glow coil question -
/ glow coil question -
thanks Dave -
yes, I was surprised too. But that what it is. I hear what you're saying, but why would a intake air heater run through a dash mounted glow coil?
here are some pics
Thanks again ....
thanks Dave -
here are some pics
Thanks again ....
/ glow coil question - #23
Just an FYI, the glow plugs for my old Ford 4 cyl read about 0.2 - 0.3 ohms and draw 40-50 amps each.
online at www.sparkplugs.com have glow plugs. If you have a number, they may be able to cross it. But not cheap! $31 each for mine...
jb
jb
/ glow coil question - #24
jb
jb
/ glow coil question - #25
I guess I'm confused, but that looks like a picture of an oil pressure switch, or at least that's what it looks like to me.
/ glow coil question - #26
/ glow coil question - #27
"I guess I'm confused, but that looks like a picture of an oil pressure switch, or at least that's what it looks like to me."
I'm confused also. I, too, only see an oil pressure switch.
/ glow coil question - #28
/ glow coil question - #29
The glow plugs are on the head somewhere screwed into the combustion chamber. They may not have a wire going from plug to plug but should have a bar. There is a wire going to the rear glow plug. I just took mine out, held them with a set of pliers and turned the key. Of course I had them all still connected electrically. They will get hot quick. If they don't they could be bad.
/ glow coil question - #30
/ glow coil question - #31
I agree, glow plugs are not located in the block, they are in the head, and there is 1 per cylinder on every diesel I ever worked on. You have a 2 cylinder so there should be 2 on your unit. That unit in your picture looks like a sending unit.
/ glow coil question - #32
Thanks ... It's just that I traced the wire going through the pre-glow push button and it seems to go to that location. I guess I traced it wrong. It must be these guys then, right?
/ glow coil question - #35
There you go,.... the little ones with the wire, not the big ones with the fuel lines.
/ glow coil question - #36
(2) OIL CATCHES (A63745)
(2) OIL CATCHES...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
2020 DRAGON 150BBL ALUMINUM (A63569)
2020 DRAGON 150BBL...
2021 CAM P4EC16  16ft 8000lb Trailer w/ Ramps (A64047)
2021 CAM P4EC16...
30ft Highway Trailer Co. Lowboy (A63118)
30ft Highway...
2006 Chevrolet 3500 Flatbed Truck (A63116)
2006 Chevrolet...
