fuel heater
/ fuel heater #1
bluetc30
northeast ma
nh tc 30
I have a tc-30 when you turn the key part way to start, the fuel warmer comes on and preheats the fuel. where is the warmer located?
/ fuel heater #2
I’ve had no luck confirming the existence of a fuel heater. Are you sure it’s not glow plugs? If so they’re where you’d expect to find spark plugs if a diesel had them.
/ fuel heater #3
Big 10-4 (agree) I've never heard of a fuel heater. I've seen a heavy fuel return line that helps a little once you get warmed up. I myself would have to guess he is referring to glow plugs..
/ fuel heater #4
Unfortunately you are confusing a fuel heater found on some 18 wheelers with the equipment on your tractor.
This Bosch video gives you a good idea of what the GP's do. Don't go changing your engine's GP's for different models of GP's as you can do a lot of engine damage
Bosch Glow Plugs - YouTube
Your tractor has the Shibaura N843 engine
The workshop manual is available on line at this link.
Hustler Shibaura S773L N843 N843L Service Manual 19823 ;)9 | Piston | Cylinder (Engine)
Go to section 5-2 and you will see an illustration showing where the three glow plugs are located. One for each cylinder of your 3 cylinder engine..
Do you have an owner's manual for your tractor? If you do it should tell you how your glow plugs operate..
Some are controlled automatically by a GP controller. Others, probably like yours, are controlled manually. Usually there is a Glow Plug indicator which glows red as the GP's heat up.
Are you having starting problems or what brought you to this forum?
Dave M7040
/ fuel heater #6
Actually diesel pickups have fuel heaters. On my Dodge Cummins they are part of the fuel filter housing. I have not seen one on a tractor, but not impossible that here could be one. Most likely it is glow plugs he is looking for.
/ fuel heater #7
1997 Ford F800 Dump Truck (A62613)
1997 Ford F800...
Keota MFG Bale Mover (A65640)
Keota MFG Bale...
2004 TRAILMOBILE 102" X 36' VAN TRAILER (A64277)
2004 TRAILMOBILE...
TRAILER MOUNTED LIGHT PLANT WITH FUEL CELL (A65643)
TRAILER MOUNTED...
Bush Hog 3Pt Post Hole Digger (A66408)
Bush Hog 3Pt Post...
2021 BOBCAT T62 R-SERIES SKID STEER (A65053)
2021 BOBCAT T62...
