Generator shed
/ Generator shed #41
How often will the generator be used? If it's for emergencies, I wouldn't spend the money on any fancy venting system. Just leave the door open when you run it if there is a concern.
If the system is auto start , who is going to open the door?
Even if the system is manual start , there is the problem of human error. Sooner or later the door will be closed on purpose or swing shut on it's own.
The system has to be designed fail safe and idiot resistant .
/ Generator shed #43
What happens if the door isn't opened? Exhaust is already going outside. There should be some sort of ventin just to deal with humidity. I'm at a loss why it's a big deal if it runs for awhile inside the room.
/ Generator shed
The exhaust is going to be piped out already. I have a 4" dryer vent and 4" 110v fan that will be plugged into the generator. If the generator is running, the fan is on. Even if the fan fails, there's still a 4" vent in each side. I built it much larger than the generator on purpose. Extra area for the heat instead of a box the exact size of the gen. It should be fine running with the door closed.
/ Generator shed #45
I too got a little confused on the watts. First you need to figure the element resistance which is 96 ohm. Then do the math at 120. Is there another formula without knowing the resistance?
/ Generator shed
600w 240v in the US is just 2 hots, not actual 240v but 120v, so 120v twice is 240v, 300w a piece. The motor just isn't working to it's potential. My pool pump is the same, I have 12-3 going to it, it's 240v, but that's just 2 120v's. I can run it on 120v just fine, just not as strong.
/ Generator shed
I've read that any/all gen's that aren't inverter types are dangerous for sensative electronics and should have an online UPS protecting them. All my computers and tv's have UPS's on them already, my grid power isn't exactly the cleanest. I hear my UPS's clicking fairly regularly as it is.
/ Generator shed #48
I run my water heater elements at 120. Less lime build up (= better efficiency) and I have never noticed a shortage of hot water.
I have decent quality alternators, yet run computers and com stuff on UPSes. I shut off various electronic equipment prior to switching over for (loaded) generator tests. Like entertainment stuff, dishwasher and the microwave. I have dedicated switches. No point taking chances on the crap that might be generated on switchover, if a pump or something happens to be running.
/ Generator shed
Growing up we had one like that, People couldn't shower back to back without it running cold half way through. With my wife and 2 daughters, we have an on demand hot water heater. They push it to it's limits though.
/ Generator shed #50
Tell them their hair looks so much better somehow when they wash in cold water.
2005 Suzuki King Quad 700 Fourwheeler (A61166)
2005 Suzuki King...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
GROVE RT 63S HEAVY DUTY HYDRAULIC CRANE (A60736)
GROVE RT 63S HEAVY...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
2015 Kubota L4701 (A60462)
2015 Kubota L4701...
