glow plug use
/ glow plug use #1
asnufkin
Sausalito, CA
Isuzu 2AB1
Hi,
I have a boat with an Isuzu 2AB1 engine, which I understand is the engine on the Iseki TS2205, and maybe on other tractors.
For anyone who has used this engine, how long do you typically need to operate the glow plugs before firing up the engine?
/ glow plug use #2
I suppose it would depend on the temp, but I usually run mine about 30 seconds. My tractor has place in the dash that will glow red when the glow plugs are hot.
/ glow plug use
Cool, thanks! Is yours an Isuzu 2AB1 engine?
Mine is on a boat, so there's no dashboard. I've had some starting trouble and I needed an indication of whether my glow plugs (which are new) were working properly.
Cheers :)
/ glow plug use #4
Put a voltmeter on the battery and turn on the glow plugs, the voltage should drop by a volt or more.
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
2024 DODGE TRUCK BED (A65643)
2024 DODGE TRUCK...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
