Fueling skid steer for light residential guy
/ Fueling skid steer for light residential guy #1
patrailer
Kubota
I use my bobcat around my house for various projects. It's a T595. I use it a few times a year.
How do light residential guys keep there machines fueled? Filling the 5 gas containers seems like a lot of work. I was thinking about getting a transfer pump and just pumping straight out of my trucks fuel tank in to the bobcat. Is this a thing?
edit something like attached picture. Drop the supply side directly in to my trucks gas tank? Is that foolish to think that hose will reach down in to the tank? I am guessing there is some anti theft stuff to prevent that from being done? This is 2011 chevy
  • FireShot Pro Webpage Capture 255 - 'VEVOR Fuel Transfer Pump 12V 10 GPM 1_4 HP Diesel Pump wit...png
/ Fueling skid steer for light residential guy #2
amazon battery operated pump for about $12. Mines lasted 3 years.
What do you pump out of
/ Fueling skid steer for light residential guy #4
I have my Kubota tractor, Cat Skidsteer and a Bobcat mini x. I probably use 50/75 gallons a year and its a pita to load them up on a trailer to go fuel them, So I goy a 45 gallon L shaped tank that would go in the bed of a truck and put it in a small 4x6 trailer with a battery operated pump. When I need to fill something, I just connect my battery jump box to the pump cables. When the tank gets low, I just bring it to the station and refill. A couple times I have had the heating oil guy fill it while they were filling our house tank.
/ Fueling skid steer for light residential guy #5
I'd stay with a fuel caddy of some sort, out there in Cali red diesel (off road) is about 50 cents a gallon cheaper than road fuel..... BUT I'm fueling a SCUT, and only burn maybe 20-25 gallons a year so two 5 gallon cans works for me....
/ Fueling skid steer for light residential guy #6
My 2007 GMC has anti theft stuff preventing siphoning, I've already tried it.
/ Fueling skid steer for light residential guy #7
/ Fueling skid steer for light residential guy #8
275gal heating oil tank with a hand crank transfer pump. Also just a home owner. Filled the tank at $1.28gal in 3/2020 and it's still 1/2 full. No algee or water in it. I do have a goldenrod filter on it.
The whole setup cost under $120.
/ Fueling skid steer for light residential guy #9
Go big or go home. ;) I bought a 100 gal steel tank. I take it to town and fill it a few times a yr.
/ Fueling skid steer for light residential guy #10
I use about 50 - 60 gallons a year and have few 55 gallon poly drums & 12V GPI Diesel fuel pump, fill up empty drums when the off-road Diesel price is low and use the same pump to transfer the fuel to drums in the barn.
3 - 4 drums in the back of pickup truck are filled at a local station no problem.
/ Fueling skid steer for light residential guy #11
For that level of use, most just use 5 gallon jugs. It's inexpensive, easy to do and certainly less mess and hassle than trying to insert and remove a diesel covered hose into and out of the fuel tank on a pickup.
/ Fueling skid steer for light residential guy #12
I tried that pump and hose solution. Kept the whole pump and hoses in a 5 gallon pail. It worked fine the first time, but what a fuel soaked mess to keep it all clean.
For what I do, several 5 gallon fuel containers are a better solution.
I did buy a number of containers with poor caps & spouts until I discovered the heavy poly "no-spill" type.
They are expensive, but often on sale. The spout caps are sold separately for about $12. Get a spare.
golf cart (A56859)
golf cart (A56859)
(100) UNUSED KJ K0311-10' GALVALUNE CORRUGATED (A60432)
(100) UNUSED KJ...
1994 JAGUAR XJ-SERIES (A58214)
1994 JAGUAR...
UNUSED SDLANCH SDLWC WOOD CHIPPER (A60432)
UNUSED SDLANCH...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2016 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2016 CHEVROLET...
