Gear pump breaks hydraulic filter
   / Gear pump breaks hydraulic filter #1
Caco4x4
Santiago, Chile
Jinma 404 (2023)
Hi folks, the backhoe gear pump hits and breaks the hydraulic filter.
Am I not connecting the PTO correctly?
Could I flip the filter upside down or relocate it, somehow?
Appreciate any feedback.
Caco
   / Gear pump breaks hydraulic filter #2
Am I looking from the bottom or the top? :unsure: Yes, the filter can be run with the cup down, as is should be. The picture you show looks to me like it would trap air. Also, find out why the pump is moving. Is it not secure? 😲
   / Gear pump breaks hydraulic filter #3
Is this the first time that you ever installed the back hoe or has it worked previously ?
Sorry the picture is sideways, PTO is left side and filter is right side.
I have used it quite a bit and noticed a dent in the filter, it grew until it punched a hole in it.
They are so close together that maybe the the body flexes and hits it.
It´s frame mounted.
   / Gear pump breaks hydraulic filter #5
Sounds like you either need to prevent the pump from rotating that much or move the filter whichever is the easiest or possible to do.
If y could spin the base and put the filter upside down, would that be ok?
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
2017 Ford F-550 4x4 Enclosed Utility/Air Compressor Truck, VIN # 1FDUF5HT6HED32921 (A51572)
2017 Ford F-550...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2005 Ford F-750 Crew Cab Heil 5 Yd Dump Truck (A51692)
2005 Ford F-750...
2014 D&P WELDING 16FT PRESSURE WASH TRAILER (A52472)
2014 D&P WELDING...
