Oil & Fuel Fuel filter water drain
   / Fuel filter water drain #1
repete
SW Washington
L2550DT IH584-4WD
Has anyone seen a fuel bowl with a water drain for a 2550? I get tired of pulling my filter just to get rid of some water.
Not sure. I use clean filtered fuel but it may be condensation in the tank. There is moisture in Washington...
   / Fuel filter water drain #6
My fuel is ran through this filter before going into the tractor tank.
   / Fuel filter water drain #7
LB if the Revnoo'rs see that you can expect to get raided! Looks like you're makin' shine there.
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
Landoll Lowboy Trailer (A55315)
Landoll Lowboy...
2019 KENWORTH T800 KILL TRUCK (A58214)
2019 KENWORTH T800...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
2014 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-250...
294 (A52706)
294 (A52706)
