Fuel follies
/ Fuel follies #41
I wonder why my local gas stop charges $2.50 a gallon today for e85? Gas fuel is $2.85. When gas was $2.10 e85 was $1.85. If e85 if only 15% gas why doesn't e85 raise at a lower rate per gal?
Cheers
/ Fuel follies #42
The reason diesel is more than gasoline is they hit it with an additional tax, to make the truckers pay for road maintenance, about 10 years ago.
Yeah, you're right about ethanol. Makes more sense to push for more diesel and biodiesel.
My cousin, a pilot, was complaining about the high price of av gas. They oughta come up with some 2 cycle (lighter weight) diesel engines for private aircraft.
The extra hydrofinishing to make low sulfur diesel shouldn't be very expensive.
Ralph
/ Fuel follies
Ralph
The Navy has an interest in finding a "heavy fuel" engine (probably recip diesel) to power UAV (Unmanned Aerial Vehicles.) Now the UAV mostly run on gasoline so the ships deploying them have to carry gasoline, not a popular item due to safety concerns. Crash a UAV on a carrier and spread a tank full of burning gasoline over some parked F/A-18 or F-14 jets and pretty soon it starts to add up to real bucks not to mention the fire you could have if the gasoline stores got set off.
I saw pix of a French guy flying a twin jet turbine powered airplane that weighed about 500 lb or so with him on board.
Pat
/ Fuel follies #45
I couldn't begin to answer the political side of this debate but one reason Diesel/home heating fuel is cheaper in summer is production amounts vary.
late fall refiners begine producing more heating fuel and diesel, summer use is more geared towards agasoline.
/ Fuel follies #46
Pat- similar to acid etching metal tanks before coating, F/G tanks are sloshed with MEK to remove oils and soften the F/G to promote adhesion. Diesel engine aircraft powered by twin Thielert turbo-diesels were introduced to Europe several years ago and FAA certified in the U.S. two years ago. The tiny twin engine aircraft you mentioned is called a Cri-Cri. There are several neat Cri-Cri videos on youtube including one with twin turbines, the world's smallest twin jet! I've been adrift in a boat many times, some scary, but nowhere near the pucker factor as a dead stick landing in a bean field I assure you.
2010 International 4300 Truck Altec DM47TR Insulated Material Handling Digger Derrick Truck (A64194)
2010 International...
Adams Nurse Trailer Tank (A63688)
Adams Nurse...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
7102 (A61567)
7102 (A61567)
Deere 210G LC (A64126)
