Galfre Drum Mower Performance
/ Galfre Drum Mower Performance #1
Jerry/MT
Elite Member
North Idaho-The Palouse
New Holland TD95D, Ford 4610 & Kubota M4500
I recently purchased a Galfre drum mower (Model FR/G 190) and just completed haying. This is a first for me, never having done my own haying before. But that's another story.
There have been many comments about the requirement for a tedder to spread the cut grass out after mowing it with a drum mower. The implication was that if you buy a drum mower you need to also have a tedder to ted the cut grass. The Galfre has what they call their "Black Hole" conditioning system. It consists of some steel plates above the drum blade carrier that spin with the drum. It spreads the cut forage out behind the mower. Here's a picture below. All I needed to do was to rake this up and bale it, which I did. Some of the bales are in the background. I have to say that we are in the midst of a drought and my problem was the hay dried "too quickly". I had to bale in the early part of the day to have some moisture in the bale. So it's not a good test of whether the conditioning system speeds drying.
My conclusion is that the Galfre 190 with the "Black Hole" conditioning system does not require a tedder. (I have no personal connection to Galfre or Galfre dealers.)
/ Galfre Drum Mower Performance #2
With the hay spread out like that in Western Montana you don't need to ted. Just rake and you are good to go. Best time for me is to bale when the dew is coming off....or at night. If your tires get wet then quit baling...moisture meter helps. I'm in Eastern Washington and imagine weather is similar. Our problem is the weather can cause the hay to dry too fast when its spread out. Sometimes I cut early in the morning. Rake afternoon and I'm baling in the evening. Hay moisture is around 14%. Makes for some beautiful GREEN hay.
That was my point exactly. This drum mower does not require tedding because of the way it spreads out the cutting.
We are abnormally dry this year. In a normal year, most folks cut with moco's, then wait for a day, and rake and bale on the third day. Not this year! It so dry that people were baling the day after thy cut. It's so dry that there hardly any dew in the hay fields but the relative humidity is higher early in the morning. I like to bale so that I'm between 15- 20% moisture content but the hay in the windrows was more like 8-10%. The hay in the picture was cut the night before and mostly baled the next day.
/ Galfre Drum Mower Performance #4
How well did it condition? Also which tractor did you use to cut. I am wondering if their HP requirement is conservative or not.
From my original post:
"... Some of the bales are in the background. I have to say that we are in the midst of a drought and my problem was the hay dried "too quickly". I had to bale in the early part of the day to have some moisture in the bale. So it's not a good test of whether the conditioning system speeds drying. "
I used a Ford 4610 which is rated at 46 pto hp @1800 rpm and I operated @ 1600 rpm in 5th gear which I estimate as ~35-37 hp and about 4.5 mph. The engine rpm did not significantly droop in the heaviest grass down in the swales. The dealer said you could mow at the speed that would allow you to keep your seat and 4.5 mph was about my limit.
/ Galfre Drum Mower Performance #6
I found this older discussion when I did a Google search on drum mowers. I'm also interested in a Galfre G190 for my 30 ac of grass hay near Spokane. Like you, I prefer the "Black Hole" feature with no wind row. Are you still positive about the mower performance after 2 haying seasons?
I emailed the factory in Italy to inquire about a local dealer; none outside the Midwest. Giovanni of Galfre Italy says he can ship reasonably right out of Italy, but I don't have a price yet.
/ Galfre Drum Mower Performance #7
Just to offer an opinion here. After several year of having a PZ170 drum mower and a 9' IH 1300 sickle mower, when conditions are right the sickle is better as it lays the grass flat for drying. However if the clover or alfalfa get thick the drum mower is better. I need to teed the day after cutting if I use the drum mower for best drying,
Just my 02 here
I bought mine from Tractor Tools Direct (tractortoolsdirect.com) in Indiana and had to have it shipped here and I assembled it myself. It's a heavy machine and well made. Yes I am still positive about the Galfre 190 performance and this year was my third season with it.
I'm about three and a half hours from you so if you want to see the 190 up close let me know. Contact Tractor Tools Direct and see what they have available. I think they have other brands available and they are the parts source for Galfre.
/ Galfre Drum Mower Performance #9
I ted for 2 reasons: I have a 190, different brand made in Turkey. It's a 2 drum 6' cutter and my tractor is setup on 6'. The WW keeps the cut hay on the previous round out from under my tractor's tires and gives me a clean view of the edge to be cut for the next pass.
Second reason is that my fields are highly irregular. In the spring with spring grasses, wet clumps are everywhere and would cause me a serious problem if I didn't come back and scatter everything out. To not have to put up with a sickle, nor shell out for a disc moco, I'll take the tedder hands down.
/ Galfre Drum Mower Performance #10
I'm glad to see you're still enjoying the drum mower. I too have one, but without the conditioner. I really don't mind getting the tedder out, it goes pretty quick. Being that I live in Western WA, most of the time I really need to ted the hay anyway.
/ Galfre Drum Mower Performance #11
I致e harvested my grass hay in the past with a very old slow JD 7 ft mower/conditioner that is now at the end of life. I like the speed and low maintenance of rotary cutting rather than a sickle bar. I would like to harvest my timothy earlier in June rather than July when it is over mature and the seed heads have gone. Therefore I need fast drying to take advantage of the shorter intervals of dry weather between thunderstorms in June. Even with only a 7 ft mower my wind rows needed to be turned for rapid full drying; that痴 why I think the 澱lack hole feature would be helpful. Spread it out for rapid dry and then rake for baling. Haymaking for me is more of a favor to provide good quality grass hay for my horses and for those of a few friends. Everyone around here seems to like multiple crops of irrigated alfalfa, which is too hot for horses that lead a life of leisure.
Thanks for the offer of letting me see the Galfre, but the Italian factory rep sent me both the owner痴 and assembly manuals for the 190 so I think I have a good appreciation of how it is designed. Your feedback on the mower performance was helpful. Does the 澱lack hole feature spread the hay out evenly to your satisfaction?
Also I was thinking the offset 3 pt mount of the mower would be beneficial to trim light brush and grass from the shoulders of my logging haul roads as well as those areas of canary grass that I do not harvest for hay.
I looked on the tractortools direct webpage and they only list Ibex and Terra brands of drum mowers, but I'll give them an email.
here's a picture of our windrows after mowing. I posted these in a thread back in2015.
/ Galfre Drum Mower Performance #13
Here's mine previously posted:
The crop is Sorghum-Sudan Gotcha Plus. Mower is the Agrimaster 190 I bought from Small Farm Innovations many years ago. Today he has the 6 footer like mine, for $3875 as I recall. Even with this much crop to process, I still have a clean entrance into the uncut row so I don't have any holidays or over cut and on the other side, my tractor's tires aren't stomping on cut product. Also, note the square corner, no having to go back and clean up corners with a big X over the field.
/ Galfre Drum Mower Performance #14
Jerry/MT, thanks for the insight and for sharing your experience with your 190. We have a used Galfre drum mower in stock at the moment, and we currently stock and sell Terra drum mowers from Italy. The Terra drum mowers have a conditioning system as well that works great. I will attach links to our website for reference. BobTreeFarmer, if you have any questions, feel free to pass them our way as we are happy to help.
Tractor Tools Direct | Product Categories | Hay Mowers
Tractor Tools Direct | TL67 Standard Drum Mowers by Galfre – USED
/ Galfre Drum Mower Performance #15
Tractor Tools Direct | TL67 Standard Drum Mowers by Galfre USED
I was interested in the Galfre because of the black hole system which would spread rather than wind row my grass hay.
Could you tell me why you chose to drop the Galfre line and pick up Terra, both Italian companies I believe....Bob
/ Galfre Drum Mower Performance #16
Bob, great question. In a nutshell, Galfre had some internal setbacks causing some of the employees to break off into a new company. Along with these employees moving forward, they had improved on designs that hadn't made it to the end of Galfre production yet. These improvements to the machines also reflect the improvements to the internal workings of the company. Essentially Terra is the new and improved Glafre, in a few different ways. The Terra drum mowers have an updated and enhanced conditioning system that also spreads the hay rather than creating a windrow as most drum mowers will produce. The new Terra system works very well and makes more sense as a longevity improvement. The new system has tines that can be removed or replaced as needed.
/ Galfre Drum Mower Performance #17
So, the white plastic pieces in this picture the are the conditioning tines?
How well do they condition the hay compared to a roller conditioner (such as the one on our current hay mower, a NH 479)?
Aaron Z
/ Galfre Drum Mower Performance #18
Aczlan, that is correct. The white nylon pieces are in fact the conditioning tines. We have had great reviews and feedback from this design. They are durable and can be replaced unlike the Galfre design. You have the option of running the machine without them, and they truly work well. The difference is that this conditioning system due to its design, tends to impact and bend the materials being cut and then spreads the material out, all in one. Rather than other designs and models of conditioning systems. Other types being slightly more intensive, such as roller conditioners, or flail types etc.. Our design is similar to a flail type. With our system, it cuts, conditions, and fluffs by spreading out the bent and split materials. Feel free to contact us for more information and/or to help make the best decision for your operational needs. Thanks for the questions, and I hope this helps.
/ Galfre Drum Mower Performance #19
Where do you get your replacement blades from for your Galfrie?
