Glow Plugs
/ Glow Plugs #1
yomax4
Elite Member
Midwest
ISEKI TA 247. Stihl Saws Gravely Zt's Polaris ATV's State Of The Art Welding Equipment
Howdi guys.. I read through some of the Threads on Glow plugs and Diesel Starting but did not find what I need. Soooo I ask you Imperial Wizards.. I need to heat my Glow Plugs on my TA 247 3cyl Diesel to get a quick start even now in Minnesota where the temps soar to over 75 degrees in the middle of summer. hahaha Last year I did not have to do this.. Is this an issue that needs to be looked into? Last year this beast would start in below freezing temps without the glow plugs.
Thanks..:confused:
/ Glow Plugs #2
Have you noticed a loss of power ?, if so maybe it's time for a compression test/check.
If you don't use glow plugs, do you get white smoke from exhaust while trying to start ?, if not you might have a fuel problem.
/ Glow Plugs
No, Tons of Power. Only have 1200 hrs on meter. Not that its accurate but this is a Power Monster. I wonder if it is a fuel issue. So, I should Not have to fire up the Glow Plugs in warm weather??
/ Glow Plugs #4
At 70 degrees my 790 fires off in less than 2 seconds of crank time without plugs.
My Dodge CTD even less.
/ Glow Plugs #5
try some diesel fuel additive to the tank it will help.plus use the glow plugs or warm the enging with the block heater.check the oil.charge up the battery.diesels do all sorts of things when they age.and are very sensitive to temperature.good luck.
/ Glow Plugs #6
I would look into the fuel issue . I,ve never needed use mine untill its below freezing . Mines about the same model as Yours , it fires right up. Bob
/ Glow Plugs #7
WOW, I learned something new today.
I did not know you did not need your glow plugs above freezing!
I warm mine up just about everytime I start the tractor.
/ Glow Plugs
Thanks all. I think I will drain fuel and replace. What are the ramifications if you put in too much Power Service? That may be my problem..:confused:
Thanks again..
/ Glow Plugs #9
I suspect you're doing it properly. Check your Owner's Manual if you have one. Mine says to ALWAYS, in any temperature, turn on the key until the glow plug light on the dash goes out, then start the engine. I don't know if they're all the same of if they differ by manufacturer.
/ Glow Plugs #10
For me, if the engine isnt warm from running, I always heat up the plugs. I usually, when starting cold any time of the year, count to ten and she fires right up. If I am working and take a couple of hours break, I count to 5............Always starts with NO PROBLEM......Dennis
/ Glow Plugs #11
You will do NO harm to your tractor by using 'heaters', even if there not needed. :cool:
/ Glow Plugs #12
How much carbon build up is normal on glow plugs? My plugs are similar to NGK Y-110 6825.
Bush Hog 3008 (A64127)
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
Coats 5060AX Rim Clamp (A63689)
Coats 5060AX Rim...
AUCTION STARTS HERE @ 9AM (A63276)
AUCTION STARTS...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
Bulk Lot - (3) Sticks HDPE Pipe - 24in x 40ft - Selling as One Lot (A63689)
Bulk Lot - (3)...
