GM recalls 721K trucks with 6.2L engine
   / GM recalls 721K trucks with 6.2L engine #101
Show me all the windowed cummins blocks.
Are you saying it didn't happen?
SR
What is the % of all produced Cummins inlines??
Wow in other News GM truck owners get screwed, in GM lawsuit being "decertified" concerning the 8 speed, and the 10 speed may be next.
Nate lets them have it.
   / GM recalls 721K trucks with 6.2L engine #102
It is being made for the medium duty truck market, not PU's.
B6.7 Octane​
The Cummins B6.7 Octane engine is specifically designed and developed for the medium-duty market while achieving 2027 EPA and CARB compliance.
https://www.cummins.com/engines/octane
Uh, UIAM ALL ISB Inline 6 Cummins are considered Medium Duty Engines already.
New reports RAM HD's will get the New B7.2 Cummins inline 6 in 2027 Not sure about going with OHC on either but the Octanes numbers are impressive and hard to argue with for low end torque...
   / GM recalls 721K trucks with 6.2L engine #103
B6.7 Octane​
So is the 5.9/6.7 Cummins, but they put them in light duty trucks anyway.
99% of truck buyers would be happier buying a light duty truck with a medium duty rated engine than a light duty engine.
   / GM recalls 721K trucks with 6.2L engine #104
I didn’t know Cummins bought the Jacobs Engine Brake Company (Jake Brake) in 2022.
That’s a huge move.
   / GM recalls 721K trucks with 6.2L engine #105
   / GM recalls 721K trucks with 6.2L engine #106
Drat! I was already drooling over buying one.
Just because it's Medium duty, it doesn't mean it won't be in a Ram.
Ram already has a medium duty diesel in its Ram 2500-5500
   / GM recalls 721K trucks with 6.2L engine #107
The Dealer just completed the recall on the L87 6.2L engine in my 2022 GMC Sierra 1500, and it checked out ok. They replaced the oil fill cap & filter, Changed the oil to a heavier weight and listened to the engine with a fancy type of stethoscope. Pretty much what the recall notice said.
Still a bit nervous driving it though, listening for any unusual engine sounds. The good news is, I'm covered if there should be a future failure specific to the recall. It's important to keep records proving you used the right oil type though if you change your own oil.
Only a 3% failure rate though so the numbers are on my side. Too bad about the hit on the trade in value.
   / GM recalls 721K trucks with 6.2L engine #108
Medium duty, as in: It makes no sense to put a cast iron lugger in a half ton. It doesnt give high horsepower but it will deliver longevity and torque in a towing truck.
   / GM recalls 721K trucks with 6.2L engine #109
Man suffers most from what he fears (but never happens)
I have a very quiet whine in the transmission, which only i hear. I can worry about it grenading the bearing rollers through the front wall, into the bellhousing, bending the clutch bolts while being pushed through that sidewall too, like i had 21 years ago, but thats an unrealistic expectation...
   / GM recalls 721K trucks with 6.2L engine #110
When did I say “half ton”? I said 2500-5500.
Read much?
2016 INTERNATIONAL 4300 SBA FLAT TOP ROAD TRACTOR (A58375)
2016 INTERNATIONAL...
202479 (A54757)
202479 (A54757)
JLG SCISSORLIFT (A52705)
JLG SCISSORLIFT...
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A56858)
2017 Autocar...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
