Fueling skid steer for light residential guy
/ Fueling skid steer for light residential guy #1
patrailer
Kubota
I use my bobcat around my house for various projects. It's a T595. I use it a few times a year.
How do light residential guys keep there machines fueled? Filling the 5 gas containers seems like a lot of work. I was thinking about getting a transfer pump and just pumping straight out of my trucks fuel tank in to the bobcat. Is this a thing?
edit something like attached picture. Drop the supply side directly in to my trucks gas tank? Is that foolish to think that hose will reach down in to the tank? I am guessing there is some anti theft stuff to prevent that from being done? This is 2011 chevy
  • FireShot Pro Webpage Capture 255 - 'VEVOR Fuel Transfer Pump 12V 10 GPM 1_4 HP Diesel Pump wit...png
/ Fueling skid steer for light residential guy #2
amazon battery operated pump for about $12. Mines lasted 3 years.
What do you pump out of
/ Fueling skid steer for light residential guy #4
I have my Kubota tractor, Cat Skidsteer and a Bobcat mini x. I probably use 50/75 gallons a year and its a pita to load them up on a trailer to go fuel them, So I goy a 45 gallon L shaped tank that would go in the bed of a truck and put it in a small 4x6 trailer with a battery operated pump. When I need to fill something, I just connect my battery jump box to the pump cables. When the tank gets low, I just bring it to the station and refill. A couple times I have had the heating oil guy fill it while they were filling our house tank.
/ Fueling skid steer for light residential guy #5
I'd stay with a fuel caddy of some sort, out there in Cali red diesel (off road) is about 50 cents a gallon cheaper than road fuel..... BUT I'm fueling a SCUT, and only burn maybe 20-25 gallons a year so two 5 gallon cans works for me....
/ Fueling skid steer for light residential guy #6
My 2007 GMC has anti theft stuff preventing siphoning, I've already tried it.
/ Fueling skid steer for light residential guy #7
/ Fueling skid steer for light residential guy #8
275gal heating oil tank with a hand crank transfer pump. Also just a home owner. Filled the tank at $1.28gal in 3/2020 and it's still 1/2 full. No algee or water in it. I do have a goldenrod filter on it.
The whole setup cost under $120.
/ Fueling skid steer for light residential guy #9
Go big or go home. ;) I bought a 100 gal steel tank. I take it to town and fill it a few times a yr.
/ Fueling skid steer for light residential guy #10
I use about 50 - 60 gallons a year and have few 55 gallon poly drums & 12V GPI Diesel fuel pump, fill up empty drums when the off-road Diesel price is low and use the same pump to transfer the fuel to drums in the barn.
3 - 4 drums in the back of pickup truck are filled at a local station no problem.
CHANDLER 500 BBL FRAC TANK (A60736)
CHANDLER 500 BBL...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
MMS 800 Remote Control Lawn Mower (A60463)
MMS 800 Remote...
UNUSED INDUSTRIAS AMERICA HYD POST PULLER (A60430)
UNUSED INDUSTRIAS...
2025 Kubota KX040-5 (A60462)
2025 Kubota...
