Good morning!!!!
/ Good morning!!!! #202,481
Good Evening Paul,
Senior moment here, sorry ! I think you told me some time ago that you do own your own tank
Sort of…
We’re talking about them taking my 320 in trade on a 500. They also want to install their own tank monitor rather than use mine.
Their price for gas isn’t bad, it will come down to the details of the tank swap.
/ Good morning!!!! #202,483
Yep, have use a bit more sand, the worst is going to be listening to wife complain it's too cold.
With the coal I tend to keep it too warm for me but it's still cold to her.
Me in a short sleeve shirt and she has on long sleeves and sweater complaining it's cold at at 74F.
I keep this shack at 76°F.
/ Good morning!!!! #202,484
Well the lights went out at 2 today. Came back on at 6. High winds are to blame and some tree hugger didn't want his precious trees cut. So the high winds bring the trees down on the power wires and the rest of us have to pay. I've got a generator and the wood furnace has a thermostatically controlled blower. The wood furnace is lit every day from 11 A.M. until 11 P.M. The oil picks up the slack except when the power goes out. Don't get me wrong, I like trees too, but not at the expense of someone else's electricity.
/ Good morning!!!! #202,486
Good memory, Mostly. This stuff is so tall and thick have to cut before entering, hence backing. Add to that the unevenness of the terrain, you’d be driving into the unknown, likely tractor becoming unstable. Backing, I can ease in, get some visibility. My repaired stabilizer holding up very well.
Is this the invasive and non native Guinea Grass that gets really tall. Saw some show where this was completely overwhelming a property. Talked about former sugar plantations were completely overgrown with this African import
/ Good morning!!!! #202,487
Yes there is a Z axis.
The sequence is that it drops down to sense the height of the surface by seeing the drive motor current rise as it stalls, raises to .150”, initiates a pilot arc, then lowers to the .060” cut height. The tricky timing is in the delay from when it lowers to cut height to make the pierce until it starts the actual cut, as well as the lead in distance and angle to the cut line.
The actual cutting distance is maintained by a closed loop that monitors the cutting voltage and drives the Z axis. If the cut height increases,so does the voltage required to maintain the arc, and conversely if the voltage dips, it raises the torch. This lets it compensate for a surface that isn’t level.
I am getting a decent handle on it, changing parameters and seeing the result has been a big help. Much less frustration than trying to learn on a part that I need.
You explained ohmic sensing very well. When me and my student worker were fighting it on the torchmate, we ended up running a 2nd ground wire to clamp to the material, and that fixed it because the table's ground was intermittent. Torchmate has pierce height setting, along with matl thickness, and feed adjustments, but nothing beats practice and experience.
I have not cut anything thicker than 1/4" so far, but we have a hypertherm 125, so supposedly we can.
Question, IIRC your table is stainless, but are the slats stainless?
David, Cody was back to normal after the seizure. He has had about one a year for the last few years. Not sure what it is causing it. Two different vets have examined him and done testing
A buddy gives his 3 yo male golden vitamin B1 to keep seizures to a minimum. Says it is working great for months now.
All of the hardware is presently black, so I’ve been “directed” to make it black. Brass did cross my mind, it’s a lot easier to work with, and I don’t have to get it powder coated.
Ask for a brass kitchen pass. :)
Just woke up my lack of sleep is catching up to me. Not sure of forecast but by second week of February cold comes back. We are dry again.
Prayers for LS and wife all others silent or spoken our Country
Prayers for Bupps, Holly, Ted and Dona.
Need to act upon it.
My bad experience, still dealing with it, my FIL was a pack rat. Now his kids are dealing with a lifetime of boats and cars some not titled at all. The stress is undeniable. If he had acted upon it, the sales, he would have benefited and his kids not be tormented by the bureaucracy involved in closing out his wishes.
Good luck, hope it works out for you all.
My mom is still "kicking" and can be just as honery from her bed as normal....but her home is full of "sentimental" (to her) keepsakes that are pretty much worthless. I'm going to be dealing with that probably in the not too distant future.
Talked with lawyer today. She said if there are no liens against mom's home, she can do a ladybird claim and it will stay out of probate. (thanks Don).
Crummy weather for the next few days, cool and rainy. Then this weekend is forecast for sun and 70F. Maybe time to ride my motorcycle!
/ Good morning!!!! #202,488
The latest weather forecast/warning;
Winter weather travel advisory in effect.What:Significantly reduced visibility in snow and blowing snow.Snowfall accumulations of 10 to 20 cm (4 to 8") by this evening. Southwesterly wind gusts up to 70 or 80 km/h (42 to 50 mph). When:This afternoon into this evening.
I WILL be plowing tomorrow.
/ Good morning!!!! #202,489
The plowing only took 2.75 hours today. More snow and they are talking lake effect for tomorrow.
I plow at 1900 rpm and use the bucket most of the time and the back blade for a little bit on my driveway. I use 3.5 US gallons of fuel in 9 hours of plowing. I think my straight pipe theory is working.
More snow coming already. Started up your and my (cottage) way already, and will hit TO within the hour.
I like it. Brings the snowmobilers up and helps the local economy a LOT.
/ Good morning!!!! #202,490
She is good. This type of deed is only available in five states: Florida, Texas, Michigan Vermont and West Virginia.
/ Good morning!!!! #202,492
Good evening all. 27ºF for the start, mostly clear sky, light breeze. Light wind, partly cloudy sky, and high temp was 51ºF. Rain in forecast for Wednesday and Thursday morning, Temps near normal. Mads coffee to start day, Creme of Wheat/Malt o Meal mix for breakfast. Groom ashes, stoke fire, tried to cut up rest of branch picked up last week before trash got picked up but they had been by already at 10:30. So only got fill second trash can once today. Food swap with stepdaughter, she got meatloaf and I go homemade vegetable beef soup, yum :) Bike rid went well. got nap.
Bill hope enjoy your seat time today.
NHBX 3 hr nap impressive! hope you slept well last night. Hope grocery shopping went well.
Ron glad you got half day conserve energy. glad pin welding done. hope painting and pins with grease fittings goes well. Fresh caught walleye sounds good for dinner. Nice Jay on feeder.
Billy sorry about another plumbing issue. Saugeye I am told have teeth like northern pike so will need steel leader.
Drew Hope conversation with Ford dealer went well. Sorry neck is acting up. I would pics of Ron's project, including as started and finished.
Phil Sorry no tow truck Friday, hope they came today. Sorry wood not cooperating very well. and one chunked let loose. Work pieces departing chucks are bad enough. Hope finish went well on cherry. Burl project very neat. Hope you can clean stove and chimney soon.
Ron thanks for pic of finished pin adapter.
Mike hope driveway getting melted off. Hope no one was under icicle when it fell.
Dennis Thanks, sometimes it's a chore to get caught back up. For some reason I thought Snagglepuss got on wife's bad list. Man that was a core getting the laptop ready for Turbotax. Glad everything is keeping up on heat side.
Dennis I am finding the actual dealer more important than name on vehicle.
Bill glad your customers are mostly protected from drifting. hope day goes well,
Spike56 looks somewhat like the SR71. Wonder what it's real capabilities will be :)
Drew thanks for info on homeowners policy.
Happy(NC) hoping for good superbowl. Good luck with Jury duty, I never have served on a jury. Hope vet visit go well.
Scott(VT) I have to agree feeding wood stove or insert is good place to be :) Have fun with the grands :)
Frits good to hear Apple watch will work. I have to clean out some of the ash every day there is a fire. Hope you are ready for accountant.
Drew sorry about the tainted case that was dismissed.
Dennis or walk into the courtroom say hang them all !! Funny meme.
Bill I think you are right :)
Ken glad garage defrosted and dried out. Hope plumber showed. Sorry about cold.
Drew good thoughts on personal rights.
Drew had to laugh at the thought of wearing Dennis's shirt to Quaker meeting.
Paul good idea to go to Costco during Eagles game. Glad you got your fab project done. Sorry about the changes to your propane supplier. Hope change over goes well. Hope meeting went well and you and wife got shed on order.
Lou hope you like your upcoming gas fireplace.
Thomas sorry E muffins on run to meet the critter food gentlemen. Hope puttering and dinner went well.
Buppies self care is important during your trying times. prayers sent.
Friend(trac) glad truck ready for travel and dog didn't run away. Hope boat goes well if he sells.
RNG glad you are getting rain. Glad good trip, sorry about wallet. Hope you list is short on things to work on, and batteries are in good shape in the F250.
Mike good reminder.
NHBX hope nothing damaged from earthquake.
Drew sorry about heater hose, I understand about not trusting them!
Two_bit my rain days are all day Wednesday and Thursday morning.
David sorry not pleased with playoff results. Hope HH was good and you got to mow.
Dennis yes there are crooked cops as well. The sad part is that to many innocent people do get jail time.
Dennis sorry to hear hospital hit with ransomware attack.
PJ glad you got epic nap. The problem with doing nothing is that you never know when you are done.
Mike enjoy the respite from mowing.
Thomas sorry n motivation. Sorry old TV died glad replacement cheap and nicer to watch.
Randy(wag) sorry it is getting warm in your neck of the woods. Hope Dr appointment went well and you rid of the smelly trash.
Don the size recommended is match amp to cold cranking amps on battery you are buying it for.
Lou wife and I went through same thing in winter and summer. I wanted house cooler , she wanted it warmer.
Bill during winter overnight set point is 64ºF, daytime set point 66-68ºF. Sorry about the power loss.
Kyle Thanks for the info on plasma cutting. Thanks for info on B1. Sorry to hear you mom is not long for this world. No rain till Wednesday for us.
Bill have fun plowing tomorrow.
prayer for all, especially Jay/Peg, Kyle /Daughter, /mom's breathing, /son's migraines, Bird /aging issues, Mike /BIL in FL, Ron /heart, David(moss) /remodel, /divorce, Buppies /cancer,parathyroid,blood sugar /wife, Thomas /gout, Phil /reflux, Frits /veteran son with mental issues, /granddaughter with Evans Syndrome, Ken /dad dementia, /chronic fatigue, Diet not working, Randy(wag) /sister stoke, Steppenwolfe /son-auto immune disorder, Grev /wife's eye, Ted /knee recovery, /retirement & disability red tape, /family issues, /wife back issues and cancer, Lou /eye issues, /heart issues, /wife hip replacement, Doug and wife/health issues, / hand nerve and surgery, /fall and recovery, / wife headaches and heart eval, / David(sadamo)/Sophie's hip or leg pain, /back issue, Scaredy/shoulder dislocation, /marriage dissolving, / friend stop drinking, Dennis /retirement, /neighbor issues, /brother's lymphoma, /dad surgery recovery, Drew /back operation issues, /friend's wife cancer diagnosis and recovery, Scotty /back pain, Helogabals /wife's friend situation, Fatjay /father broken hip, ******, Ukraine war, hurricane victims, and Country.
/ Good morning!!!! #202,493
good morning all
up early, enjoying my coffee
nice to see it above freezing for once waking up, 34 going up to 41 today, should keep melting what's left of the snow.
snow system crossing Canada and New England North of us, but nothing here.
hope you all have a good day.
/ Good morning!!!! #202,494
Been ho hum kinda day couldn't get interested doing anything. :oops:
The 18 year flat screen tv final quite :( Mrs. had sale bill when brought $1.893,Mrs. gone an hour return home with 55" name brand flat screen for $185.oo.:unsure: Mrs. setup tv :) what BIG different. (y)
Plans for the evening 0 Nothing little as possible.
Enjoy your evening all.
ENJOY THE NEW TV!
/ Good morning!!!! #202,495
Good Morning!
Still under Cloudy skies today. High predicted to be 55°F. Currently 44°.
Meeting this evening tired me out and I went to sleep early. So early to bed and early to rise today!
Not a lot really planned.
Everyone have a great day! Prayers for our Nation!
/ Good morning!!!! #202,496
Coffee is cooling in cup. 27° with cloudy skies this morning. Heading to 35° with clouds and wind. Yesterday had lots of sun and wind. First day this year with above freezing temperatures. Got my conserve energy day in after doing laundry and giving Sassy a bath. Plan to get some shop time today. Making greasable pins. May get pin adapter on tractor today.
Mostly, will have a photo of Quick Pin Adapter project when I get it Painted and on tractor.
Everyone stay well and safe.
Good Morning All.
/ Good morning!!!! #202,497
My mother had a Lady Bird Deed on her house. After she passed went to City Hall with it a, copy of death certificate and my ID. 15 minutes later walked out of there with deed in my name. Have Lady Bird Deed on my house and property for my sons.
/ Good morning!!!! #202,498
having a basic "I love you" will where you give everything to your spouse or family is
enormously helpful for the executor. Dying intestate is an unnecessary burden on the family.
having the deed modified is the cherry on top when it fits your situation.
good info from both Don and Ron, not something I dealt with in financial planning practice in PA.
I had to look it up, seems like a good way to manage estate taxes
A Lady Bird Deed is an estate planning tool that allows a property owner to transfer property to a beneficiary without going through probate.
The grantor retains ownership of the property during their lifetime, so they continue to pay property taxes.
  • When the grantor dies, the property transfers to the beneficiary with a stepped-up basis. This means the beneficiary acquires the property at its current market value, not the original cost basis.
  • If the beneficiary sells the property, they may pay less in capital gains taxes. However, if the property has appreciated significantly, they may pay higher capital gains taxes.
/ Good morning!!!! #202,500
29F now and should be the high for today partly cloudy sky,good chance late morning snow showers heavy at times with 10-20mph winds. 🙄
Plans for today...8 hours at part store afterwards attach snowplow to pickup for overnight 2-4 inch snowstorm coming...pretty sure going to be feet up evening.🤞
Enjoy your day all.
2012 Acura TL Sedan (A59231)
2012 Acura TL...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
DEUTZ MARATHON...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
