air seat (a lot more comfy than the hard metal pan on the old Ferguson). After a little tuition, I set the "response" knob to slow and she drove home no problem. Full beaming smile by the time she climbed out and I was forgiven. :)
Her only complaint was that throttle was a little sluggish, set the response a little quicker next time.
I see lots of posts since yesterday morning, I will have to catch up later. It is dry at the moment, though forecast just said rain by this evening, with showers continuing for most of next week. I better get out now and make the most of it.
   / Good morning!!!! #33,992
Coffee is done brewing. 65° with overcast skies this morning. Heading to 83° with chance of thunderstorms later in the day. Got the waterline to pond filter fixed. Cold last winter had destroyed 5' of the 2" flex PVC. Local Pond Place charged $7.50 a foot for it. But when you need it you need it. Need to make sure I blow this line out next winter when shutting it down. Still need to fill in trench before rain causes sides to cave in. Got Trak-Vac hooked up to lawnmower and got lawn cut. Today is wash all the house windows day.
B7510HSD, congrats on your retirement.
txdon, the guy only has one boot on?
Drew, way to clean of a shop.
RedNeckGeek, nice paint job.
Good Morning All.
   / Good morning!!!! #33,993
Close call on spending the night in the dog house there.:rolleyes: Good thing you had the Iseki there to distract her.
   / Good morning!!!! #33,994
51F foggy now high 80F
Headed outside shortly to finish planting veggie plants before I am blackflies breakfast.
Today just puttering here and there nothing special.
Enjoy the day all.
   / Good morning!!!! #33,995
52F with some fog. Supposed to be near 80 today with a slight chance of a shower later this morning. We did get some rain last night, enough to wet the surface down at least. According to the radar replay it blossomed into a nice rain storm just after it passed on to our east. The folks in New Brunswick, Canada should be getting a nice rain this morning.
I see the problem with the boot test TXDon. Some crazy guy went into a room full of poisonous snakes. :laughing:
Eric, I hope Julie let's you drive the tractor now. She may take a liking to it.
Enjoy the day.
   / Good morning!!!! #33,996
67F with some light rain/drizzle/mist @ 06:45 ...
Will be good for the weed pullin' ... but I think I could hear the grass growing while I slept last night ...
Spent the better part of yesterday working on the Lawn Boy, getting it up and running. Pulled the spark plug and hit it with a wire brush and then washed the air filter and oiled it. Drained the fuel tank and rinsed it out with some fresh premix. Took the air hose and blew off all the crud and cobwebs off the unit ...
Broke the rope for the pull start on the first pull ... so I had to replace that with a new one ... wasn't too bad, but it was the first time I'd ever had the recoil starter off. Had to clean the rust off the guide eyelets for the starter rope with a grinding point in a drill.
Second pull nada ... fired on the third and tried to start but didn't quite make it ... got it started at some point after that ... took considerable futzing around with the carb to get it really dialed in ...
Of course the owners manual was completely useless as far as providing any useful info to adjust it ... was forced to resort to Google and YouTube, and some of the content there wasn't much better than the owners manual.
Checked the blade and surprisingly it was in relatively decent shape: rusted up a bit and could use sharpening, but the blade edge was smooth with no nicks or gouges out of it. Probably should pull it and clean it up with a flap disc in the angle grinder. Might want to check the exhaust ports for carbon while I'm at it.
This one is for Eric.
When I went up to the shop to get the new cord for the starter, the neighbor's sheepz were down at this end:
attachment.php
They're pretty funny ... vehicles (cars, trucks, tractors) don't seem to spook 'em ... but if they see a human they take off and head towards the barn.
   / Good morning!!!! #33,998
RS, two cycle lawnboy?
Yup ... L21ZSNA ... circa 1989 or so ... looks like this only a little rougher:
425213-good-morning-l21zsna-1-jpg
Emission control sure did them in. I bet we tried every different kind of trimming mower on our farm growing up, some didn't last one season. The toughest one of them all was a commercial version Lawn Boy, probably because all the slope cutting didn't starve the engine for oil. It was good for many years.
Yeah ... can't say that this one has seen a ton of use ... it was bought mainly for trimming and clean up around the house ... but we've sorta tried to landscape so that most all the mowing can be done while seated on something ... :D
Really wish I had ponied up for the LB with the aluminum deck though ...
My Stihl FS66 is in at the shop right now (2 week backlog there) trying to get a diagnosis on what's causing it to shoot raw gas out of the muffler, so in the meantime the LB might see some use to beat back the jungle in places where I can't get with a rider.
Wood shop is lookin' very nice :thumbsup:
   / Good morning!!!! #33,999
2015-05-17, 0755
56 right now...high of 80 today. looks like a good day to mow the lawn
   / Good morning!!!! #34,000
66 this morning high of 77 later today with storms possible. Very humid outside as well. Worked until 3:00PM or so the wife and I pulled weeds and planted flowers by the gate. Wife watched the ponies run while I got gas then went on nice relaxing ride on parkway with top down. Very relaxing and the sights were breathtaking. More grass mowing on agenda today, then BBall tonight. Good Morning all
JEEP FOR DOUBLE TRAILER (A58214)
JEEP FOR DOUBLE...
2007 FELLA SM350 3 PT DISC MOWER (A55315)
2007 FELLA SM350 3...
2022 CATERPILLAR 330 EXCAVATOR (A60429)
2022 CATERPILLAR...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2019 INTERNATIONAL...
Commercial truck Frame with Axle (A59230)
Commercial truck...
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A55745)
2018 PJ TRAILER...
