Oil & Fuel Fuel filter water drain
   / Fuel filter water drain #1
repete
SW Washington
L2550DT IH584-4WD
Has anyone seen a fuel bowl with a water drain for a 2550? I get tired of pulling my filter just to get rid of some water.
Not sure. I use clean filtered fuel but it may be condensation in the tank. There is moisture in Washington...
   / Fuel filter water drain #6
My fuel is ran through this filter before going into the tractor tank.
   / Fuel filter water drain #7
LB if the Revnoo'rs see that you can expect to get raided! Looks like you're makin' shine there.
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
2025 IRGC40 Mini 3 60v Electric Tricycle (A56859)
2025 IRGC40 Mini 3...
2017 Ford F-350XL (A57148)
2017 Ford F-350XL...
Squat Machine (A57454)
CATERPILLAR 305 CR EXCAVATOR (A60429)
CATERPILLAR 305 CR...
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58216)
2019 ALLMAND...
