2016 emax 22 hst glow plugs not working and cell light is flashing
   / 2016 emax 22 hst glow plugs not working and cell light is flashing #1
maht2
Terry@123
While using the tractor the glow plug light started flickering for no reason until it went out then cel light started flashing code 24 .
Here is the steps I have done so far to find the problem .
Tested the wires going to glow plug relay all tested good except for the ground side of the relay coil . Relay tested good tried new relay anyway no luck
I ran a jumper wire to ground side on the relay to see if would fix the problem of bad ground wire but didn't work . I didn't remove the existing ground from the relay plug itself just slide jumper ground wire in beside it .
I am thinking the original ground wire may have melted in the harness somewhere causing ecu to stay in fault ? Thinking of pulling the wiring harness .
I also purchased the workshop manual and the blink code 24 is not in there only 21 and 28 which point to ground fault .
Any help or information would be appreciated to solve this problem.
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2021 KENWORTH T680...
