Fun with gates
/ Fun with gates
Ron,
Those hinges are the greatest. If you're ever on 380 heading east (when we go to Arizona every fall on vacation we run up to 380 and turn left. It ends at I 25 in New Mexico. Lots faster and more interesting than I 40.) Anyway in Farmersville there's a tractor place on your right named Pinky's. If you turn right on that street and go back behind Pinky's you'll be in an industrial complex. You'll see Wylie Drilling. Check out their gates. It's a thirty eight foot opening with the gates reaching nine feet tall in the middle. They weigh about fifteen sixteen hundred pounds apiece.
They're on those hinges.
Remember what I said about hundred and eighty degree hinges so the gate when open can be folded back against the fence. If you use those hinges what you'll find is your post and your gate frame will be just about a half inch apart with the hinge being on the inside of the gate swing.
You might start noticing something. Well you probably already have and have probably figured it out. But when you hit a gate or a corner you will see the fence hump up one panel back. The reason that happens is the gate post isn't deep enough to support the gate by itself. So the gate starts to pull on the post. The post starts to sink and push the bottom in away from the gate. This causes the top rail to hump up. It eventually lifts the second post back in line from the gate. Then you have the hump. The cure is a gate post with a hole too deep and having too much concrete. Too much is usually just enough.
There used to be some boys here in North Texas that put in miles of pipe and cable. What they did was used sandline cable. It's like they use on cranes etc, braided like rope.
They'd weld up one end. Then they'd pull it through the eyes on the line posts. The end post they'd have holes blown through where they could pull the cable on through. They'd pull it snug. Then they'd weld a large nut to the cable and cut off the cable. They'd tighten the cable by turning the nut. When they had it tight they'd weld the nut to the post.
Then mother nature would wreck havoc. I don't know why but the cable would continue to tighten up. I went on one job they'd done where they'd had a winding drive. They'd pulled the cable through end to end without any stops. When the cable started self tightening it literally pulled the bottoms of the posts in towards a straight line. The ranch owner called me for an estimate for a repair. He almost had a coronary. I not only had to bid putting in a new fence. I had to bid removing the old one.
But if you see a pipe and cable fence that's like a south Dallas paint job on a car (waving at you like you're family) check it out. Chances are it's that kind of installation.
If you look around you'll see all these fences with expansion joints. I didn't know you were supposed to do that if you welded it up right. So I never did. By the time I found out I was doing it all wrong I noticed that all my fences just didn't seem to need it.
On your question about pulling the bow out between posts above in "Projects". In your mind imagine the pattern left if your favorite female movie star planted a kiss on the top rail dead over a post. A wet open mouthed kiss. Now take your torch and make that lipstick pattern red. And then go on down to the next post. You're a sick puppy thinking thoughts like that.
Keep in mind, when you heat it up it's going exaggerate the problem. It's when it cools off that it does all the work.
While it's on my mind. I've meant to mention it to you a couple of times and have lost the thought. When I build a fence for horses especially and other livestock too. I try to avoid ninety degree corners. This is especially true the smaller the pen. When an animal feels cornered and reacts accordingly is when they hurt themselves or whatever's got them into that position.
/ Fun with gates #42
Thanks for all the great info again Harv, if you are ever out this a'way, let me know and I will buy you a few of your favorite beverage.
I have noticed several of the gate and corner posts sagging and leaning on fences around here, and the top rails above them bowing. I guess lots of people think that not quite enough is just right/w3tcompact/icons/sad.gif... I think that you and I are of the same school... To me, if I am going to the trouble to do a project, I am going to likely overdo it. Just ask my wife, who will go on and on about things like an 800 lb doghouse complete with tile floors, or about the spiderweb of conduit I have buried under our property running to every conceivable location I might need electric / phone / cable, etc.
I planned on using 4" gate posts buried 4' in the ground with 12" augered holes. My gates are going to weigh about 300 lbs each (all single 12' gates), and I plan to use the Antech Guardian hinges. For the corners, I am going to use 2 45 degree angles spaced 8' (one post) apart rather than to use any 90 degree angles. (I think you must have been reading my mind on that one).
Most of the pipe and cable fences I have seen going up around here now have those big springs inline on the cable, probably to prevent what you have been referring to.
Thanks for the description of the top rail heating technique. I will try it out on my new fence (starting to dig the post holes next week), and let you know how it works for me.
I am going to try out a modified way to do the saddle cuts on the pipe and was wondering what you might think. My idea is going to use bimetal holesaw bits sized the same as the OD of the pipe, and a modified drill press with pipe clamps on the base. I think that I might go through quite a few holesaw bits, but if I can get really clean cuts through the pipe, I think that the welding and sighting could go lots smoother.
/ Fun with gates
Since we're so close, sixty miles, nothing in Texas. You might consider either coming by my place and checking out my arcfit knotcher or stopping by Wylie Steel and looking at their samples I've done for them.
If you buy direct from Vogel you're looking less than a thousand. If you buy through some of the many wholesalers you're looking over that.
It cuts a saddle in schedule forty two and three eighths that Anne Frank could weld up.
If you brought over a piece or two of your tubing we could try it with the arc fit. If it worked you would be saving money over the holesaws let me tell you by buying an arc fit. And when you're done you can sell it to a local fence man for probably ninety percent of your costs. (none of them know about it. they think I've got a big punch press at the shop.)
I made this little wheel barrow looking thingy dingy. I mounted the arc fit to it over the wheel. I had this <A target="_blank" HREF=http://photos.yahoo.com/bc/wroughtnharv/vwp?.dir=/ben+brook&.src=ph&.dnm=contraption+for+construction.jpg&.view=t&.done=http%3a//photos.yahoo.com/bc/wroughtnharv/lst%3f%26.dir=/ben%2bbrook%26.src=ph%26.view=t>big job</A> where we had to cope (saddle) all these joints. It was a two rail schedule forty pipe fence with some sections thirty five feet off the ground. (check out the pictures).
The way you use it is you put the pipe in, pull down, turn the pipe a hundred and eighty degrees, pull down. You've got a saddle that's cleaner than the Pope's little black book.
/ Fun with gates #44
I'd love to come by and see your place. I should be getting the pipe dropped off near the beginning of next week. Maybe I could bring a piece of it by sometime next weekend?
I think that you are right about the holesaw bits going pretty quick, but I was thinking about being able to cut off posts which were already set. If I could make it work, it sure would make setting the posts a piece of cake.
Thanks again for all of your help.
Ron
/ Fun with gates #45
Harv, thanks for the detailed response....sorry to be so long in responding, but life is a blur these days...
<font color=blue>If you're where electricity is a pain to get then you can go low voltage and a screw drive.</font color=blue>
that solution sounds like what we need. Each of three gates are more than 2500 ft from the house site, so running AC wire is impractical....though we might still have to run some telephone wire or coax for camera, phone etc....
The gates are fairly heavy, but well below the 800 lbs you mentioned. There are no hinges, persay...rather, a 6" sched 80 pipe simply slides over a 4" (I think), with an ear type thing to keep it there. Action is actually pretty smooth, considering no hinge. I'll have to measure but I think they are 18 foot long with an angle at the base of the hinged side to hold up the horizontal. They close and lock against another 6" upright.
Ideally, we would have an opening/closing mechanism, intercom/security keypad, remote in the truck and 24/7 security camera tagged into a puter, all powered by battery backup....all three locations are heavily wooded, but we probably could configure a 10V solar panel to pick up 3 or 4 hours a day for trickle charge.
Security locking mechanism may be a trick. I really like your sliding bar idea, but am not sure about retrofitting now that the gates are already in place. I 'spose we could cut a window with a torch and spot weld cover plates afterward, but arranging and fixing brackets to guide the sliding bar inside the pipe might be a feat.
Any ideas where I could scare up the necessary components at reasonable prices?
Maybe if we sweeten the deal by also arranging for you to do up some artistic Bearpen logos to fancy up our plain jane gates, and you decide to take a vacation in the beautiful NC smoky mountains, and you decide a house call is in order, and the price doesn't make a man throw his hat in a crick......well then, a plan might could come together....did I mention trout fishing and how nice these mountains are?
Now where did I put that budget stretcher anyway....
/ Fun with gates
Ron,
Here's how I set my posts. Since I work by myself or with a day laborer I usually use a string if the lines are short. If they're longer what I will do is temporarily stand up plumb marker posts. One at each end and one in the middle. The middle one I place by stabbing it into the ground. I go back to the closest end and then sight down the side. I keep moving the middle post in and out until when I sight down the side of the end post towards the other end post I can't see it because of the middle post.
I will then start at one corner and with upside down paint if the ground is hard or with a claw hammer if it's soft I'll mark off lines perpendicular to the fence line on eight foot centers.
If when I get to the other end I'll stop about thirty feet away and measure. I will then try to divide that measurement so that I have less than eight but an even number. Sometimes I have to come back more than thirty feet to get that number but what I'm after is not a short section at the corner. That screams to even the varmints that either a rookie or someone who didn't have much pride set those posts!
Once I have the eight foot centers marked I pick up a pair of post hole diggers. I hold them from the tops of the handles over the mark. I look down one side. I move the diggers making sure I'm holding them by the handles high so that they're hanging plumb in and out until the edge of the diggers lines up with the center marker post and the one at the far end. When they line up just perfect. You'll know. I drop the diggers and they will leave a mark. If I am using paint I will mark across my eight foot center mark with the paint. I do this over each mark. Now when I hit the marker post I turn around and sight back to the other end post. What is important is if I sighted down the north side of the line even though I'm looking back the other way I make sure I'm sighting down the north side.
I dig my holes. Now what you might want to keep in mind is the width of your posts and allow for the placement of the center of your auger accordingly. In other words if you're posts are two and a half inches o.d. and you're going to leave your original marker posts up to help with your setting (good idea) you might want to center your auger an inch over so that it's center of the post line and not center of the north edge of the fence line.
I set my corner posts. I set them one inch higher than nominal fence height. I use a marker that will contrast with the post to mark down the diameter of the toprail plus the one inch. I make a nice horizontal line that is easy to see at a distance. I knock down the center marker post and get it out of my way.
I go to the second post in line from the end I'm going to start setting. I line it up the same way I did the marking post.
BTW the posts are always lined up with a torpedo level holding them plumb!
And don't use the magnetic side!
The devil will get you for that!
Actually what will happen is if you're not triple careful you'll pull your post out of plumb removing the level.
I will usually put a little mixed concrete in that second post to hold it in place while I set it. Again, plumb it up, check it, move it plumb, check it, etc.
When it's dead on where when you look down the side you can't see the other end post unless you move your eye a half inch off line you're doing good.
Fill the hole with concrete. Since you're doing livestock fence I suggest leaving the concrete down four to six inches from the top of the hole. The livestock will walk the fence line. If the path they wear down erodes the dirt around your post and the concrete is higher then you have a potential hazard to them. And if they don't wear it down and you weed eat it will save you string hitting the smooth pipe versus the ragged concrete.
Now you have the second post set for line. Go back to your near end post. Hold your plumb for level at your line you made. Sight over the top of the level towards your other end. What you're wanting to see is the bottom of your saddle and just barely your corresponding mark on the other end post.
Did I mention you presaddle all your posts? I should have.
You move up and down the second post until it's perfect. Each time you move it you check if for line.
I know it sounds busy but you only have to do this one time a line.
Once it's perfect then you go to post between your second post and your near corner or end. Holding that post plumb with your torpedo level you move it in and out of line until you can see either nothing of the far end post or just a hair of it. You put your concrete in the hole. Now you double check your post for line and pull it up for height. What you're looking for is to barely see that horizontal line over the bottom of the saddle of the post your'e setting. When it's perfect you step around the post and look back at the other end to verify it's perfect that direction too.
When that one's perfect then you're home free. All the rest of it's pure work plain and simple. You pick up your third line post and sight over the saddle when it's plumb and in line towards your near corner or end. When it's perfect you step back to your previous post and double check it by looking down over it to the far end.
This might sound like too much work and too complicated. I have folks all the time tell me that it's too hard when it's so easy to stretch a string and set all the posts high. Then you come back and stretch another string tight mark your posts and cut them all with a torch and then saddle them with the torch and a sure cut.
You can usually see when they've done that. The fence will have a bow because any wind that blows will catch string. It also so sags so you will see where the middle of the section is slightly lower than the ends.
I spend fifty percent longer setting my posts this way than they do with the string. But when it's time to come back welding in I have perfect saddles dead in line for height and line. I just lay in my top rail and weld it in. I'm done before they are and my job looks a hundred times better. If the customer wouldn't know the difference then they're not the kind of customer I want anyway.
I like working with picky people. Picky people appreciate quality. Sometimes you have to educate them but generally they're capable of learning too.
I once was just cleaning up from setting a line about four hundred feet long. An old boy drove up, got out of his truck, looked down the saddles, and shook his head. I don't think I ever really convinced him that I'd done it all by eye. To this day I'm sure he'll tell you I am the best man he ever seen with a string.
But setting posts this way is a good metaphor on life. The whole secret to a perfectly straight line is making sure each post is perfect and then leaving it to go to the next. It's sorta funny how if you've made sure each one is perfect then when you get to the end it's all perfect and it was done one at a time.
Sorry for the lengthy diatribe. But there's few things finer than looking down a straight line of posts and knowing that you're the luckiest guy on the planet.
/ Fun with gates
Ah man you're talking my dream.
If I had my dream it would be this. I'd like to have my truck and a nice travel trailer. My wife loves working and traveling with me. What would be the ultimate dream would be able to travel this great nation with all it's wonderful folks and take along my tools.
We could park the trailer close to some place like yours. We, you, me, yours, mine, would start off with a good breakfast and then we'd get out there and get after it. We could build what you want the way you want as long as I approved of course and have more fun than any human is allowed to have.
I have more tools than just about anyone I know. I'd have the tools and a little bit of knowledge and with your dream and energy it would be fun.
About five years ago We took Moby, the truck, and visited relatives in Arizona. They had it all set up where the concrete truck came in early the next morning. One of the highlights of my life is standing there mud boots tamping concrete and looking around to my dad, his sister, his brother since passed, his brother in law, my wife, my aunt too, all of us covered with concrete and pouring slabs. I was the youngest and my dad's brother, since passed, was the oldest.
The next day I was cutting and welding and we were putting up a killer storage building and a patio cover.
There's few things finer than good work and kindred spirits doing same.
The biggest hurdle to modifying the existing gate is find that spring combination. I like to use big succor rod for the bolt. It's too hard to cut with anything but a torch and it don't bend easy.
The other stuff is just details. As for the twelve volts what I advise my customers to do to prolong the life of the batteries is to rotate them with those in the bass boat etc.
/ Fun with gates #48
Harv,
First I would like to complement you on your work. Very, very nice. Also thank you for sharing with all of us. Some consider me one of those picky carpenters and you are exactly right when you say that the customers that don’t know the difference are not the ones I want.
As I read your method of setting posts and not using string I was thinking that I would be using my laser level. Have you ever considered one? It would seem like it could be a real time saver in your business. In resent years they have become very reasonably priced and I find them useful from grading to trim work.
MarkV
/ Fun with gates
Mark,
It's a lot faster than it sounds. Actually even with using lots and lots of concrete I can set thirty to forty posts a day all by myself. That's laying out, digging holes, settin' them in concrete. With a good helper I can easily double that. But good helpers usually only last one day. (grin)
I've been in love with lasers for years. I have a David White Transit that's not getting much use cause I have a good rotary I use for setting grade on a lot of jobs.
Have you got one of those good laser torpedo levels with the three way lights? I love it. I can shoot a perfect ninety without the old three four five and over a point too.
In the old days of laying out a wood fence on uneven terrain the fence foreman would set up on one post and shooting over his torpedo level sight in a grade mark to the helper at each post.
Then I got my transit and found out it was so much easier. Then I got the rotary laser and got rid of the help. I can set that puppy up in the middle and walk around with the target marking each post. And once you have a reference mark the rest of it's junior high math.
What you might find interesting is how we set posts like for a tennis court. The corners and ends are set at twelve foot. The lines are set three and a half inches shorter to allow for the top rail. Most folks set posts high and then send a helper around with a ladder and a portaband after the grades are shot to cut the posts. We do it different. We sight them in for line and height.
Since I'm only five eight looking over a post twelve feet high is a mite of a problem. So I make a mark down six and a half feet with a sharpie for the ends and corners and six feet two and a half inches down for the lines. We use the sharpie lines for setting height. Once you get used to it you feel sorry for the guys on the ladders with the portaband.
I have a theory about sharing what you know about work. It's just the thing to do. And I've been most fortunate in that I've had the pleasure of working with some of the pickiest customers and craftsmen in the world I do believe. And even though each event was painfull from one perspective the lesson learned was always invaluable.
I try to keep the enthusiasm for work up for myself and for others. I look at these young guys and man there's been times I wished I'd had someone like me to hang out with. I could have learned all he knew in a short period of time and been off to conquer the world.
The biggest problem I see today is very few people understand what quality is. And it's not their fault. They have no reference point from which to start.
Used to be your father would be a craftsman. He might not know squat about any other trade but he knew quality in his own. And that point of reference gave him a perspective from which to judge other trades. He knew good work when he saw it.
These dot com millionaires and the tech kids have to be educated by us. A couple of years ago a neighbor came to me and asked about a fence like mine. I explained that the best thing to do was to allow me to help him buy the materials at my cost and I'd give him the name of some guys who were production fencemen that did okay work.
He came back wanting a fence like mine or one of the ones he'd heard I built in the city. I shaved the cost a bit cause he was a neighbor and gave him a quote. He gave me the job.
This young man was a techie making very decent money. But the reason I got the job is his father came in from out of town to visit. The kid showed him around. His dad told him to go with quality. His dad educated him and I benefited.
But without him being educated he'd never spent twice the price for a fence that his friends would have.
/ Fun with gates
<font color=blue>Maybe if we sweeten the deal by also arranging for you to do up some artistic Bearpen logos to fancy up our plain jane gates, and you decide to take a vacation in the beautiful NC smoky mountains, and you decide a house call is in order, and the price doesn't make a man throw his hat in a crick......well then, a plan might could come together....did I mention trout fishing and how nice these mountains are?</font color=blue>
Hush. Please. I might not be easy, but I can be had
/ Fun with gates #51
Harv, I was thinking about using 4" x 4" x 8' PT for the 194 posts I have to put in around our new 3 acre horse pasture. I've never put a fence in before /w3tcompact/icons/smile.gif but I have a 3ph post hole digger, my tractor and am ready to start. Can you offer a rookie some advice and instructions on how to do it right? Thanks.
/ Fun with gates #52
Harv,
I should have known that you would have jumped on the advantages of lasers. Like you I have a couple of builders levels that have not seen any use for a number of years. I am also becoming a laser junkie and am up to three now. They sure can be a time saver for many projects.
MarkV
/ Fun with gates
Morning Mike,
I'd have a couple of questions. The first would be about the overall construction plan. What kind of fence will it end up being? Are you going to have posts and wire, posts and rails etc?
The problem with pressure treated is so much of the time they use the cheaper cuts of wood. So you're starting off with more knots etc. And because of that the board you buy might not be the board you end up with. If you don't believe me drive through a fence company's yard and notice the four by fours that would serve better as modern art versus being a fence post.
A fence contractor buys the posts by the bundle and has to eat the culls. He gets a better price because first he's buying quanity and secondly because he understands he gets the good, the bad, and the ugly.
So if you're buying quanity remember there's no culling and be sure to allow for at least ten percent bad. Chances are you won't have that many bad but...........
If I was in you shoes I might try dealing with the commercial manager of a box store like Home Depot or Lowes. I'd try to get the lowest price on a quanity purchase (they will negotiate even tho they deny it) with the understanding you get to bring back and get credit for the culls.
If you're picking and choosing as you're purchasing remember that on pressure treated you're wanting the lightest posts, not the heaviest. Chances are the lightest have dried out and are in their final stage of warpage. The heavy wet ones are like a twelve year old choosing a career. No one knows what direction they're gonna take off on.
What I do with my customers on laying out a pasture is try to keep the big picture in mind. That is consider what you're wanting to have after all the adventures of building are complete. Then even if you're doing just a small part those small parts will add up to a big picture. No sense in ruining it by jumping out there and building something just to be building something.
Be aware of the property lines. In residential situations I try to have the fence line two inches on the inside of the property line. If it's on the property line the neighbor owns their side and can do whatever they want with it, plant ivy, paint it purple, etc.
But on farm and country fencing, especially if we're talking five and ten acre parcels I like to have it in a foot. That way if your neighbor brings in a cribber, horse that nervously chews on wood, you can run a hot wire and they can't say squat. Or if their horse has a personality disorder and just wants to fight with your animals you again can put up a hot wire on their side with impunity.
If there's anyway possible do your corners in either radiuses or cut them at forty fives like Ron and me were talking. If bad dogs get in the pasture they can corner the horse. If there are no corners the horse is less likely to be trapped.
You can rarely have too many gates. If you're thinking about eventually having another pasture adjoining or a drive somewhere put in the gate opening even if you don't put in the gate now. Remember, the best way to keep people from climbing the fence is to provide them a gate. That somebody climbing the fence cause another somebody didn't put in a gate in the most obvious place might be your wife.
Another thing I always try to do. I try to get the wife's input. I know they're the little woman but they are so practical. And they think of little things that you and me wouldn't in a million years or until it jumps up and hits smack in the face.
Another thing I try to do with customers is do the worst case scenario. There's a big storm coming in and we want to get the livestock under cover. Let's build the fence so that's doable by one person if possible.
Remember to build your gate openings smaller than the gate so if the latch is undone the animal has to not only pull the gate open but walk around it to get out.
I like to use offset hinges that make the gate close on it's own when I can. Gravity works, most times.
/ Fun with gates #54
Harv, thanks so much for the reply! I hadn't thought about the 45 degree corners, a great idea. Someone down the road had a new horse cornered by the two original horses. In the scuffle, the fence was broken, they got out onto a highway. Not pretty.
<font color=blue>The first would be about the overall construction plan. What kind of fence will it end up being? Are you going to have posts and wire, posts and rails etc?</font color=blue>
Initially, I will have four strands of white <A target="_blank" HREF=http://www.horseguardfence.com>Horse Guard Fencing</A> tape with a Parmak charger. I was going to use 4" x 4" x 8' posts spaced 8' apart in the event someone, i.e., the wife /w3tcompact/icons/smile.gif wants to put up 1" x 6" rails at some time. Right now, we're stretching the budget just for the posts and tape, much less 4 rails. The best price I got on the posts (no haggling yet) was $5.19 each at 84 Lumber. 194 posts to enclose 1,433 linear feet of fence.
/ Fun with gates
This evening we loaded up the door frame for the house where I'm building the front doors.
/ Fun with gates
This frame looks pretty big sitting on the trailer.
/ Fun with gates
But once we got to the house it didn't appear big at all. It fit in right where it was supposed to. Funny how that works sometimes and sometimes not.
I don't think you can see the details but there are thousands of dents and dings in the metal. Four, sometimes five, hammers with different patterns and one old man's right arm just getting after it.
It's sorta interesting how things work. You have a forty to fifty dollar hammer and you hit something perfectly wrong and a chip flies out. You push the dirty words out of the way so you won't trip over them and grab another hammer.
Then one day you want to have a distinctive ding kinda dent and low and behold, lemon becomes lemonade. Life is so good it's shame you only get one chance.
I don't know if you can see the bowls along the sides and in the top of the frame. They're there to hold flowers. There is no pattern to their placement. The customer looked at that and gave me a questiony kinda look.
I explained their placement as a reflection of my feminine side. You know the mother nature part of oneself. I pointed out to him that mother nature doesn't put two flowers on side of a plant and then get all in a tither to balance it out with two on the other side. If she didn't get excited about balance then why the heck should I?
He informed me that I was the artist so it must be okay. Have I got it made or what?
Don't say it harv.
BTW harv it you look back in that mess you will see a rusty looking frame with a curvey kind of shape. It's a swing. I got my head a little cockeyed one day and made a swing out of chainlink materials, just for grins. I planned on putting it at a wholesalers so all my cohorts in crime could rest a bit on me. But the one inch mesh eleven gauge chainlink turned out to be so comfortable I kept it for myself. Wife wants to move it up to the house. But I ain't finished with it. I sometimes have a problem finishing things, character flaw, first to brag about it.
/ Fun with gates #58
<font color=blue>I don't think you can see the details</font color=blue>
We sorta can, but I'm wondering if there was supposed to be one more picture showing the installed frame. If not, I sure wish there was.
Looks danged impressive on the trailer.
And BTW -- who's the geezer on the skidsteer? (And if it isn't you, please replace "geezer" with "fine-looking gentleman"). /w3tcompact/icons/eyes.gif
<font color=blue>Don't say it harv.</font color=blue>
"IT!!!!!" /w3tcompact/icons/grin.gif
Hey, that chain link swing sounds interesting. Any chance of some better picts?
<font color=blue>I sometimes have a problem finishing things</font color=blue>
Cripes, Harv, I can already tell that you've finished more projects than I ever even started.
What's next?
/ Fun with gates
<font color=blue>What's next?</font color=blue>
The mind has been working harv, working.
Here's a sample.
In my youth I had to have a trailer that would haul my racecar. I didn't have any money to buy one so I made one. One of the problems with race car trailers is the car starts out real close to the ground. And often they are damaged racing and must be loaded and unloaded with even less ground clearance. So I made it a tilt trailer. It was ugly but trick. So I'd like to find some old pictures of it and put them here along with a description of how it was made so some folks can venture into uniqueland. It's not a bad place, rather fun really.
I see there's a real desire amongst some of the folks that let their fingers do the walking to TBN for a demonstration on how to bend heavy wall tubing for say like ROPS. I've figured out how to do it where the handier types can duplicate the process at home or in the shop of their new very best friend.
One of the problems with wagon design, your old standard little red wagon or old farm hay or grain or cotton wagon is you have to allow for the swing when doing a turn. A bud of mine loves to restore and work on old cars. So he needed to have a buggy to walk through the old car swapmeets to haul his new found treasures. So he designed and built one. It has no swing problem. The back wheels trail exactly in the tread of the front wheels. I'm sure he wasn't the originator of the design but that doesn't mean the design isn't the trickest thing since putting pockets on shirts.
I'd like to do a thing showing how to make such a wagon. If we get around to it about next spring it'll be perfect for a Mother's Day gift.
I want to do the receiver thing for the FEL I've talked about. I've even arranged for a Kubota tractor for my demonstration (he gets to keep the thingy dingy, nothing's free it seems anymore).
I'd like to build some home made forks and hay spears.
And you know in the old days the farmer's number one bud besides the bank was the blacksmith. I'd like to get with some local smiths that are up on the old ways and do a demo on how they shaped and made plows etc. Just the other day a friend whose dad was a smith called to find out if I could resharpen and shape the blades on his brush hog. I have all the equipment and bud remembers as a kid all the farmers bringing in their blades for his dad to tune up.
That would be fun.
I'd like to build a project green house. I already have one. You see about eight years ago I poured a slab for my little building in the back yard. At one end I poured a section lower than the building slab five by ten, building ten by twelve. I shaped a drain and ran the drain out to the edge of the slab and capped it.
Then about three or four years after that I put in all the french drains in the back yard and ran a drain to the street in front. At that time I picked up the drain from the future green house and put it into the drain system.
A couple of years ago I worked on a multimillion dollar house of one of the biggest jerks to ever walk the face of the earth. He put both "R's" in SORRY, almost added a third. But his master bath was being remodeled by some buds of mine. I told them not to break the glass when they removed it. That glass and some recycled redwood planking facilitated our green house I built this year.
But I know there are some guys out there that would love to build a nice green house. I think we can build one that's economical and durable. Mother's Day again comes to mind.
I've been watching the thing up there on pipe pulling. For the life of me I can't remember the details but I made a little machine for a friend's company for burying cable tv and telephone drops. It worked real well. But it just wasn't enough better than the old way to justify converting over to it. But it was a total original design. I just can't remember the details. That's a problem I have, remembering, gets me in trouble all the time.........
I think we could have some fun with different ways of doing things like feeders and furniture too. I'd also like to do some rock stuff.
On that fountain in the project at the photo web site I use we get to see what happens when a mind does it's own thing and a customer goes with it. I put that fountain together with epoxy, big rocks, little rocks, and stainless steel. The main rock, sorry boulder, it was sensitive about that, weighed four hundred pounds. The way I put it in there it's actually this large coffee table with a hole drilled from the bottom.
In this hole fits some clear plastic tubing attached to a pump. I went through three pumps to find the one I wanted, that did what I wanted to happen without me knowing exactly what I wanted to happen but I knew I would know it when I saw it, get it?
At that point I placed a big rock on top of the boulder, the one with feelings about names. I turned on the first pump. It was like the spray bar on one of those big water buggies at a construction. That dog mighta hunted. But not in a nice neighborhood like that. So I studied a bit. I needed the water to come out with some volume but not straight out all mad like.
I made a bowl in the bottom of the top rock. I figured that bowl would confuse the water under pressure just enough that it'd come out between the two rocks more like a staggering drunk than a sprinter with the devil on his tail. It worked. Never ever doubt the power of confusion.
Then I decided that we needed a little water coming out from the bottom of the statue standing on the rock above the boulder with the inferiority complex. So I drilled a smaller hole in the bowl. That worked.
But we had some splashing. So I drilled some smaller rocks an epoxied some half inch stainless pins in them. I drilled corresponding holes in the boulder to break up the flow and cut back on the splashing. That worked.
I have a saying about luck. "I'd rather be lucky than good. Anyone can be good. That only takes working at it."
With the fountain I got real lucky. I'd picked out the rocks at the landscape products vendor. They were just rocks with a color approximately the color we had around the place. But when the water got going it turned out there were these really neat lines of quartz running through the rocks that were like chrome on a Mercedes. You wouldn't think it'd be appropriate but when you actually see it sometimes it's alright.
I gotta go.
Someone's complaining right now about me chewing up all this bandwidth meandering.....
/ Fun with gates
Here's some details on the installed door frame.
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2016 Manitou MHT10230 50,000lb. 4x4 Rough Terrain Telehandler (A60352)
2016 Manitou...
(2) Firestone 282-26 Tires w/Rims (A64127)
(2) Firestone...
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
2008 WELLS CARGO 16 ENCLOSED T/A TRAILER (A65643)
2008 WELLS CARGO...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
