Generator requirements
/ Generator requirements #2
/ Generator requirements #3
In some ways the smaller welder needs a much or more generator than the larger welder.
That said either choice of welder is not a very heavy unit and something larger maybe considered.
On occasion a little old 10, 12.5 or 15KW pto generator sells cheap.
Portable gasser generator? 6500W absolute minimum and could be problematic. 10,000Wis a realistic minimum.
/ Generator requirements #4
Just looking at the spec's for the 180, 20 amps input current, 208 volts = 4160 watts. So any good generator 5000 watts or larger should do it.
Sizing a welder or motor is not like sizing a row of light bulbs.
Reactive power is a consideration.
So 10K running watts? It will be a gas generator, don't see many pto generators around here. I've found myself increasingly relying on battery tools and have decided it's time to buy some mobile power.
Ben
/ Generator requirements #6
Regular 5k gas genny will run either fine. Choose the 180C as it's 230V and lets you use all the generator windings.
2015 PETERBILT 367 WINCH TRUCK (A60736)
2015 PETERBILT 367...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
2016 Godwin CD225 Silenced Dri-Prime T/A Towable Trash Pump (A61567)
2016 Godwin CD225...
Case 1020 25ft Draper Head (A61307)
Case 1020 25ft...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
