Gear pump breaks hydraulic filter
   / Gear pump breaks hydraulic filter #1
Caco4x4
Santiago, Chile
Jinma 404 (2023)
Hi folks, the backhoe gear pump hits and breaks the hydraulic filter.
Am I not connecting the PTO correctly?
Could I flip the filter upside down or relocate it, somehow?
Appreciate any feedback.
Caco
   / Gear pump breaks hydraulic filter #2
Am I looking from the bottom or the top? :unsure: Yes, the filter can be run with the cup down, as is should be. The picture you show looks to me like it would trap air. Also, find out why the pump is moving. Is it not secure? 😲
   / Gear pump breaks hydraulic filter #3
Is this the first time that you ever installed the back hoe or has it worked previously ?
Sorry the picture is sideways, PTO is left side and filter is right side.
I have used it quite a bit and noticed a dent in the filter, it grew until it punched a hole in it.
They are so close together that maybe the the body flexes and hits it.
It´s frame mounted.
   / Gear pump breaks hydraulic filter #5
Sounds like you either need to prevent the pump from rotating that much or move the filter whichever is the easiest or possible to do.
If y could spin the base and put the filter upside down, would that be ok?
John Deere 310K Backhoe (A51573)
John Deere 310K...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
New Land Honor 5400 LB Ratchet Binder And Chains (A53002)
New Land Honor...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
