Great A/C but no heat.
   / Great A/C but no heat.
Oh and I’ve never seen a coolant leak under the tractor or in the oil.
It’s now giving heat. I’m thinking it was something with that radiator cap. I kind of messed with the seals and spring and now its pressurized. Sounds like a new cap in my future.
   / Great A/C but no heat. #14
Ya, id swap it right away. To prevent engine damage
   / Great A/C but no heat. #15
A good possibility the the cap was not securely fastened to the second stop, which would not pressurize the system.
   / Great A/C but no heat. #16
My Kioti ck3510 chse has freezing cold a/c but now that fall it here I now realize there’s no heat. I turn it to hot or cold and it feels like outside air. Does anyone know where to start? With only 650 hours I’d doubt its a heater core but don’t really know how the system operates being that the air comes out of the roof unlike a car.
The blend air door is controlled by a cable. I had the cable slip when my cab top got infested by mice. While there shove steel wool down the A, B, and C pillars for mouse prevention.
That’s initially what I was thinking but before removing it I tried pushing it down while tightening and it was on correctly. I guess everything eventually fails.
   / Great A/C but no heat. #18
I’m surprised you didn't see/smell coolant after running it a while.
Never smelled coolant. I was out at this property yesterday enjoying the snow. I just got an alert that my radiator cap has finally arrived but its back home. Anyway I ran this tractor for about 45 minutes and it barely got off cold on the gauge. I'm now thinking the previous owner removed the thermostat or it's stuck open.
   / Great A/C but no heat. #20
There is a cable connected to the temp control. On my NX it fell off once. I popped the top off hooked the cable end back up and safety wired it in place. No problems since that time.
2014 Chevrolet Silverado 1500 (A60460)
2014 Chevrolet...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
Truck Mounted Carpet Cleaning Extraction Machine (A57453)
Truck Mounted...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
Topsoil Trommel (A57453)
Topsoil Trommel...
Miller Air Condition Unit (A57454)
Miller Air...
