Good Full size truck forum
   / Good Full size truck forum #11
Also look at inside of windshield for a haze created by mist coming from defroster. I had an s-10 with a core that went at 50k miles, dealer labor was quoted at $400 found a gmc mechanic to do it at his home for $200. An all out failure of core might be an unpleasant surprise as hot coolant comes out of vents.
Steve
Champagne Taste, Beer Budget
   / Good Full size truck forum #13
I had an '89 Lincoln that wouldn't put out heat despite a functioning tempature gauge that indicated normal operating temps. The heater input was tapped off the head of the engine (a crossways V6) The long and the short of it was a head gasket leak into the water jacket that would block(vapor lock !) the take-off port for the heater. Revving the engine real high would overcome the resistence the bubble of exhaust gases caused and the flow would resume temporarilly through the heater. Fortunately it was under warranty and was a $880 bill circa 1996. The Ford garage screwed around for 2 months with thermostats, electronic/vacunm controls.
RCH
The mystery has been resolved. The heater core was fully blocked by calcium-like deposits. No water was flowing in. There is no valve on the heater hoses on this truck (97 3/4 ton). On my 96 1/2 ton Tahoe, there is a valve. The thermostat was working ok, but I changed it anyway, and there was a lot of crud on it (probably from whatever clogged the heater core). The thing that really ticks me off is that I paid a local Chevy dealer over $500 to replace the heater core less than 2 years ago. My buddy at the radiator shop can't understand how this could have happened if they really did replace the core AND flushed the system sufficiently. Don't trust those dealerships as far as I can throw them!!!/w3tcompact/icons/mad.gif
The smell of antifreeze is coming from a small split where the cooling fins of the main radiator come together with one of the side tanks. It was loosing level ever so slightly, but the crack is pretty high up on the radiator, so it only leaked steam after the level went down below that point - not a lot of volume, but pretty easy to smell. The smell was being picked up by the fresh air intake as the heater blew (cold) air into the truck. Since the radiator has plastic tanks, it cannot be brazed, so after I use up the antifreeze I have topping off the reservoir, I will probably spring for the ~$300 to replace the radiator. I'm not in the mood to do it right now since my other car (96 tahoe) just got a new intake manifold since the old one cracked where a water passage was (leaking anitfreeze like a sieve). When it rains, it pours./w3tcompact/icons/sad.gif
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
*Selling at Royal Auction Zephyrhills, FL Location* 12 (A59230)
*Selling at Royal...
10ft. S/A Utility Trailer (A56859)
10ft. S/A Utility...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2022 Chevrolet Tahoe SUV (A56859)
2022 Chevrolet...
