Oil & Fuel Fuel System Heater ????
/ Fuel System Heater ???? #11
You just need the right additives in your fuel, anti-gel or enough mix of #1, or even straight #1, to make it flow. Your problem is NOT that the fuel is too cold to ignite, the pump pressurizes it quite enough to make it warm. Your problem is the fuel is too thick to get from the tank through the filter to the pump - no flow. Once your tractor runs for a while, diesels recurculate fuel so your fuel should slightly warm as it flows around.
Any kind of heater around a fuel tank makes me kinda nervious. Here in Minnesota on my farm & the one's around me, we frequently operate at ten below F, as cold as 20-30 below a few times. In northern MN & farms in Canada it's common to operate at 20-40 below F. There should be no need to heat your fuel if you have planned properly & have strong enough additives/ #1 fuel.
This is like anti-freeze in your cooling system. You can't wait until it freezes up to deal with it - plan ahead, get the fuel right. No need to fool around with extra heaters or fuel temeratute.
Just the block heater for the engine. In a shed really helps. Winter oil. clean fuel filter, & #1/ additives to keep it flowing at your temp.
--->Paul
The fuel I use is directly from the Irving pump so I know it has some winter additive in it plus I have added some of my own. The tractor does sit for several days at a time un-used and un-run.
Maybe, as has been mentioned, I need to thin the fuel further by cutting it with kerosene.
/ Fuel System Heater ???? #13
Mark, I've been running diesels for many years, and only twice I've had a problem in frigid temps. Once because I expected 5 yearold batterys to work like work like new ones, and more recently when I got a load of nonwinterized fuel in one of the trucks. Since then I make sure that I add an antigel fuel treatment everytime I refuel in the winter regardless of temp at the time. I'm in Michigan, and you'd be surprised of the temp swings we can get.
Between using a block heater and treated fuel you really shouldn't be having any big problems. By the way, go to a truck stop like T/A or the like and get the fuel additive, it will be a whole cheaper than at a gas/fuel station.
Finally, NEVER put anything but the correct fuel in your tank, and NEVER use ether. We all hear how the big truck drivers supposedly mix a few gallons of gasoline or kerosene in thier tanks, but just talk to one of them at the local truckstop and you'll find thats just another urban legend, at least with the modern diesels. /forums/images/graemlins/shocked.gif
/ Fuel System Heater ???? #14
Hi
When it’s too cold for the tractor to start then its too cold for me to be outside. So for its never happened they always start I guess it don't get that cold here in Missoureee
Charlie
Once or if, a gelled fuel is warmed sufficiantly. Do the wax crystals brake back down so they will pass through the filter etc. ?
I am also wondering what harm, if any, this apparent gelling problem may have done to my filter. As in maybe some clogging and premature failure.
When I started the tractor this morning to take off the trash masher and re-install the plow. I noticed that the fuel level was near 3/8, so I dumped in approx. 12oz. of a NAPA additive and then poured in a fresh 5 gls. of fresh diesel.
The tractor was run (I think) long enough to have worked some of the now "well treated tank of diesel" into the filter and fuel system. The tractor ran like a champ all day.
I guess only time and more cold weather will tell if any problem has been cured.
/ Fuel System Heater ???? #16
You said the fuel level was near 3/8. I fill my tank up after running to prevent condensation. I wonder if you may have some water in your tank or fuel lines and that's what you've got to thaw up before it will run. My 2120 has started in -20F so far with just a block heater.
/ Fuel System Heater ???? #17
Wax becomes oil once it melts. I doubt its gelling on the filter will affect the filter. The pump doing the pumping to the filter is likely a low pressure one that pumps into a high pressure one that sends fuel to the injectors. The low pressure pump likely won't be able to put up enough pressure to collapse the filter.
Ralph
/ Fuel System Heater ???? #18
I have worked on lots of diesel trucks that have jelled. First thing is change fuel filter. It doesn't take much to clog one up. It is much easier to prevent than it is to cure a diesel that is jelled up.
They do have fuel heaters on trucks that run off coolant hoses from the engine. Of course they don't do anything if you can't get it started.
/ Fuel System Heater ???? #19
After having troubles not starting when we got hit by the cold snap, I've now focused on keeping my block and hydraulic heaters plugged in on those really cold nights when I think I'm going to need the tractor in the morning. I'm also dumping a can of SeaFoam in with #1 fuel so I prevent any gelling... all of this seems to do the trick really well for me.
I take it that the folks out East don't like the cold? /forums/images/graemlins/wink.gif
Take care and stay warm out there!
-Bob
2017 Nissan Rogue SUV (A59231)
2017 Nissan Rogue...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A57024)
2022 NEW HOLLAND...
Teak Wood Dining Table (A59231)
Teak Wood Dining...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A59908)
2006 CHEVROLET...
2016 John Deere 6110M (A60462)
2016 John Deere...
