Glossary of Tractor Terms
   / Glossary of Tractor Terms #41
Here's a list of model designations from Kubota as of 2012
DT - Dual Traction, ie. 4 wheel drive... Ok, more appropriately front wheel assist.
Kubota designations:
BX Series
V = Loader Valve
T = Turf Tires
R = R4 Industrial Tires
LB-T = Loader Backhoe w/Turf Tires
LB-R = Loader Backhoe w/R4 Tires
B Series
E = Two Wheel Drive DT = Dual Traction 4wd
HSE = Hydrostatic Transmission, 2wd
HSD or HSD-1 = Hydrostatic Transmission, 4wd
HSDB = Same as Hydrostatic 4wd, but includes Bi-Speed turn
HSD-T = Hydrostatic Transmission, 4wd, Tow Tractor (Airlines)
TL = Tractor, Loader
TLB = Tractor, Loader, Backhoe
L Series
DTC = Dual Traction, 4wd, Two stage clutch, Live continuous Running PTO (L235/L275) DTC = Dual Traction, 4wd, Integral Factory Cab (L3600/L4200) DTN
DTS = Dual Traction, 4wd, Power Steering
DTSC = Dual Traction, 4wd, Power Steering, Two stage clutch, Live continuous Running PTO (L235/L275)
DTN = Dual Traction 4wd, Narrow Specialty Tractor DT-W = Dual Traction 4wd, (W) Wet Clutch = EVER CLUTCH
F = Two Wheel Drive
FS = 2wd, Power Steering
FC = 2wd, Live-continuous running PTO
FSC = 2wd, Live-continuous running PTO, Power Steering
FST = Fully Synchronized (Main) Transmission
GST = Glide Shift Transmission
GSTCA = Glide Shift Transmission, 4wd, Factory Cab, "A is for Air Ventilation Kit (L3600/L4200)
GSTC = Glide Shift Transmission with Integrated Factory Cab
HC = High Clearance (L245HC only)
HF = Hydraulic Shuttle, 2wd
HDT-W = Hydraulic Shuttle, Dual Traction 4wd, (W) Wet Clutch = EVER CLUTCH HDT = Hydraulic Shuttle, Dual traction
HSTC = Hydrostatic "Feather Step Transmission with Integrated Factory Cab MF = Mechanical Shuttle, 2wd
MDT = Mechanical Shuttle, Dual Traction
SS = Shuttle Shift
T = Tow Tractor
W = Wide tread for Row Crop applications. (i.e., Tobacco)
DTC = Dual Traction 4wd, Cab Model
DTCCS = Dual Traction 4wd, Cab with Creep Speed
M Series
DT-1 = Dual Traction 4wd, ROPS model with IC/Shuttle Transmission (M7580/M9580)
DTL = Dual Traction 4wd, Low Profile (for orchards)
DTM = Dual Traction 4wd, MUDDER (for specialty, row crop and vegetable)
DTN = Dual Traction 4wd, Narrow (for vineyard/orchard tractor)
DTN-B = Dual Traction 4wd, Narrow wheel tread with Bi-Speed Turn
F = Two Wheel Drive
F-1 = (-1) = Larger two pump hydraulic system
FC = Two Wheel Drive Cab Model
F-CS = Two wheel drive with Creep Speed (Ag. tires or as Turf Special)
HC = High Clearance (2wd M7950 only)
HD = Hydraulic Shuttle, 4wd
HDC = Hydraulic Shuttle, 4wd, Cab
HDCCS = Hydraulic Shuttle, 4wd, Cab, Creep Speed
L = Low Profile
ML = Mechanical shuttle, Low profile
MDT = Mechanical shuttle, Dual traction 4wd
MDTL = Mechanical shuttle, Dual traction 4wd, Low profile
MF = Mechanical shuttle, Two wheel drive
OC = Orchard model
S = Synchro-Shuttle, 2wd
SD = Synchro-shuttle, 4wd
SCS = Synchro-Shuttle, 2wd, Creep Speed
SDN-B = Synchro-Shuttle, 4wd, Narrow with Bi-Speed Turn
SDNBC = Synchro-Shuttle, 4wd, Narrow with Bi-Speed turn, Cab model
SDNBF = Synchro-Shuttle, 4wd Narrow with Bi-Speed turn, Foldable mid-mounted ROPS
SU = Special Utility, 2wd
SU-R = Special Utility 2wd, Rigid ROPS
SU-F = Special Utility 2wd, Foldable ROPS SU-TF = Special Utility 2wd, Turf Special
SUD-R = Special Utility, 4wd, Rigid ROPS
SUD-F = Special Utility, 4wd, Foldable ROPS
SUMDT = Special Utility, Mechanical Shuttle, 4wd
SUDT = Special Utility, 4wd
W = Wide Row
H = 2WD, ROPS (Note: All H-Models are Std. Swing Shift 16F X 16R speeds)
HC = 2WD, CAB
HD = Swing Shift, 4WD, ROPS
HDC = Swing Shift, 4WD, CAB
DS = Dual speed, ROPS (Note: All Dual Speed models are 32F X 32R speeds)
DSC = Dual speed, CAB
SDSCC = Dual speed, CAB, cold weather w/high amp alternator and creep speed and second remote valve
SDSC = Swing Shift Dual Speed, CAB DSDF = Dual Speed, 4WD, ROPS
SDSL = Dual Speed, 4WD, Low Profile
M-Series Notes:
Suffix "1 models are the second generation "Wide Cab tractors. Cab is 5.7 inches wider than first models.
Suffix "2 models are factory equipped with 540 / 1000 RPM PTO kits. M95S and M105S:
The "S represents the model/tractor class in general is no specific meaning, however it can be applied to "Swing Shift as the base transmission on all "S models.
M50-Series 1983 - 1984 Cab was orange in color, air conditioning was optional.
   / Glossary of Tractor Terms #42
It would be great if tractor model numbers could be used as key terms in a search, and come up so when one searched for 253, 1086 2040 ect. one would not get other numbers like if you search for Massey 253 in the MF forum you get references to the numbers 2/5/3 and nothing on the 253 Tractor.
   / Glossary of Tractor Terms #43
I am not an advocate of abbreviations or acronyms, but here are a few that I think suit Tractor By net.
By the way, why is abbreviation such a long word?/w3tcompact/icons/smile.gif
AAAAA
American Association Against Acronym Abuse
CMIIW
Correct Me If Im Wrong
CUA
Commonly Used Acronym
DSH
Desperately Seeking Help
GFC
Going For Coffee
GIWIST
Gee, I Wish I'd Said That
GMTA
Great Minds Think Alike
HIWTH
Hate It When That Happens
HTH
Hope This Helps
IAAL
I Am A Lawyer
IAAD
I Am A Doctor
IAAF
I Am A Farmer
IAS
I Am Stupid
IBN
Im Buck Naked
ICBW
I Could Be Wrong
IHA
I Hate Abbreviations
IIRC
If I Recall Correctly
IMAO
In My Arrogant Opinion
IMCDO
In My Conceited Dogmatic Opinion
IME
In My Experience
IMHO
In My Humble Opinion
JAUA
Just Another Useless Answer
MCIBTY
My Computer Is Better Than Yours
NALOPKT
Not A Lot Of People Know That
PCMCIA
People Cant Memorize Computer Industry Acronyms
PWDUC
Pwople Who Dont Use Computers
RAEBNC
Read And Enjoyed But No Comment
RFI
Request For Information
RTFAQ
Read The FAQ
SCNR
Sorry Could Not Resist
SOHF
Sense Of Humor Failure
SWMBO
She Who Must Be Obeyed
TBT
Talking By Typing
TIA
Thanks In Advance
TIWTGLGG
This Is Where The Goofy Little Grin Goes
TTBOMK
To The Best Of My Knowlege
WAMKSAM
Why Are My Kids Staring At Me
WIBAMU
Well Ill Be A Monkeys Uncle
WT
Without Thinking
YGWYPF
You Get What You Pay For
YWIA
You're Welcome In Advance
LMAO!:LOL:.
   / Glossary of Tractor Terms #44
The search is only as good as the info people put out there.
A MF253 would be way better to find than a MF 253 that has the space between.
I could search for MTxxx models before for Mitsubishi. BUT, the TYM started naming their machine starting with MT. Go figure.
Often people will leave off the prefix letters and just post a number. Downright confusing in a search.
BUT HEY, the search tool never worked well enough to begin with till this last forum upgrade.
Vermeer 605 XL Round Baler (A59814)
Vermeer 605 XL...
Chemical Containers Tank (A57148)
Chemical...
2014 AMERITRAIL TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
DOOSAN G25KW GENERATOR (A58214)
DOOSAN G25KW...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
