Oil & Fuel Fuel filter water drain
/ Fuel filter water drain #1
repete
SW Washington
L2550DT IH584-4WD
Has anyone seen a fuel bowl with a water drain for a 2550? I get tired of pulling my filter just to get rid of some water.
Not sure. I use clean filtered fuel but it may be condensation in the tank. There is moisture in Washington...
/ Fuel filter water drain #6
My fuel is ran through this filter before going into the tractor tank.
/ Fuel filter water drain #7
LB if the Revnoo'rs see that you can expect to get raided! Looks like you're makin' shine there.
