Gasoline polution
/ Gasoline polution #1
Anonymous Poster
Epic Contributor
Need some help quick, gotta go to a hearing and fight the new superstation they want to build upstream from me.
What is the name of that crap they put in the Oxygenated gasoline a few years ago that is now poluting aquifers?
/ Gasoline polution #2
MTBE, methyl tertiarybutylether
<A target="_blank" HREF=http://www.epa.gov/otaq/consumer/fuels/mtbe/mtbe.htm>http://www.epa.gov/otaq/consumer/fuels/mtbe/mtbe.htm</A>
Chuck
/ Gasoline polution #3
MTBE, and that's why we should all be using good ol' Iowa ethenol /w3tcompact/icons/grin.gif
/ Gasoline polution #4
Of course, no one has come up with anything that MTBE does to anyone. Ethanol, on the other hand, has been contributing to entertaining behavior for millenia. My vote's with Pitbull.
/ Gasoline polution #5
Yep, it's considered "super wet" or something like that, cant be filtered out by any means so far.
/ Gasoline polution #6
Charlie,
Shhhhh.... the wife doesn't know about my ethenol refinery out behind the wood shed /w3tcompact/icons/smile.gif
/ Gasoline polution #7
One of the villages next to where I live has been battling MTBE for several months now. The Federal Government has just stepped in to help. It seems that a gasoline tank has been leaking for an unknown amount of time. The MTBE polluted the local water supply. Plus, fumes from ground water has seeped into some basements. I tried doing a google search to get the news reports on it, but, my server is slow tonight. Maybe you will have better luck; check under 'Pascoag (RI) Water District - MTBE'. My home is not affected yet! But, I'm more than 15 miles away, so, I doubt it will "find" me. Good luck on your challenge...
/ Gasoline polution
Situation Update
Thanks for the help guys, MTBE landed like a rock in the middle of a farm pond! I had a few minutes before the hearing to read the Station's plan, and all it calls for is a holding pond, with a sand filter to eliminate heavy metals from spills.
The town engineer had never heard of MTBE, but got real scared real fast. The head of planning wasn't happy when I pointed out he would make everyone dependant on the aquifer a Test Dummy if the plan was approved.
The station owner now officially hates my guts, can't slide what he said to me past the censor.
Whole deal is now tabled for another month while more costly studying is done.
/ Gasoline polution
Forgot to mention
One of the Board members asked what MTBE is, and when it was put into gasoline. I explained that it is an ether compound gasoline manufacturers choose to use rather than Fine Iowa Corn alcohol.
Always try to put a plug in for the farmers!
/ Gasoline polution #10
Re: Forgot to mention
The EPA does come in handy at times.
Chuck
/ Gasoline polution #11
<font color=blue>...rather than Fine Iowa Corn alcohol</font color=blue>
/w3tcompact/icons/smile.gif/w3tcompact/icons/grin.gif/w3tcompact/icons/smile.gif/w3tcompact/icons/grin.gif/w3tcompact/icons/smile.gif
/ Gasoline polution #12
The EPA recommended the use of MTBE a few years back. It's coming back to haunt them. /w3tcompact/icons/smile.gif
EPA - worthless pieces o' ..........
Terry
/ Gasoline polution #13
It just amazes me that the EPA is worried about pressure treated lumber when MBTE leaks are polluting about 10% of the wells around here...
Timd
/ Gasoline polution #14
<font color=red>It just amazes me that the EPA is worried about pressure treated lumber when MBTE leaks are polluting about 10% of the wells around here...</font color=red>
Although I certainly don't have a desire to defend the EPA, or any other government agency's priorities, it is possible that it is rational to be more concerned about pressure treated wood than about MBTE. The wood is treated by injection of known poisons, although in amounts very unlikely to hurt anyone. For MTBE, a "Blue Ribbon Panel" studied the problem, after first deciding that it wasn't its function to analyze if there were any negative health effects of MBTE. Since it has been reported that MBTE in sufficient quantity might cause water to smell or taste a bit funny, the Panel went on to propose all sorts of remediation. Of course, MBTE was put in the gasoline in the first place to try to meet clean air standards.
Although we all would just as soon not have gasoline leaking out of tanks and getting into the drinking water, does anyone have a reference to any study that actually concludes that MBTE poses any danger to anyone?
/ Gasoline polution
Best info I know of on MTBE health effects. Nobody really knows much. Wasn't the first documented ground water MTBE contamination in 1996? You'll notice that CDC hasn't updated their document since 1997.
<A target="_blank" HREF=http://www.atsdr.cdc.gov/tfacts91.html>http://www.atsdr.cdc.gov/tfacts91.html</A>
/ Gasoline polution #16
That EPA link I posted earlier has links to just about all that's known about MTBE. The bottom line is you don't want it in your water whether or not there is a known health hazard. I've been on the receiving end of some pretty silly EPA rulings, but you really do have to step back and look at the whole picture. We all want clean air. We all want clean water. How do we get there without doing away with all the other things we also all want that give us the life style we desire? Apparently ethanol doesn't work as well as MTBE in reducing some emissions from IC engines, but perhaps the balance of toxicity vs function still favors ethanol. I'm really afraid the bottom line is that as long as we are dependent on IC engines, we're going to have these problems. I keep hoping that a real breakthrough in fuel cell design will occur. Wouldn't it be nice at some time in the not-so-distant future, to be able to tell the Saudis to try drinking their oil?
Chuck
/ Gasoline polution #17
Chuck:
I can't quarrel with what you say. The EPA seldom picks the right balance, and often acts on faulty information, but that's not to say I want MTBE in the water either, despite the fact there is no known human health hazard. It smells and tastes bad, and that's enough to try to get it out of the water, and then we don't have to worry about undiscovered long term effects. We also don't need another flood of litigation in which real medical or scientific evaluation is completely obliterated by the claim process.
Of course, once global warming does its work, MTBE will be broken down by the heat, and no longer a problem -- right?
/ Gasoline polution #18
Charlie,
Agreed on all points. Unfortunately, in this imperfect world, it appears that the only way to avoid ground water contamination by MTBE or any other gasoline additive means banning such additives. There are so many potential point sources for leaks that it would be impossible to prevent them. If it is true that some such additive is required in order to reduce the airborne pollutants produced by IC engines, then we are stuck between a rock and a hard place, so long as we depend so heavilly on these beasts. Is there an innocuous additive that will perform well enough to serve the function until we have a substitute for IC engines, or until the oil runs out? I don't know. If ethanol is it, I could live with a little in my water....I often do! I guess the microbes would metabolize it first though.
Chuck
/ Gasoline polution #20
ethanol, requires fuel to work the fields and harvest along with more energy to turn corn to another fuel. It does't make sense to use more energy then you would get in return. If they can find a way to get more efficent vehicles there wouldn't be a problem but ethanol is not and will not be an answer. They are doing good with the new hybids getting 70-80 mpg and that will be their best bet but it will take a few years to work out the bugs. Ford has a new compressed air system they plan for in a few years on their trucks that will help fuel economy quite a bit and not affect pulling power for their heavy duty trucks. Later
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2021 FORD RANGER (A60736)
2021 FORD RANGER...
2023 Chevrolet Express Van, VIN # 1GCWGBFP8P1104620 (A61165)
2023 Chevrolet...
1996 CATERPILLAR D6E CRAWLER DOZER (A62129)
1996 CATERPILLAR...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
