GeoTextile Cloth
/ GeoTextile Cloth #1
MikePA
Super Moderator
PA
Had TC25D, now JD X310
Since it's been so wet this spring, I can't get into our new field to continue installing the fence I started last Fall. /forums/images/graemlins/frown.gif So, I decided I would begin work on digging out our three horse stalls. Do I know how to have fun, or what? /forums/images/graemlins/grin.gif Since I can not get any mechanized equipment into the stalls (three, 12' x 12' stalls), I will be doing all this by hand. /forums/images/graemlins/shocked.gif
Based upon feedback I've received on TBN before, my plan is as follows;
1. Dig down 10" across the entire area, sloping to 12" at the center.
2. Dig a hole in the center to contain a 15 gallon blue plastic barrel, perforated with holes.
3. Lay down geotextile cloth over the entire area. (I will actually use the Stall Skins we have installed now)
4. Put down 6" of 2A modified limestone (3/4" down to fines).
5. Lay down geotextile cloth.
6. Lay down 4" of sand.
Two Questions...
- What's the TBN brain trust think of this plan?
- The geotextile cloth I am looking at is located here. Since I only need enough cloth to do three stalls, I was going to order the 15' x 15' pond liner instead of an entire roll of the fabric somewhere else. However, I wasn't sure if the 8 oz fabric was the same stuff that gets used under driveways. Is it?
/ GeoTextile Cloth #2
Mike; I don't know what to tell you except the material you are looking at is pricey! I don't know the weight, but my brother uses the same fabric used on the Town roads, and he pays about $300 for a 13'x300' roll. (He uses when he installs sand filter septic systems.) The fabric on the website you linked is $300 for a 15'x100' section.
Your plan sounds good to me, although I have vever installed any stalls. It seems like you have drainage and cushioning under control.
Will
/ GeoTextile Cloth #3
Mike,
Just a thought.....Sam's Club sells large rolls of Landscape fabric, 4' x 400'? for about $28. It's probably not as thick as the Geotextile cloth but you could lay it out then double it up using a criss cross pattern.
/ GeoTextile Cloth #4
I'm not sure what your purpose of using the cloth is Mike? I really don't think it's necessary. I looked on the stallskins website and they don't mention it either. I also wouldn't use the sand. It's too soft and will give too much in my opinion.
/ GeoTextile Cloth
<font color="blue"> I'm not sure what your purpose of using the cloth is Mike? </font>
I was going to use it to keep the limestone from getting pushed down into the underlying clay.
<font color="blue"> I also wouldn't use the sand. </font>
Would you just use the limestone and put the bedding (pine wood chips) on top of that?
/ GeoTextile Cloth #6
Here is a link to geotextiles and livestock. GEOTEXTILE AND LIVESTOCK
I've attached a picture of the woven geotextile that I use. Price is under a doller per running foot for a 12' wide roll. In this area it's well worth it under driveways or for skidding trails. Sorry but I can't help you on horse use. But a geotextile used correctly will really help in rutting so I guess that would speak for itself.
I would also look to see if your local rental centers, ag centers or even where your going to buy your limestone from sell any type of geotextile. Just a thought. Good luck
Gordon
/ GeoTextile Cloth #7
Gordon's picture is what I was referring to earlier. Sounds like it is priced about the same.
Will
/ GeoTextile Cloth #8
Didn't you say you were using the stallskins Mike? They have an excellent step by step picture of doing this on their website. You need something over the top of the limestone after you lay it down. If not it gets to be a mess. Either stallskins or rubber mats are well worth the price.
/ GeoTextile Cloth
<font color="blue"> Didn't you say you were using the stallskins Mike? </font>
The problem we're having is with the clay underneath the StallSkins. When it gets water logged, you feel as if you're walking on a water bed. As the clay dries out, the stall floors become a 12' x 12' series of hills and valleys.
My plan was to dig down a foot, install the leach pit with the 15 gallon barrel in the center. (That's what you used, right?) Cover with limestone (not sure why StallSkin recommends the sand), then cover with another Stallskin. It will be difficult to reuse the existing Stallskin since they've already been trimmed.
/ GeoTextile Cloth #10
Mike,
What would your seasonal high water table be? Have you dug a test hole to see if it fills with water and how high it fills with water. If the water table is high your blue barrel will fill up with water and then have no place to go....
/ GeoTextile Cloth
In the spring, I imagine the barrel will be full. /forums/images/graemlins/frown.gif
Any ideas?
Plus, the ground the barn is on is relatively flat, so there's no place for the water to naturally drain. /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
/ GeoTextile Cloth #12
Mike,
I don't have a clue about the horse side of your question but
the fabric does prevent the stone from mixing in the clay. I
only drive on my driveway with geotextile a couple of times
a week at best but you can't tell that 355 tons of ABC was
moved across parts of the drive. Once we move out there
we will find out how well it holds up.
The supplier of my geotextile would sell the stuff by the
the foot. He just divided up the price pre foot off a full roll
and charged that price per linear foot. Very fair. Maybe
you can find a supplier to do the same. He sure did not have
a problem selling less than full loads.
Later,
Dan
/ GeoTextile Cloth
Update on the water table...
In 2 hours (and 5 FEL loads), I hand dug 1/6 of the stall out to a depth of 12 inches. Most of it was water logged clay. Very soon after I got down to the 12 inch depth, puddles of water began to appear. /forums/images/graemlins/frown.gif
Given this situation, I am debating whether to put the 15 gallon barrel in the center. As Don mentioned, it's going to just fill up with water which kind of defeats the purpose of installing it in the first place, I think.
/ GeoTextile Cloth #14
Mike,
My suggestion would be to lay perferated drain pipe(PVC) under the three stalls and direct them to a common pit. Place a sump pump in the common pit and pump the water outside as far away from the barn as possible. The sump pump will have a float on it and automatically come on when the pit fills with water. Does your barn have power?
/ GeoTextile Cloth
Yep, the barn has power. However, installing a common sump appears to make this project a bit more complicated than time and equine patience permits. /forums/images/graemlins/frown.gif
There are 3 stalls, two adjacent and one across a paved aisle. In order to reduce the impact on our equine inhabitants, I am doing one stall at a time. Connecting all the stalls to a common sump would mean digging a 3' deep trench between the stalls (two are adjacent, one is across a paved aisle) and then figuring out a location for the collection sump, etc.
If I could figure a backhoe into this operation in order to speed things up, this would be a possibility, but all this digging has to be done by hand. Sure wish I hand planned this all out before the barn was built. /forums/images/graemlins/blush.gif
/ GeoTextile Cloth #16
Hey Mike,
Looks like you have got a great idea, let me offer some input for you to think about. /forums/images/graemlins/laugh.gif
We just went through this with stalls. Our barn sits on C L A Y and more C L A Y. The stalls slope into a french drain, maybe a 5 gallon hole in the clay at the most. It is filled with stone and on top of this is about 6 inches of stone dust.
On top of the stone dust are stall matts. WoodyPet, a brandname wood shaving mixture is on top of that.
The stalls are BONE dry, don't smell and let me tell you with this rain, the horse was in her stall the last two weeks.
On the outside, I ran drain tile, about 300' feet, connecting to the downspouts. I also ran drain tile in the "pen" paddock area. I put this down TOO FAR, for the clay. I rented a ditch witch and took it down 3-4 feet. On top of this a placed blue stone #5 (good for driveways). I leveled it back off with the B7800 using the churned up clay mixture.
The horse has compacted the clay on top of the drain tile so much it does NOT drain. This w/e I will return to the paddock area and take out (about 1-2 feet) of clay and just use stone dust. That is if it dries out.
Anyway, your milage may vary.
-Mike Z. /forums/images/graemlins/laugh.gif
/ GeoTextile Cloth #17
Mike,
With your situation with the water I would not do any of the draining. I would just level it all out with fines and then put your mats back on. As long as you use plenty of sawdust and keep the stalls fresh with good sawdust you should be ok.
/ GeoTextile Cloth #18
ditto what cowboydoc said - sand won't pack and will get depressions - I've used stoendust which is better but still not as good as running crush. The fabric won't hurt but I would go with stall mats on top of everything. If you get a good compacted (compacted being the operative term!!) base of crusher run, then put the stall mats over that you should have no problem and all the urine should get soaked up by your bedding which is what you want. Your goal should be to get the urine collected and out of the stall, not letting it sink in which will give you a perpetually wet underlayment since horsies put out 5-10 gal per day. (Least that's what they take in, guess not ALL of it comes out). If you dont' use mats you'll always be tweaking the flooring. Also if you get mats use the interlocks - just no comparison and no shifting.
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
2016 Kia Sorento SUV (A61574)
2016 Kia Sorento...
Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
Kivel 48in Forks...
ATTENTION! PLEASE READ (A64119)
ATTENTION! PLEASE...
2025 Fendt 1167 Vario MT Track Tractor (A63111)
2025 Fendt 1167...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
