glow coil question -
/ glow coil question -
thanks Dave -
yes, I was surprised too. But that what it is. I hear what you're saying, but why would a intake air heater run through a dash mounted glow coil?
here are some pics
Thanks again ....
thanks Dave -
here are some pics
Thanks again ....
/ glow coil question - #23
Just an FYI, the glow plugs for my old Ford 4 cyl read about 0.2 - 0.3 ohms and draw 40-50 amps each.
online at www.sparkplugs.com have glow plugs. If you have a number, they may be able to cross it. But not cheap! $31 each for mine...
jb
jb
/ glow coil question - #24
jb
jb
/ glow coil question - #25
I guess I'm confused, but that looks like a picture of an oil pressure switch, or at least that's what it looks like to me.
/ glow coil question - #26
/ glow coil question - #27
"I guess I'm confused, but that looks like a picture of an oil pressure switch, or at least that's what it looks like to me."
I'm confused also. I, too, only see an oil pressure switch.
/ glow coil question - #28
/ glow coil question - #29
The glow plugs are on the head somewhere screwed into the combustion chamber. They may not have a wire going from plug to plug but should have a bar. There is a wire going to the rear glow plug. I just took mine out, held them with a set of pliers and turned the key. Of course I had them all still connected electrically. They will get hot quick. If they don't they could be bad.
/ glow coil question - #30
/ glow coil question - #31
I agree, glow plugs are not located in the block, they are in the head, and there is 1 per cylinder on every diesel I ever worked on. You have a 2 cylinder so there should be 2 on your unit. That unit in your picture looks like a sending unit.
/ glow coil question - #32
Thanks ... It's just that I traced the wire going through the pre-glow push button and it seems to go to that location. I guess I traced it wrong. It must be these guys then, right?
/ glow coil question - #35
There you go,.... the little ones with the wire, not the big ones with the fuel lines.
/ glow coil question - #36
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
GREEN LEE KNOCK OUT SET (A63745)
GREEN LEE KNOCK...
NEW HOLLAND C227 SKID STEER (A64279)
NEW HOLLAND C227...
Dodge Charger (A56859)
