fuel heater
/ fuel heater #1
bluetc30
northeast ma
nh tc 30
I have a tc-30 when you turn the key part way to start, the fuel warmer comes on and preheats the fuel. where is the warmer located?
/ fuel heater #2
I’ve had no luck confirming the existence of a fuel heater. Are you sure it’s not glow plugs? If so they’re where you’d expect to find spark plugs if a diesel had them.
/ fuel heater #3
Big 10-4 (agree) I've never heard of a fuel heater. I've seen a heavy fuel return line that helps a little once you get warmed up. I myself would have to guess he is referring to glow plugs..
/ fuel heater #4
Unfortunately you are confusing a fuel heater found on some 18 wheelers with the equipment on your tractor.
This Bosch video gives you a good idea of what the GP's do. Don't go changing your engine's GP's for different models of GP's as you can do a lot of engine damage
Bosch Glow Plugs - YouTube
Your tractor has the Shibaura N843 engine
The workshop manual is available on line at this link.
Hustler Shibaura S773L N843 N843L Service Manual 19823 ;)9 | Piston | Cylinder (Engine)
Go to section 5-2 and you will see an illustration showing where the three glow plugs are located. One for each cylinder of your 3 cylinder engine..
Do you have an owner's manual for your tractor? If you do it should tell you how your glow plugs operate..
Some are controlled automatically by a GP controller. Others, probably like yours, are controlled manually. Usually there is a Glow Plug indicator which glows red as the GP's heat up.
Are you having starting problems or what brought you to this forum?
Dave M7040
/ fuel heater #6
Actually diesel pickups have fuel heaters. On my Dodge Cummins they are part of the fuel filter housing. I have not seen one on a tractor, but not impossible that here could be one. Most likely it is glow plugs he is looking for.
/ fuel heater #7
1998 Volvo VNL64T Sleeper Truck (A62679)
1998 Volvo VNL64T...
2024 Kubota SVL 75-3 (A64126)
2024 Kubota SVL...
2017 Hyundai Santa Fe AWD SUV (A64557)
2017 Hyundai Santa...
(2) CHROME STEP BARS (A64276)
(2) CHROME STEP...
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
(4) 12-16.5 Tires and Rims (A65640)
(4) 12-16.5 Tires...
