Generator requirements
/ Generator requirements #2
/ Generator requirements #3
In some ways the smaller welder needs a much or more generator than the larger welder.
That said either choice of welder is not a very heavy unit and something larger maybe considered.
On occasion a little old 10, 12.5 or 15KW pto generator sells cheap.
Portable gasser generator? 6500W absolute minimum and could be problematic. 10,000Wis a realistic minimum.
/ Generator requirements #4
Just looking at the spec's for the 180, 20 amps input current, 208 volts = 4160 watts. So any good generator 5000 watts or larger should do it.
Sizing a welder or motor is not like sizing a row of light bulbs.
Reactive power is a consideration.
So 10K running watts? It will be a gas generator, don't see many pto generators around here. I've found myself increasingly relying on battery tools and have decided it's time to buy some mobile power.
Ben
/ Generator requirements #6
Regular 5k gas genny will run either fine. Choose the 180C as it's 230V and lets you use all the generator windings.
2013 MITSUBISHI FE 4X2 S/A 20FT BOX TRUCK (A69167)
2013 MITSUBISHI FE...
Steiner 48in Front Loader Tractor Bucket Attachment (A64553)
Steiner 48in Front...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
PACER 2" PUMP, BRIGGS & STRATTON ENGINE, HOSE (A64276)
PACER 2" PUMP...
2020 HAULOTTE 3522A TOWABLE ELECTRIC BOOM LIFT (A65056)
2020 HAULOTTE...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
2018 GENERAC...
