ovrszd
Epic Contributor
- Joined
- May 27, 2006
- Messages
- 33,727
- Location
- Missouri
- Tractor
- Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
Yep. I'd be a bit concerned on 4". Although I know of several that have stood the test of time. I wouldn't have any concerns on a 6" floor.You will likely be fine Deezler. You protected it during the most critical time with the water. Especially if it was not in the direct sun on a clear 95 degree day. The mixture water content will likely be what dictates the ultimate strength. A super wet 7 sack mix will never be as strong as a 7 sack minimal water mix.
When i poured my shop floor I dug out two 24" square by 20" deep holes where my lift would g and then did a monopour of a 4" slab over the entire shop floor. I also used 12" bolts in the concrete for the lift. I figured an extra 1/3 yd of concrete was cheap insurance... I was not comfortable with the directions stating that the lift would be fine on a 4" (which is frequently more like 3.5" with 2x4 forms).
I think the important thing is to properly load the lift. Failures come from too much weight forward/rearward of center and tipping the lift over one of those directions.
