Great A/C but no heat.
   / Great A/C but no heat.
Oh and I’ve never seen a coolant leak under the tractor or in the oil.
It’s now giving heat. I’m thinking it was something with that radiator cap. I kind of messed with the seals and spring and now its pressurized. Sounds like a new cap in my future.
   / Great A/C but no heat. #14
Ya, id swap it right away. To prevent engine damage
   / Great A/C but no heat. #15
A good possibility the the cap was not securely fastened to the second stop, which would not pressurize the system.
   / Great A/C but no heat. #16
My Kioti ck3510 chse has freezing cold a/c but now that fall it here I now realize there’s no heat. I turn it to hot or cold and it feels like outside air. Does anyone know where to start? With only 650 hours I’d doubt its a heater core but don’t really know how the system operates being that the air comes out of the roof unlike a car.
The blend air door is controlled by a cable. I had the cable slip when my cab top got infested by mice. While there shove steel wool down the A, B, and C pillars for mouse prevention.
That’s initially what I was thinking but before removing it I tried pushing it down while tightening and it was on correctly. I guess everything eventually fails.
   / Great A/C but no heat. #18
I’m surprised you didn't see/smell coolant after running it a while.
Never smelled coolant. I was out at this property yesterday enjoying the snow. I just got an alert that my radiator cap has finally arrived but its back home. Anyway I ran this tractor for about 45 minutes and it barely got off cold on the gauge. I'm now thinking the previous owner removed the thermostat or it's stuck open.
   / Great A/C but no heat. #20
There is a cable connected to the temp control. On my NX it fell off once. I popped the top off hooked the cable end back up and safety wired it in place. No problems since that time.
2005 Construction Trailer Specialists BDT-40 Bottom Dump T/A 40ft Trailer (A49461)
2005 Construction...
KLEIN TOOLBOX (A50854)
1994 Toyota 6000lbs 2 Stage Forklift (A51039)
1994 Toyota...
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
1271 (A50490)
1271 (A50490)
