Generator requirements
/ Generator requirements #2
/ Generator requirements #3
In some ways the smaller welder needs a much or more generator than the larger welder.
That said either choice of welder is not a very heavy unit and something larger maybe considered.
On occasion a little old 10, 12.5 or 15KW pto generator sells cheap.
Portable gasser generator? 6500W absolute minimum and could be problematic. 10,000Wis a realistic minimum.
/ Generator requirements #4
Just looking at the spec's for the 180, 20 amps input current, 208 volts = 4160 watts. So any good generator 5000 watts or larger should do it.
Sizing a welder or motor is not like sizing a row of light bulbs.
Reactive power is a consideration.
So 10K running watts? It will be a gas generator, don't see many pto generators around here. I've found myself increasingly relying on battery tools and have decided it's time to buy some mobile power.
Ben
/ Generator requirements #6
Regular 5k gas genny will run either fine. Choose the 180C as it's 230V and lets you use all the generator windings.
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
2017 Nissan Juke SUV (A61574)
2017 Nissan Juke...
UNUSED SDLANCH 14' BI-PARTING IRON GATE (A64281)
UNUSED SDLANCH 14'...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
DEWALT 30 GALLON COMMERCIAL AIR COMPRESSOR (A64281)
DEWALT 30 GALLON...
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
