Fuel filter?
/ Fuel filter? #1
2515R Dude
Platinum Member
KY
Branson 2515R
I have this kind of filter. There is no maintenance for it, just replacement, however, my search skills betrayed me again, i cannot find it online.
Where can i find one or maybe just replace with something more conventional?
What do you do TBN gurus?
/ Fuel filter? #2
Dont have a TYM, but... it appears to me that its a paper filler inside the bowl, or is this just a simple sediment bowl with a water bleeder? If its just a sediment bowl, and water bleeder, you would only replace if damaged.
/ Fuel filter?
Apparently not. According to this TYM maintenance vid, the part number is 16119513000.
/ Fuel filter? #4
Hmm, thats an "intresting" design choice... Why wouldn't they use a standard can type fuel filter thats screws to the assembly, Or use a removable bowl with a paper element? Seems like they turned a $30 assembly and a $10 filter, into a $80.45 part...
/ Fuel filter?
Oh, you found it. I could not even find it online.
Found this one on Amazon. I guess it would be a good alternative.
/ Fuel filter? #6
That's the option people tend to replace that filter you have with, as the OEM is very very expensive. I would just recommend to get a better quality filter for that Amazon one.
/ Fuel filter? #7
Our just bite the bullet and replace it with a Racor sediment bowl filter. Not cheap, but worth it imho. Select 2,10, or 30 micron filters, easy servicing.
/ Fuel filter? #8
That is what I would do, many different manufactures and models to choose from.
/ Fuel filter?
/ Fuel filter? #10
Dude, good find on the filter! I was needing one for the 5520.
$80. some dollars is hard to swallow for a fuel filter from TYM.....
Thanks again
/ Fuel filter?
Thanks again
Some members say there are better options available, hope they elaborate
/ Fuel filter? #12
The chinesse housing is considerably less expensive then the genuine Racor,
the actual Racor filters are likely to be a better quality filter , in the R12 lineup you can actually get a 2 micron filter element.
/ Fuel filter? #13
The genuine article complete;
/ Fuel filter? #14
Of course I got to browsing the Racor website, guess what I found;
/ Fuel filter? #15
Buy once, cry once with the Racor filters. I put a 215r on my tractor with a 2 micron element. The replacement filters can be found a case at a time for $10 each.
/ Fuel filter?
They look awfully similar the amazon's one, probably made at the same plant,
I think i'll buy the housing from the amazon but the filter elements from racor.
Actually R12t is a 10 micron filter according to Racor website.
the 2 micron is R12SUL.
/ Fuel filter?
Finally got around to install a new fuel filter. I'm sure the old one would serve me for another 500 hours, but me being **** about maintenance wanted to do it now.
I decided to try one from amazon. If i didn't like it, easy to return. Chosen the one with the best reviews even though I'm 99% sure they all are made at the same plant with the genuine Racor, the only difference is the writing.
It looked to be very good quality which confirmed my 99% opinion. Really solid, great machine work and cost only $18 (with 10% coupon).
It is a little larger then the OEM, so I had to change the location and fabricate a new bracket. Took me a little while (about 2 hours including drying time), but now i hope i'm set for life.
Here is the filter: Amazon.com
Before
The filter
The new location
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A65643)
2007 DRAGON 150...
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
