fuel heater
/ fuel heater #1
bluetc30
northeast ma
nh tc 30
I have a tc-30 when you turn the key part way to start, the fuel warmer comes on and preheats the fuel. where is the warmer located?
/ fuel heater #2
I’ve had no luck confirming the existence of a fuel heater. Are you sure it’s not glow plugs? If so they’re where you’d expect to find spark plugs if a diesel had them.
/ fuel heater #3
Big 10-4 (agree) I've never heard of a fuel heater. I've seen a heavy fuel return line that helps a little once you get warmed up. I myself would have to guess he is referring to glow plugs..
/ fuel heater #4
Unfortunately you are confusing a fuel heater found on some 18 wheelers with the equipment on your tractor.
This Bosch video gives you a good idea of what the GP's do. Don't go changing your engine's GP's for different models of GP's as you can do a lot of engine damage
Bosch Glow Plugs - YouTube
Your tractor has the Shibaura N843 engine
The workshop manual is available on line at this link.
Hustler Shibaura S773L N843 N843L Service Manual 19823 ;)9 | Piston | Cylinder (Engine)
Go to section 5-2 and you will see an illustration showing where the three glow plugs are located. One for each cylinder of your 3 cylinder engine..
Do you have an owner's manual for your tractor? If you do it should tell you how your glow plugs operate..
Some are controlled automatically by a GP controller. Others, probably like yours, are controlled manually. Usually there is a Glow Plug indicator which glows red as the GP's heat up.
Are you having starting problems or what brought you to this forum?
Dave M7040
/ fuel heater #6
Actually diesel pickups have fuel heaters. On my Dodge Cummins they are part of the fuel filter housing. I have not seen one on a tractor, but not impossible that here could be one. Most likely it is glow plugs he is looking for.
/ fuel heater #7
213138 (A64276)
213138 (A64276)
2019 Big Tex Gooseneck Low Pro Equipment Trailer (A66285)
2019 Big Tex...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
2024 Bobcat T650 (A64126)
2024 Bobcat T650...
2018 John Deere 3025E (A64126)
2018 John Deere...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
